Having problems with creating an expression with isEmpty to look at a DateTime List correctly to see if an item on the list is empty. The issue is on the every 1 minute section of the piston only if the tile doesn’t have an entry on the date/time list.
This expression should be displaying on the footer of the Piston Tile either No Event Yet if there’s no entry on the date/time list or display the Date/time using the provided format.
Expression I’m using is this:
isEmpty(tileTime[tile]) ? ‘No Event Yet’ : {formatDateTime(tileTime[tile], {DateTimeFormula})}
I’ve tried doing this expression a few ways and even reversed around the No Event Yet’ and the {formatDateTime(tileTime[tile], {DateTimeFormula})} sections.
Currently it’s displaying the current date/time whenever there’s no entry in the date/time list. I’ve tried the expression several ways and even in the Evaluation console the date/time lists display correctly.
Evaluation console showing the correct values for the list entry 1 and 3:
Date/Time List on variables section showing only 1 entry on number 3:
Piston Tiles, the Kitchen Window correctly shows correct time but the other tiles should be showing No Event Yet instead of the date/time:
Note: I only set to 1 minute for the timer for testing only
10/23/2017, 4:10:11 PM +519ms +0ms ╔Received event [Home].time = 1508789411593 with a delay of -75ms +400ms ║RunTime Analysis CS > 196ms > PS > 101ms > PE > 103ms > CE +415ms ║Runtime (55685 bytes) successfully initialized in 101ms (v0.2.0fa.20171011) (414ms) +416ms ║╔Execution stage started +440ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +459ms ║║Cancelling statement #208's schedules... +471ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1 +476ms ║║Executed virtual command setVariable (3ms) +498ms ║║Calculating (string) closed == (string) open >> (boolean) false +517ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +526ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +530ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +547ms ║║Calculating (string) closed == (string) open >> (boolean) false +552ms ║║Executed virtual command setTile (1ms) +560ms ║║Cancelling statement #208's schedules... +573ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2 +578ms ║║Executed virtual command setVariable (3ms) +601ms ║║Calculating (string) closed == (string) open >> (boolean) false +621ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +632ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +636ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +656ms ║║Calculating (string) closed == (string) open >> (boolean) false +662ms ║║Executed virtual command setTile (1ms) +674ms ║║Cancelling statement #208's schedules... +690ms ║║Calculating (integer) 2 + (integer) 1 >> (integer) 3 +695ms ║║Executed virtual command setVariable (3ms) +723ms ║║Calculating (string) closed == (string) open >> (boolean) false +743ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +752ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +756ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +773ms ║║Calculating (string) closed == (string) open >> (boolean) false +779ms ║║Executed virtual command setTile (2ms) +788ms ║║Cancelling statement #208's schedules... +802ms ║║Calculating (integer) 3 + (integer) 1 >> (integer) 4 +807ms ║║Executed virtual command setVariable (3ms) +829ms ║║Calculating (string) closed == (string) open >> (boolean) false +849ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +857ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +862ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +878ms ║║Calculating (string) closed == (string) open >> (boolean) false +883ms ║║Executed virtual command setTile (1ms) +892ms ║║Cancelling statement #208's schedules... +909ms ║║Calculating (integer) 4 + (integer) 1 >> (integer) 5 +914ms ║║Executed virtual command setVariable (2ms) +935ms ║║Calculating (string) closed == (string) open >> (boolean) false +956ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +964ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +968ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +984ms ║║Calculating (string) closed == (string) open >> (boolean) false +989ms ║║Executed virtual command setTile (1ms) +998ms ║║Cancelling statement #208's schedules... +1015ms ║║Calculating (integer) 5 + (integer) 1 >> (integer) 6 +1022ms ║║Executed virtual command setVariable (5ms) +1044ms ║║Calculating (string) closed == (string) open >> (boolean) false +1064ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1072ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1076ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1093ms ║║Calculating (string) closed == (string) open >> (boolean) false +1098ms ║║Executed virtual command setTile (1ms) +1107ms ║║Cancelling statement #208's schedules... +1123ms ║║Calculating (integer) 6 + (integer) 1 >> (integer) 7 +1127ms ║║Executed virtual command setVariable (3ms) +1149ms ║║Calculating (string) closed == (string) open >> (boolean) false +1168ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1176ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1181ms ║║Calculating (boolean) false == (boolean) true >> (boolean) false +1197ms ║║Calculating (string) closed == (string) open >> (boolean) false +1202ms ║║Executed virtual command setTile (1ms) +1206ms ║║Cancelling statement #216's schedules... +1211ms ║║Executed virtual command setVariable (3ms) +1227ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1232ms ║║Cancelling statement #219's schedules... +1235ms ║║Executed virtual command clearTile (1ms) +1250ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1255ms ║║Cancelling statement #219's schedules... +1258ms ║║Executed virtual command clearTile (0ms) +1274ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1278ms ║║Cancelling statement #219's schedules... +1282ms ║║Executed virtual command clearTile (1ms) +1296ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1301ms ║║Cancelling statement #219's schedules... +1305ms ║║Executed virtual command clearTile (0ms) +1319ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1324ms ║║Cancelling statement #219's schedules... +1327ms ║║Executed virtual command clearTile (0ms) +1342ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1346ms ║║Cancelling statement #219's schedules... +1350ms ║║Executed virtual command clearTile (1ms) +1365ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1370ms ║║Cancelling statement #219's schedules... +1373ms ║║Executed virtual command clearTile (1ms) +1388ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1394ms ║║Cancelling statement #219's schedules... +1399ms ║║Executed virtual command clearTile (1ms) +1414ms ║║Calculating (integer) 7 + (integer) 1 >> (integer) 8 +1419ms ║║Cancelling statement #219's schedules... +1423ms ║║Executed virtual command clearTile (1ms) +1427ms ║╚Execution stage complete. (1010ms) +1428ms ║Setting up scheduled job for Mon, Oct 23 2017 @ 4:11:11 PM EDT (in 58.646s) +1494ms ╚Event processed successfully (1495ms)
