I’m not really sure where to post this…hope this is right.
I have well over 50 ST devices in my system and I am sure some of my WebCore pistons (20-30 pistons) overlap devices and I could do better with that as well. But, I think pistons that end up needing to run at the same time are messing things up…For instance, I have one that triggers the back doors to unlock and the garage to open when I toggle a virtual switch from a wall mounted button controller by the back door.
There is also a piston that triggers when I open the back door to turn the light on outside which usually happens quickly after I trigger the virtual switch I mentioned above and often that light turning on is very delayed or doesn’t happen at all.
I’m just wondering if I purchased one or two more hubs and split the operations/devices between them and then used “super global variables” (which I think would work for this) to keep certain things they all need to know to be in sync with would help?
Has anybody tried this?
and totally get home automation is a fledgling field still (and WebCore is the BEST thing out there hands down).
…on the other hand…my better half is not and gets a little frustrated when things work “sometimes.”
