Just had a thought, the devices to monitor are defined by a variable. So what happens if I go to ST app and rename one of those devices? Do I have to come back and update the piston accordingly?
Importing a Piston
Mike1616
#22
No. Not if you just rename things. WC will pickup on that and adjust accordingly. However, if you replace a device (currently) then you do have to go back in and change things I’ve heard they are working on building some code to allow you to replace devices easier…but right now you must edit each piston to change a device if you’re replacing it.
