I have a portion of a piston that does not interpret the “…but only in December” part. It is getting triggered at the right time but somehow fails this evaluation.
Piston is triggered each morning at 20 minutes after sunrise. The conditional at lines 44-49 should execute between the last week of November through the first week of January.
It is the month of December and at sunrise+20 minutes, line 47 is executing as false.
I will do this if there is not an obvious problem to the above (like monthly exception evaluation does not work).
Any thoughts on why this would not evaluate to TRUE?
