After setting Task Execution Policy to “On Condition State Changes” for one of my IF statement my piston doesn’t run anymore even when the condition is TRUE (mode changes)
I would like my piston to be executed every time my location mode changes (Ex: in an other piston or in a routine) but not re-evaluate all the IF statements every time the piston runs. That’s the reason I changed the Task Execution Policy for those tasks
**5) Attach any logs
11/29/2018, 11:13:53 PM +921ms
+1ms ╔Received event [Home].mode = Away - Night with a delay of 38ms
+56ms ║RunTime Analysis CS > 12ms > PS > 32ms > PE > 11ms > CE
+58ms ║Runtime (39790 bytes) successfully initialized in 32ms (v0.3.108.20180906) (56ms)
+59ms ║╔Execution stage started
+64ms ║║Skipping execution for statement #104 because condition state did not change
+66ms ║╚Execution stage complete. (6ms)
+68ms ║Setting up scheduled job for Fri, Nov 30 2018 @ 7:00:00 AM EST (in 27966.012s)
+79ms ╚Event processed successfully (78ms)
11/29/2018, 11:13:11 PM +652ms
+1ms ╔Received event [Home].test = 1543551191651 with a delay of 0ms
+113ms ║RunTime Analysis CS > 22ms > PS > 67ms > PE > 25ms > CE
+118ms ║Runtime (39791 bytes) successfully initialized in 67ms (v0.3.108.20180906) (115ms)
+127ms ║║Skipping execution for statement #104 because condition state did not change
+145ms ║╚Execution stage complete. (25ms)
+149ms ║Setting up scheduled job for Fri, Nov 30 2018 @ 7:00:00 AM EST (in 28008.2s)
+161ms ╚Event processed successfully (161ms)
