Today, the light came back on at 7:45AM, and there is nothing that appears in the WebCore logs, yet the IDE logs note that it was this piston that sent the set level command.
12/11/2017, 7:41:13 AM +296ms
+0ms
╔Received event [Home].time = 1512996074276 with a delay of -981ms
+447ms
║RunTime Analysis CS > 31ms > PS > 314ms > PE > 102ms > CE
+465ms
║Runtime (39930 bytes) successfully initialized in 314ms (v0.2.0ff.20171129) (463ms)
+467ms
║╔Execution stage started
+513ms
║║Executed physical command [Front Pot Lights].off() (12ms)
+514ms
║║Executed [Front Pot Lights].off (15ms)
+521ms
║╚Execution stage complete. (53ms)
+524ms
║Setting up scheduled job for Tue, Dec 12 2017 @ 6:10:00 AM EST (in 80926.181s), with 1 more job pending
+539ms
╚Event processed successfully (539ms)
12/11/2017, 7:41:04 AM +105ms
+1ms
╔Received event [Home].time = 1512996064643 with a delay of -538ms
+137ms
║RunTime Analysis CS > 19ms > PS > 45ms > PE > 72ms > CE
+148ms
║Runtime (39927 bytes) successfully initialized in 45ms (v0.2.0ff.20171129) (146ms)
+149ms
+170ms
║║Executed virtual command [Front Pot Lights].wait (0ms)
+171ms
║║Requesting a wake up for Mon, Dec 11 2017 @ 7:41:14 AM EST (in 10.0s)
+176ms
║╚Execution stage complete. (27ms)
+178ms
║Setting up scheduled job for Mon, Dec 11 2017 @ 7:41:14 AM EST (in 9.993s), with 2 more jobs pending
+193ms
╚Event processed successfully (192ms)
12/11/2017, 7:40:59 AM +128ms
+0ms
╔Received event [Home].time = 1512996060000 with a delay of -873ms
+169ms
║RunTime Analysis CS > 26ms > PS > 62ms > PE > 82ms > CE
+183ms
║Runtime (39931 bytes) successfully initialized in 62ms (v0.2.0ff.20171129) (182ms)
+185ms
+199ms
║║Comparison (time) 27659324 happens_daily_at (time) 22200000 = false (1ms)
+202ms
║║Cancelling condition #19’s schedules…
+203ms
║║Condition #19 evaluated false (7ms)
+206ms
║║Cancelling statement #19’s schedules…
+210ms
║║Requesting time schedule wake up at Tue, Dec 12 2017 @ 6:10:00 AM EST
+215ms
║║Condition group #15 evaluated false (state did not change) (20ms)
+257ms
║║Comparison (time) 27659348 happens_daily_at (datetime) 1512996060000 = true (1ms)
+259ms
║║Time restriction check passed
+261ms
║║Cancelling condition #24’s schedules…
+263ms
║║Condition #24 evaluated true (42ms)
+265ms
║║Cancelling statement #24’s schedules…
+272ms
║║Requesting time schedule wake up at Tue, Dec 12 2017 @ 7:41:00 AM EST
+286ms
║║Comparison (enum) on is (string) on = true (2ms)
+288ms
║║Condition #73 evaluated true (12ms)
+289ms
║║Cancelling condition #20’s schedules…
+291ms
║║Condition group #20 evaluated true (state changed) (71ms)
+295ms
║║Cancelling statement #21’s schedules…
+323ms
║║Executed virtual command [Front Pot Lights].sendPushNotification (21ms)
+341ms
║║Skipped execution of physical command [Front Pot Lights].setLevel([60]) because it would make no change to the device. (6ms)
+349ms
║║Executed physical command [Front Pot Lights].setLevel([55], [delay: 500]) (6ms)
+356ms
║║Executed physical command [Front Pot Lights].setLevel([50], [delay: 1000]) (5ms)
+361ms
║║Executed physical command [Front Pot Lights].setLevel([45], [delay: 1500]) (3ms)
+369ms
║║Executed physical command [Front Pot Lights].setLevel([40], [delay: 2000]) (5ms)
+375ms
║║Executed physical command [Front Pot Lights].setLevel([35], [delay: 2500]) (4ms)
+381ms
║║Executed physical command [Front Pot Lights].setLevel([30], [delay: 3000]) (5ms)
+388ms
║║Executed physical command [Front Pot Lights].setLevel([25], [delay: 3500]) (5ms)
+393ms
║║Executed physical command [Front Pot Lights].setLevel([20], [delay: 4000]) (3ms)
+399ms
║║Executed physical command [Front Pot Lights].setLevel([15], [delay: 4500]) (5ms)
+404ms
║║Executed physical command [Front Pot Lights].setLevel([10], [delay: 5000]) (3ms)
+410ms
║║Executed physical command [Front Pot Lights].setLevel([10], [delay: 5099]) (5ms)
+412ms
║║Executed virtual command [Front Pot Lights].fadeLevel (82ms)
+414ms
║║Requesting a wake up for Mon, Dec 11 2017 @ 7:41:04 AM EST (in 5.1s)
+422ms
║╚Execution stage complete. (238ms)
+425ms
║Setting up scheduled job for Mon, Dec 11 2017 @ 7:41:04 AM EST (in 5.091s), with 2 more jobs pending
+442ms
╚Event processed successfully (442ms)
12/11/2017, 6:09:59 AM +101ms
+1ms
╔Received event [Home].time = 1512990600000 with a delay of -900ms
+123ms
║RunTime Analysis CS > 18ms > PS > 36ms > PE > 69ms > CE
+134ms
║Runtime (39931 bytes) successfully initialized in 36ms (v0.2.0ff.20171129) (133ms)
+135ms
+145ms
║║Comparison (time) 22199244 happens_daily_at (time) 22200000 = true (0ms)
+147ms
+148ms
+149ms
║║Condition #19 evaluated true (6ms)
+150ms
+154ms
+164ms
║║Comparison (enum) on is (string) off = false (2ms)
+166ms
║║Cancelling condition #75’s schedules…
+167ms
║║Condition #75 evaluated false (11ms)
+168ms
║║Condition group #15 evaluated false (state did not change) (26ms)
+199ms
║║Comparison (time) 22199273 happens_daily_at (datetime) 1512996060000 = false (1ms)
+201ms
║║Condition #24 evaluated false (29ms)
+202ms
+207ms
║║Requesting time schedule wake up at Mon, Dec 11 2017 @ 7:41:00 AM EST
+210ms
║║Condition group #20 evaluated false (state did not change) (39ms)
+214ms
║╚Execution stage complete. (79ms)
+216ms
║Setting up scheduled job for Mon, Dec 11 2017 @ 7:41:00 AM EST (in 5460.684s), with 1 more job pending
+334ms
╚Event processed successfully (334ms)
See…no logs from WebCore about it turning back on…
