This is my first piston, Ive looked a couple of threads but nothing I’ve tried helped. I’ve messed around with some {} and back slashes, but no dice, i keep getting the same error
It should send the command successfully
Nothing is happening, I just receive the “Invalid ternary operator.” error. I KNOW it’ll be a simple fix, i just have no idea.
|+7ms|╔Received event [Home].test = 1604662930550 with a delay of 1ms, canQueue: true, calledMyself: false|
|+18ms|║RunTime initialize > 18 LockT > 2ms > rtDT > 1ms > pistonT > 0ms (first state access 15 9 9)|
|+20ms|║Runtime (5007 bytes) successfully initialized in 1ms (v0.3.110.20201015_HE)|
|+21ms|║╔Execution stage started|
|+24ms|║║Cancelling statement #1’s schedules…|
|+32ms|║║Invalid ternary operator. Ternary operator’s syntax is (condition ? trueValue:falseValue ). Please check your syntax.|
|+35ms|║║Calculating (string)amOn : (boolean)true >> (string)|
|+36ms|║║Calculating (string) , (string)tempTarget >> (string)tempTarget|
|+38ms|║║Invalid ternary operator. Ternary operator’s syntax is (condition ? trueValue:falseValue ). Please check your syntax.|
|+40ms|║║Calculating (string)tempTarget : (integer)22 >> (string)|
|+42ms|║║Invalid ternary operator. Ternary operator’s syntax is (condition ? trueValue:falseValue ). Please check your syntax.|
|+45ms|║║Calculating (string)DA : (string) >> (string)|
|+49ms|║║Sending asynchttpPut web request to: www.anonwebcore.com/
|+51ms|║║Executed virtual command httpRequest (3ms)|
|+53ms|║║Requesting a wake up for Fri, Nov 6 2020 @ 10:42:34 PM AEDT (in 24s)|
|+59ms|║╚Execution stage complete. (37ms)|
|+92ms|║Setting up scheduled job for Fri, Nov 6 2020 @ 10:42:34 PM AEDT (in 24s)|
|+96ms|╚Event processed successfully (95ms)|
