Piston is supposed to control hue lightstrip with two motion sensors. Sometime works, sometime it does not
The piston is supposed to execute Executed physical command [Hue Bedroom].off() and turn off the light
Sometimes the light get turned off sometimes does not. here is an example
1/14/2020, 6:02:44 AM +81ms
+0ms ╔Received event [Home].time = 1578999765065 with a delay of -984ms
+127ms ║RunTime Analysis CS > 27ms > PS > 55ms > PE > 45ms > CE
+130ms ║Runtime (43313 bytes) successfully initialized in 55ms (v0.3.110.20191009) (128ms)
+170ms ║║Executed physical command [Hue Bedroom].off() (10ms)
+172ms ║║Executed [Hue Bedroom].off (12ms)
+174ms ║╚Execution stage complete. (43ms)
+176ms ╚Event processed successfully (176ms)
1/14/2020, 7:12:07 AM +153ms
+0ms ╔Received event [Home].time = 1579003928507 with a delay of -1354ms
+186ms ║RunTime Analysis CS > 69ms > PS > 67ms > PE > 50ms > CE
+189ms ║Runtime (43312 bytes) successfully initialized in 67ms (v0.3.110.20191009) (188ms)
+190ms ║╔Execution stage started
+191ms ║╚Execution stage complete. (0ms)
+192ms ╚Event processed successfully (191ms)
1/14/2020, 7:09:08 AM +235ms
+2ms ╔Received event [Bedroom Motion].motion = inactive with a delay of 123ms
+175ms ║RunTime Analysis CS > 56ms > PS > 64ms > PE > 55ms > CE
+178ms ║Runtime (43310 bytes) successfully initialized in 64ms (v0.3.110.20191009) (174ms)
+178ms ║╔Execution stage started
+223ms ║║Comparison (time) 25748416 is_between (time) 1579037760000 … (time) 1579003920000 = true (7ms)
+224ms ║║Time restriction check passed
+225ms ║║Condition #41 evaluated true (44ms)
+226ms ║║Condition group #null evaluated true (state did not change) (45ms)
+235ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+237ms ║║Cancelling condition #2’s schedules…
+238ms ║║Condition #2 evaluated false (9ms)
+239ms ║║Cancelling condition #1’s schedules…
+239ms ║║Condition group #1 evaluated false (state changed) (12ms)
+245ms ║║Comparison (enum) inactive changes_to (string) inactive = true (0ms)
+247ms ║║Condition #19 evaluated true (7ms)
+254ms ║║Comparison (enum) on is (string) on = true (1ms)
+255ms ║║Condition #32 evaluated true (8ms)
+256ms ║║Condition group #18 evaluated true (state did not change) (16ms)
+261ms ║║Comparison (string) :74a897f25ee3b31d6c771c70eb36e3fb: is (string) :74a897f25ee3b31d6c771c70eb36e3fb: = true (1ms)
+262ms ║║Cancelling condition #23’s schedules…
+263ms ║║Condition #23 evaluated true (5ms)
+264ms ║║Cancelling condition #20’s schedules…
+265ms ║║Condition group #20 evaluated true (state changed) (7ms)
+266ms ║║Cancelling statement #20’s schedules…
+270ms ║║Executed virtual command [Hue Bedroom].wait (0ms)
+271ms ║║Requesting a wake up for Tue, Jan 14 2020 @ 7:12:08 AM EST (in 180.0s)
+275ms ║╚Execution stage complete. (97ms)
+353ms ║Setting up scheduled job for Tue, Jan 14 2020 @ 7:12:08 AM EST (in 179.919s)
+360ms ╚Event processed successfully (360ms
1/14/2020, 7:08:41 AM +81ms
+1ms ╔Received event [Bedroom Motion].motion = active with a delay of 88ms
+118ms ║RunTime Analysis CS > 25ms > PS > 43ms > PE > 50ms > CE
+120ms ║Runtime (43316 bytes) successfully initialized in 43ms (v0.3.110.20191009) (118ms)
+160ms ║║Comparison (time) 25721205 is_between (time) 1579037760000 … (time) 1579003920000 = true (7ms)
+161ms ║║Time restriction check passed
+162ms ║║Condition #41 evaluated true (38ms)
+163ms ║║Condition group #null evaluated true (state did not change) (39ms)
+171ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+172ms ║║Cancelling condition #2’s schedules…
+173ms ║║Condition #2 evaluated true (8ms)
+180ms ║║Comparison (enum) off is (string) off = true (1ms)
+181ms ║║Condition #3 evaluated true (7ms)
+182ms ║║Cancelling condition #1’s schedules…
+183ms ║║Condition group #1 evaluated true (state changed) (19ms)
+188ms ║║Comparison (string) :74a897f25ee3b31d6c771c70eb36e3fb: is (string) :74a897f25ee3b31d6c771c70eb36e3fb: = true (1ms)
+189ms ║║Cancelling condition #10’s schedules…
+190ms ║║Condition #10 evaluated true (5ms)
+198ms ║║Comparison (enum) off is (string) off = true (1ms)
+199ms ║║Cancelling condition #33’s schedules…
+200ms ║║Condition #33 evaluated true (9ms)
+201ms ║║Cancelling condition #4’s schedules…
+202ms ║║Condition group #4 evaluated true (state changed) (16ms)
+203ms ║║Cancelling statement #4’s schedules…
+214ms ║║Executed physical command [Hue Bedroom].setLevel([50]) (8ms)
+215ms ║║Executed [Hue Bedroom].setLevel (10ms)
+221ms ║║Comparison (string) :74a897f25ee3b31d6c771c70eb36e3fb: is (string) :98a779fd563e96b34cce96ff82913e82: = false (1ms)
+222ms ║║Cancelling condition #17’s schedules…
+223ms ║║Condition #17 evaluated false (6ms)
+224ms ║║Cancelling condition #11’s schedules…
+225ms ║║Condition group #11 evaluated false (state changed) (7ms)
+227ms ║╚Execution stage complete. (106ms)
+228ms ╚Event processed successfully (228ms)
1/14/2020, 6:01:44 AM +814ms
+2ms ╔Received event [Bedroom Motion].motion = inactive with a delay of 111ms
+141ms ║RunTime Analysis CS > 27ms > PS > 61ms > PE > 53ms > CE
+144ms ║Runtime (43313 bytes) successfully initialized in 61ms (v0.3.110.20191009) (141ms)
+145ms ║╔Execution stage started
+189ms ║║Comparison (time) 21704962 is_between (time) 1579037760000 … (time) 1579003920000 = true (7ms)
+190ms ║║Time restriction check passed
+191ms ║║Condition #41 evaluated true (43ms)
+192ms ║║Condition group #null evaluated true (state did not change) (45ms)
+203ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+205ms ║║Cancelling condition #2’s schedules…
+206ms ║║Condition #2 evaluated false (12ms)
+207ms ║║Cancelling condition #1’s schedules…
+208ms ║║Condition group #1 evaluated false (state changed) (14ms)
+216ms ║║Comparison (enum) inactive changes_to (string) inactive = true (1ms)
+218ms ║║Condition #19 evaluated true (9ms)
+226ms ║║Comparison (enum) on is (string) on = true (2ms)
+227ms ║║Condition #32 evaluated true (8ms)
+228ms ║║Condition group #18 evaluated true (state did not change) (19ms)
+233ms ║║Comparison (string) :98a779fd563e96b34cce96ff82913e82: is (string) :74a897f25ee3b31d6c771c70eb36e3fb: = false (1ms)
+235ms ║║Condition #23 evaluated false (5ms)
+236ms ║║Condition group #20 evaluated false (state did not change) (6ms)
+241ms ║║Comparison (string) :98a779fd563e96b34cce96ff82913e82: is (string) :98a779fd563e96b34cce96ff82913e82: = true (1ms)
+243ms ║║Condition #27 evaluated true (5ms)
+244ms ║║Condition group #24 evaluated true (state did not change) (6ms)
+245ms ║║Cancelling statement #24’s schedules…
+249ms ║║Executed virtual command [Hue Bedroom].wait (0ms)
+250ms ║║Requesting a wake up for Tue, Jan 14 2020 @ 6:02:45 AM EST (in 60.0s)
+254ms ║╚Execution stage complete. (109ms)
+255ms ║Setting up scheduled job for Tue, Jan 14 2020 @ 6:02:45 AM EST (in 59.996s)
+269ms ╚Event processed successfully (269ms)
1/14/2020, 6:01:19 AM +213ms
+2ms ╔Received event [Bedroom Motion].motion = active with a delay of 110ms
+140ms ║RunTime Analysis CS > 23ms > PS > 51ms > PE > 65ms > CE
+142ms ║Runtime (43318 bytes) successfully initialized in 51ms (v0.3.110.20191009) (139ms)
+143ms ║╔Execution stage started
+188ms ║║Comparison (time) 21679360 is_between (time) 1579037760000 … (time) 1579003920000 = true (8ms)
+189ms ║║Time restriction check passed
+190ms ║║Condition #41 evaluated true (44ms)
+191ms ║║Condition group #null evaluated true (state did not change) (45ms)
+200ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+201ms ║║Cancelling condition #2’s schedules…
+202ms ║║Condition #2 evaluated true (9ms)
+210ms ║║Comparison (enum) off is (string) off = true (1ms)
+211ms ║║Condition #3 evaluated true (8ms)
+212ms ║║Cancelling condition #1’s schedules…
+213ms ║║Condition group #1 evaluated true (state changed) (19ms)
+218ms ║║Comparison (string) :98a779fd563e96b34cce96ff82913e82: is (string) :74a897f25ee3b31d6c771c70eb36e3fb: = false (2ms)
+219ms ║║Condition #10 evaluated false (4ms)
+220ms ║║Condition group #4 evaluated false (state did not change) (6ms)
+226ms ║║Comparison (string) :98a779fd563e96b34cce96ff82913e82: is (string) :98a779fd563e96b34cce96ff82913e82: = true (1ms)
+227ms ║║Condition #17 evaluated true (4ms)
+234ms ║║Comparison (enum) off is (string) off = true (2ms)
+235ms ║║Cancelling condition #34’s schedules…
+236ms ║║Condition #34 evaluated true (8ms)
+237ms ║║Cancelling condition #11’s schedules…
+238ms ║║Condition group #11 evaluated true (state changed) (16ms)
+239ms ║║Cancelling statement #11’s schedules…
+257ms ║║Executed physical command [Hue Bedroom].setLevel([25]) (14ms)
+258ms ║║Executed [Hue Bedroom].setLevel (15ms)
+260ms ║╚Execution stage complete. (117ms)
+261ms ╚Event processed successfully (261ms)
