I’m a very happy Echo Speaks user that moved from Smartthings to Hubitat specifically to keep using this app. I have one of my Echos programmed to play grandfather clock style chimes on the quarter hour by streaming from Amazon using searchAmazonMusic and playlists and it works fine.
I can have only one music stream running with Amazon Prime, so I’d like to move this off of streaming and play the mp3 directly. I purchased and downloaded the music tried hosting it online and I can play the music in browser sans login.
I’m trying to use the Play Track task to play a publicly accessible mp3. I’d like the audio in the mp3 file to play on the Echo device.
The echo speaks the name of the mp3 file without the suffix or the url. For example if my url is ‘https://www.somefakemp3host.com/Clock15.mp3’, the echo will say “Clock Fifteen” (I edited the url in the log from the real host below)
3/6/2021, 11:56:20 PM +337ms
+28ms ╔Received event [Home].test = 1615092980337 with a delay of 1ms, canQueue: true, calledMyself: false
+33ms ║RunTime initialize > 31 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 29 29 2)
+41ms ║Runtime (4642 bytes) successfully initialized in 1ms (v0.3.110.20201015_HE)
+43ms ║╔Execution stage started
+46ms ║║Cancelling statement #1’s schedules…
+431ms ║║Executed physical command [Echo - Office].playTrack([‘https://www.somefakemp3host.com/Clock15.mp3’], ) (375ms)
+433ms ║║Executed [Echo - Office].playTrack (378ms)
+439ms ║╚Execution stage complete. (396ms)
+444ms ╚Event processed successfully (424ms)
