I have bought, downloaded and installed WebCoRE on my tablet, however in following the instructions for installation on the new Smartthings App it is not found
According to the instructions WebCoRE should be listed un the SmartApps section - however it is not found
These are the instructions I have followed to the letter:
Installing webCoRE
- Open the SmartThings app on your mobile device.
- From the Home screen, you have two options from where to add a new instance of webCoRE…
- touch the Plus (+) icon and select Smartapp
- or Select Menu and touch SmartApps and touch the Plus (+) icon
- Scroll down to the Custom section until you find webCoRE and tap it. If you can’t find webCore you likely skipped some steps above.
No piston to show as I don’t get that far
No logs to attach
