I’ve updated several DTH’s mainly for Jasco switches, to fix button press issues and make them compatible with the new SmartThings app and smartlighting app. The new app requires button action values, like “pushed” or “held” to be stored as a JSON object now (see developer doc here https://smartthings.developer.samsung.com/docs/api-ref/capabilities.html )
supportedButtonValues
List of valid button attribute values
- *Type: ** JSON_OBJECT * *Required: ** Yes
Webcore does not appear to be fully compatible with this JSON button value. A simple piston based on a button being held is failing
The log shows what is pasted below - the held event triggers the piston, but the line “is held” = “is held” is evaluating as false for some reason, when it really is true. Anyone have any idea what’s going wrong here? I have another DTH that is just “pushed” with no held that works fine. It seems having the two values together on one button is messing up webcore. Log:
+2ms ╔Received event [Living room lamp].button = held with a delay of 166ms
+44ms ║RunTime Analysis CS > 20ms > PS > 8ms > PE > 16ms > CE
+46ms ║Runtime (37539 bytes) successfully initialized in 8ms (v0.3.110.20191009) (44ms)
+47ms ║╔Execution stage started
+57ms ║║Comparison (enum) held gets (string) held = false (3ms)
+58ms ║║Condition #2 evaluated false (7ms)
+59ms ║║Condition group #1 evaluated false (state did not change) (8ms)
+61ms ║╚Execution stage complete. (14ms)
+62ms ╚Event processed successfully (62ms)
