Thank you for the explanation, that all makes sense.
And, yes, the piston was working for me, but not in the way I thought it was.
Oh. Ooops. Thatâs my fault. Between posting the piston and trying to understand it, I realised it was difficult to reset the light to test it each time, so I changed the variable definition to no initial value and just edited it true and false under variables in webCoRE before running it.
Why didnât I just set it white at the beginning of the piston? I have no idea.
I wouldnât have done that if Iâd realised it was significant! I know the variable resets on each piston run, but I thought pressing Test was a single run. Something else Iâm now understanding Iâm wrong about.
I think that solves your mystery, sorry about that
Iâm also seeing how my instinct to try to get things to work abstractly in code and then use the actual devices and triggers seems like it ought to be quicker and simpler, but isnât really helping.
Iâm now going to go away and see if I can get the same result in a less haphazard way.
Funny, I thought it was so simple!
