Piston triggers twice in quick succession instead of just once
Piston only triggers once in a set time period (e.g. once per X minute) and ignore repeated triggers in that period.
**5) Attach any logs
4/10/2019, 8:46:28 AM +40ms
+0ms ╔Received event [Home].execute = x.x.x.x with a delay of 74ms
+9887ms ║RunTime Analysis CS > 29ms > PS > 9817ms > PE > 41ms > CE
+9888ms ║Piston waited at a semaphore for 9772ms
+9890ms ║Runtime (37982 bytes) successfully initialized in 9817ms (v0.3.104.20180323) (9889ms)
+9892ms ║╔Execution stage started
+9898ms ║║Cancelling statement #1's schedules...
+10573ms ║║Executed physical command [Speakers
Group].playTrack([http://a.a.a.a/someoneisatthedoor.mp3]) (669ms)
+10575ms ║║Executed [Speakers Group].playTrack (671ms)
+10579ms ║║Cancelling statement #3's schedules...
+10599ms ║║Executed virtual command sendSMSNotification (14ms)
+10615ms ║║Executed virtual command sendSMSNotification (8ms)
+10618ms ║╚Execution stage complete. (727ms)
+10619ms ╚Event processed successfully (10620ms)
4/10/2019, 8:46:27 AM +664ms
+2ms ╔Received event [Home].execute = x.x.x.x with a delay of 134ms
+145ms ║RunTime Analysis CS > 35ms > PS > 72ms > PE > 38ms > CE
+148ms ║Runtime (37909 bytes) successfully initialized in 72ms (v0.3.104.20180323) (144ms)
+155ms ║║Cancelling statement #1's schedules...
+842ms ║║Executed physical command [Speakers
Group].playTrack([http://a.a.a.a/someoneisatthedoor.mp3]) (680ms)
+843ms ║║Executed [Speakers Group].playTrack (682ms)
+847ms ║║Cancelling statement #3's schedules...
+927ms ║║Executed virtual command sendSMSNotification (74ms)
+939ms ║║Executed virtual command sendSMSNotification (5ms)
+942ms ║╚Execution stage complete. (793ms)
+943ms ╚Event processed successfully (943ms)
This piston is incorrectly getting triggered twice by an external Tasker rule. Rather than try and fix the thing causing the trigger, I want to make my Piston robust and resistant to such false triggers by making it ignore any extra triggers within a set time period. Essentially, implement debounce logic.
So if this piston already ran within the last minute, then ignore it.
Is there an easy way to do this?
