Trying to get a Piston setup to set an LED Indicator light to a specific color based on two different connections.
Door Locks Locked & Door Contact Sensor closed = Illuminate indicator green
Door Contact Sensor Closed & Door Locks unlocked = illuminate indicator red
Door Contact Sensor open = illuminate indicator white
Green and White indicators are working, can’t get red indicator.
1/2/2023, 8:38:39 PM +503ms
+3ms ╔Received event [Back Door Lock].lock/physical = locked with a delay of 44ms, canQueue: true, calledMyself: false
+12ms ║RunTime initialize > 11 LockT > 0ms > r9T > 2ms > pistonT > 0ms (first state access 5 m:9 4 7)
+15ms ║Runtime (6859 bytes) initialized in 2ms (v0.3.114.20221228_HE)
+16ms ║╔Execution stage started
+24ms ║║Comparison (enum) locked is (string) locked = true (1ms)
+26ms ║║Comparison (enum) locked is (string) locked = true (1ms)
+27ms ║║Condition #3 evaluated true (7ms)
+34ms ║║Comparison (enum) closed is (string) closed = true (0ms)
+37ms ║║Comparison (enum) open is (string) closed = false (1ms)
+38ms ║║Condition #4 evaluated false (10ms)
+39ms ║║Condition group #1 evaluated false (condition did not change) (19ms)
+45ms ║║Comparison (enum) closed is (string) open = false (1ms)
+47ms ║║Comparison (enum) open is (string) open = true (1ms)
+48ms ║║Condition #7 evaluated true (8ms)
+50ms ║║Condition group #2 evaluated true (condition did not change) (9ms)
+86ms ║║Executed device command [Office Scene Controller ].setLED(4,white,100) (19ms)
+89ms ║╚Execution stage complete. (72ms)
+113ms ╚Event processed successfully (111ms)
1/2/2023, 8:35:59 PM +843ms
+3ms ╔Received event [Back Door].contact = closed with a delay of 26ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 0ms > r9T > 1ms > pistonT > 0ms (first state access 6 m:11 4 8)
+15ms ║Runtime (6845 bytes) initialized in 1ms (v0.3.114.20221228_HE)
+21ms ║║Comparison (enum) unlocked is (string) locked = false (1ms)
+23ms ║║Condition #3 evaluated false (4ms)
+39ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+40ms ║║Comparison (enum) open is (string) closed = false (1ms)
+41ms ║║Condition #4 evaluated false (17ms)
+42ms ║║Condition group #1 evaluated false (condition did not change) (24ms)
+62ms ║║Comparison (enum) closed is (string) open = false (3ms)
+64ms ║║Comparison (enum) open is (string) open = true (1ms)
+65ms ║║Condition #7 evaluated true (22ms)
+66ms ║║Condition group #2 evaluated true (condition did not change) (23ms)
+123ms ║║Executed device command [Office Scene Controller ].setLED(4,white,100) (46ms)
+126ms ║╚Execution stage complete. (110ms)
+129ms ╚Event processed successfully (125ms)
1/2/2023, 8:35:54 PM +319ms
+5ms ╔Received event [Back Door].contact = open with a delay of 44ms, canQueue: true, calledMyself: false
+34ms ║RunTime initialize > 33 LockT > 0ms > r9T > 3ms > pistonT > 1ms (first state access 25 m:30 5 28)
+55ms ║Runtime (6841 bytes) initialized in 3ms (v0.3.114.20221228_HE)
+56ms ║╔Execution stage started
+95ms ║║Comparison (enum) unlocked is (string) locked = false (24ms)
+115ms ║║Condition #3 evaluated false (53ms)
+128ms ║║Comparison (enum) open is (string) closed = false (0ms)
+129ms ║║Condition #4 evaluated false (13ms)
+130ms ║║Condition group #1 evaluated false (condition did not change) (67ms)
+133ms ║║Comparison (enum) open is (string) open = true (1ms)
+134ms ║║Condition #7 evaluated true (4ms)
+135ms ║║Condition group #2 evaluated true (condition did not change) (5ms)
+162ms ║║Executed device command [Office Scene Controller ].setLED(4,white,100) (19ms)
+165ms ║╚Execution stage complete. (110ms)
+169ms ╚Event processed successfully (166ms)
1/2/2023, 8:35:20 PM +957ms
+10ms ╔Received event [Home].test = 1672709720957 with a delay of 1ms, canQueue: true, calledMyself: false
+32ms ║RunTime initialize > 31 LockT > 15ms > r9T > 1ms > pistonT > 0ms (first state access 5 m:15 25 6)
+42ms ║Runtime (6838 bytes) initialized in 1ms (v0.3.114.20221228_HE)
+43ms ║╔Execution stage started
+54ms ║║Comparison (enum) unlocked is (string) locked = false (0ms)
+55ms ║║Condition #3 evaluated false (4ms)
+58ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+59ms ║║Comparison (enum) open is (string) closed = false (1ms)
+61ms ║║Condition #4 evaluated false (5ms)
+62ms ║║Condition group #1 evaluated false (condition did not change) (11ms)
+66ms ║║Comparison (enum) closed is (string) open = false (1ms)
+67ms ║║Comparison (enum) open is (string) open = true (0ms)
+68ms ║║Condition #7 evaluated true (5ms)
+69ms ║║Condition group #2 evaluated true (condition did not change) (6ms)
+96ms ║║Executed device command [Office Scene Controller ].setLED(4,white,100) (19ms)
+100ms ║╚Execution stage complete. (57ms)
+102ms ╚Event processed successfully (93ms)
1/2/2023, 8:35:15 PM +256ms
+6ms ╔Received event [Home].test = 1672709715256 with a delay of 0ms, canQueue: true, calledMyself: false
+57ms ║RunTime initialize > 56 LockT > 0ms > r9T > 44ms > pistonT > 43ms (first state access 6 m:12 6 50)
+61ms ║Runtime (6893 bytes) initialized in 44ms (v0.3.114.20221228_HE)
+63ms ║╔Execution stage started
+86ms ║║Comparison (enum) unlocked is (string) locked = false (1ms)
+87ms ║║Condition #3 evaluated false (19ms)
+90ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+92ms ║║Comparison (enum) open is (string) closed = false (0ms)
+93ms ║║Condition #4 evaluated false (4ms)
+94ms ║║Condition group #1 evaluated false (condition did not change) (26ms)
+98ms ║║Comparison (enum) closed is (string) open = false (0ms)
+100ms ║║Comparison (enum) open is (string) open = true (2ms)
+101ms ║║Condition #7 evaluated true (7ms)
+102ms ║║Condition group #2 evaluated true (condition did not change) (8ms)
+127ms ║║Executed device command [Office Scene Controller ].setLED(4,white,100) (19ms)
+131ms ║╚Execution stage complete. (68ms)
+135ms ╚Event processed successfully (129ms)
1/2/2023, 8:35:10 PM +9ms
+4ms ╔Starting piston… (v0.3.114.20221228_HE)
+23ms ║╔Subscribing to devices…
+83ms ║║Device missing from piston. Loading all from parent (57ms)
+120ms ║║subscriptions: no triggers, promoting conditions
+122ms ║║Subscribing to Back Door.contact…
+136ms ║║Subscribing to Front Door.contact…
+146ms ║║Subscribing to Back Door Lock.lock…
+159ms ║║Subscribing to Front Door Lock.lock…
+167ms ║║Piston utilizes Office Scene Controller []…
+183ms ║╚Finished subscribing (176ms)
+191ms ║Subscribing to Home.pistonID…(:b16cbebf75bff3f8c326779f91f311b5:)
+209ms ║Comparison (enum) unlocked is (string) locked = false (1ms)
+213ms ║Comparison (enum) closed is (string) closed = true (1ms)
+215ms ║Comparison (enum) open is (string) closed = false (1ms)
+220ms ║Comparison (enum) closed is (string) open = false (1ms)
+221ms ║Comparison (enum) open is (string) open = true (1ms)
+242ms ╚Piston started (239ms)
