Not sure if this is an issue. piston ran, leaving me to think that its ok but I did notice this in the medium set logs. Is this an issue and/or what does this mean?
for there to be no errors
getting an error, not sure if its bad since the piston ran anyway
It was set to medium but still lists the error
10/17/2019, 8:07:22 AM +9ms
+0ms âReceived event [Home Master].routineExecuted = cc531390-996b-4bb1-8091-cae429fbe804 with a delay of 102ms
+105ms âRuntime (43686 bytes) successfully initialized in 56ms (v0.3.110.20191009) (104ms)
+106ms ââExecution stage started
+148ms ââInvalid ternary operator. Ternary operatorâs syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+156ms ââExecuted virtual command wait (1ms)
+158ms ââWaiting for 4000ms
+4187ms ââExecuted virtual command setAlarmSystemStatus (26ms)
+4248ms ââExecuted virtual command setLocationMode (58ms)
+4251ms ââExecuted virtual command wait (1ms)
+4252ms ââWaiting for 600ms
+6240ms ââExecuted virtual command resumePiston (1385ms)
+6254ms ââInvalid ternary operator. Ternary operatorâs syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+6260ms ââExecution stage complete. (6154ms)
+6262ms âEvent processed successfully (6261ms)
