I’m trying to loop over a list of network devices, and if a device is offline perform an action. The problem is that httpStatusOK is saying devices are offline when they are, and vice versa.
To accurately determine if an HTTP request was successful when sending requests asynchronously. The goal is to be able to resend requests that fail.
In my example piston below, devices 192.168.0.151, and 192.168.0.105 are ONLINE, and 192.168.0.152 is OFFLINE. It’s saying that my device 192.168.0.152 is online when it is in fact turned off. Device 192.168.0.105 is in fact receiving messages despite my logs saying it’s offline.
Logging Level: None (My Logs)
12/4/2020, 5:04:59 PM +78ms
+91ms ║Panel: 192.168.0.105 Status: ERROR
12/4/2020, 5:04:41 PM +431ms
+66ms ║Panel: 192.168.0.152 Status: OK
12/4/2020, 5:04:40 PM +50ms
+58ms ║Panel: 192.168.0.151 Status: OK
Logging Level: Full
+0ms ╔Received event [Home].time = 1607130125986 with a delay of -828ms
+39ms ║RunTime Analysis CS > 18ms > PS > 5ms > PE > 17ms > CE
+42ms ║Runtime (39662 bytes) successfully initialized in 5ms (v0.3.110.20191009) (41ms)
+43ms ║╔Execution stage started
+56ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+74ms ║║Calculating (string) Panel: + (string) 192.168.0.105 >> (string) Panel: 192.168.0.105
+77ms ║║Calculating (string) Panel: 192.168.0.105 + (string) Status: >> (string) Panel: 192.168.0.105 Status:
+80ms ║║Calculating (string) Panel: 192.168.0.105 Status: + (string) ERROR >> (string) Panel: 192.168.0.105 Status: ERROR
+84ms ║║Panel: 192.168.0.105 Status: ERROR
+85ms ║║Executed virtual command log (2ms)
+88ms ║╚Execution stage complete. (44ms)
+89ms ╚Event processed successfully (89ms)
12/4/2020, 5:01:50 PM +293ms
+1ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+41ms ║RunTime Analysis CS > 17ms > PS > 7ms > PE > 17ms > CE
+43ms ║Runtime (39667 bytes) successfully initialized in 7ms (v0.3.110.20191009) (41ms)
+44ms ║╔Execution stage started
+54ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+69ms ║║Calculating (string) Panel: + (string) 192.168.0.152 >> (string) Panel: 192.168.0.152
+72ms ║║Calculating (string) Panel: 192.168.0.152 + (string) Status: >> (string) Panel: 192.168.0.152 Status:
+74ms ║║Calculating (string) Panel: 192.168.0.152 Status: + (string) OK >> (string) Panel: 192.168.0.152 Status: OK
+77ms ║║Panel: 192.168.0.152 Status: OK
+78ms ║║Executed virtual command log (1ms)
+80ms ║╚Execution stage complete. (36ms)
+81ms ║Setting up scheduled job for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 15.612s)
+96ms ╚Event processed successfully (96ms)
12/4/2020, 5:01:46 PM +338ms
+43ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 15ms > CE
+46ms ║Runtime (39667 bytes) successfully initialized in 6ms (v0.3.110.20191009) (44ms)
+47ms ║╔Execution stage started
+58ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+73ms ║║Calculating (string) Panel: + (string) 192.168.0.151 >> (string) Panel: 192.168.0.151
+76ms ║║Calculating (string) Panel: 192.168.0.151 + (string) Status: >> (string) Panel: 192.168.0.151 Status:
+79ms ║║Calculating (string) Panel: 192.168.0.151 Status: + (string) OK >> (string) Panel: 192.168.0.151 Status: OK
+84ms ║║Panel: 192.168.0.151 Status: OK
+87ms ║╚Execution stage complete. (40ms)
+89ms ║Setting up scheduled job for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 19.519s), with 1 more job pending
+100ms ╚Event processed successfully (100ms)
12/4/2020, 5:01:45 PM +815ms
+0ms ╔Received event [Home].test = 1607130105814 with a delay of 0ms
+33ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 10ms > CE
+36ms ║Runtime (39659 bytes) successfully initialized in 6ms (v0.3.110.20191009) (35ms)
+38ms ║╔Execution stage started
+51ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+56ms ║║Cancelling statement #207’s schedules…
+66ms ║║Calculating (string) http:// + (string) 192.168.0.151 >> (string) http://192.168.0.151
+70ms ║║Calculating (string) http://192.168.0.151 + (string) :1817/?message=DATA >> (string) http://192.168.0.151:1817/?message=DATA
+77ms ║║Sending internal web request to: 192.168.0.151:1817/?message=DATA
+80ms ║║Executed virtual command httpRequest (4ms)
+82ms ║║Requesting a wake up for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 20.0s)
+100ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+104ms ║║Cancelling statement #207’s schedules…
+115ms ║║Calculating (string) http:// + (string) 192.168.0.152 >> (string) http://192.168.0.152
+118ms ║║Calculating (string) http://192.168.0.152 + (string) :1817/?message=DATA >> (string) http://192.168.0.152:1817/?message=DATA
+125ms ║║Sending internal web request to: 192.168.0.152:1817/?message=DATA
+128ms ║║Executed virtual command httpRequest (3ms)
+129ms ║║Requesting a wake up for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 20.0s)
+140ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+145ms ║║Cancelling statement #207’s schedules…
+155ms ║║Calculating (string) http:// + (string) 192.168.0.105 >> (string) http://192.168.0.105
+159ms ║║Calculating (string) http://192.168.0.105 + (string) :1817/?message=DATA >> (string) http://192.168.0.105:1817/?message=DATA
+166ms ║║Sending internal web request to: 192.168.0.105:1817/?message=DATA
+168ms ║║Executed virtual command httpRequest (3ms)
+170ms ║║Requesting a wake up for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 20.0s)
+183ms ║╚Execution stage complete. (146ms)
+193ms ║Setting up scheduled job for Fri, Dec 4 2020 @ 5:02:05 PM PST (in 19.891s), with 2 more jobs pending
+234ms ╚Event processed successfully (234ms)
