I’ve got two different pistons that seem to not be consistently activating, and a third that I’m hoping to ensure looks good.
Control automation of bathroom shower/lights/exhaust fan.
#1 Cutoff shower if on for 30 with no movement or 1 hr even if movement
#2 Turn on heater (dependant on temperature), exhaust fan and shower light with shower, turn off post, turn on room light after
Not consistently activating, not consistently impacting all components. Latest time the cutoff didn’t run, but on a test did, and seemed to run twice.
Cutoff Logs:
11/19/2019, 7:25:23 PM +550ms
+1ms ╔Received event [Shower].valve = closed with a delay of 94ms
+66ms ║RunTime Analysis CS > 14ms > PS > 40ms > PE > 12ms > CE
+68ms ║Runtime (38554 bytes) successfully initialized in 40ms (v0.3.110.20191009) (66ms)
+69ms ║╔Execution stage started
+139ms ║║Duration 6153745ms for is >= 1800000ms threshold = true
+140ms ║║Comparison (enum) closed was (string) open = true (63ms)
+142ms ║║Condition #3 evaluated true (68ms)
+151ms ║║Comparison (enum) inactive is_not (string) active = true (2ms)
+152ms ║║Condition #4 evaluated true (9ms)
+153ms ║║Condition group #2 evaluated true (state did not change) (79ms)
+154ms ║║Condition group #1 evaluated true (state did not change) (81ms)
+156ms ║║Cancelling statement #6’s schedules…
+521ms ║║Executed physical command [Shower].close() (362ms)
+522ms ║║Executed [Shower].close (363ms)
+537ms ║║Executed virtual command [Shower].sendPushNotification (11ms)
+549ms ║║Executed virtual command [Shower].sendSMSNotification (7ms)
+551ms ║╚Execution stage complete. (482ms)
+552ms ╚Event processed successfully (552ms)
11/19/2019, 7:25:13 PM +585ms
+0ms ╔Received event [Suite].test = 1574209513584 with a delay of 1ms
+96ms ║RunTime Analysis CS > 22ms > PS > 58ms > PE > 16ms > CE
+99ms ║Runtime (38564 bytes) successfully initialized in 58ms (v0.3.110.20191009) (98ms)
+100ms ║╔Execution stage started
+242ms ║║Duration 6144114ms for is >= 1800000ms threshold = true
+243ms ║║Comparison (enum) open was (string) open = true (130ms)
+245ms ║║Cancelling condition #3’s schedules…
+246ms ║║Condition #3 evaluated true (141ms)
+255ms ║║Comparison (enum) inactive is_not (string) active = true (1ms)
+257ms ║║Condition #4 evaluated true (10ms)
+259ms ║║Cancelling condition #2’s schedules…
+260ms ║║Condition group #2 evaluated true (state changed) (154ms)
+261ms ║║Cancelling condition #1’s schedules…
+262ms ║║Condition group #1 evaluated true (state changed) (158ms)
+265ms ║║Cancelling statement #6’s schedules…
+736ms ║║Executed physical command [Shower].close() (467ms)
+737ms ║║Executed [Shower].close (469ms)
+788ms ║║Executed virtual command [Shower].sendPushNotification (45ms)
+867ms ║║Executed virtual command [Shower].sendSMSNotification (73ms)
+873ms ║╚Execution stage complete. (773ms)
+875ms ╚Event processed successfully (875ms)
11/19/2019, 12:42:03 PM +744ms
+10107ms ║Piston waited at a semaphore for 10014ms
#On/Off Logs:
11/19/2019, 7:33:26 PM +150ms
+1ms ╔Received event [Suite].time = 1574210007168 with a delay of -1019ms
+128ms ║RunTime Analysis CS > 25ms > PS > 64ms > PE > 39ms > CE
+130ms ║Runtime (39198 bytes) successfully initialized in 64ms (v0.3.110.20191009) (128ms)
+221ms ║║Executed physical command [Ceiling Heater].off() (64ms)
+223ms ║║Executed [Ceiling Heater].off (66ms)
+225ms ║╚Execution stage complete. (94ms)
+226ms ╚Event processed successfully (226ms)
11/19/2019, 7:31:24 PM +147ms
+0ms ╔Received event [Suite].time = 1574209884635 with a delay of -489ms
+164ms ║RunTime Analysis CS > 28ms > PS > 86ms > PE > 51ms > CE
+167ms ║Runtime (39197 bytes) successfully initialized in 86ms (v0.3.110.20191009) (165ms)
+168ms ║╔Execution stage started
+2029ms ║║Executed physical command [Shower Light].setLevel([0]) (1856ms)
+2988ms ║║Executed physical command [Shower Light].setLevel([0]) (954ms)
+3014ms ║║Cancelling statement #17’s schedules…
+3019ms ║║Executed virtual command [Ceiling Heater].wait (0ms)
+3021ms ║║Requesting a wake up for Tue, Nov 19 2019 @ 7:33:27 PM EST (in 120.0s)
+3025ms ║╚Execution stage complete. (2857ms)
+3026ms ║Setting up scheduled job for Tue, Nov 19 2019 @ 7:33:27 PM EST (in 119.995s)
+3034ms ╚Event processed successfully (3034ms)
11/19/2019, 7:29:53 PM +103ms
+1ms ╔Received event [Suite].time = 1574209794634 with a delay of -1531ms
+166ms ║RunTime Analysis CS > 47ms > PS > 90ms > PE > 29ms > CE
+169ms ║Runtime (39198 bytes) successfully initialized in 90ms (v0.3.110.20191009) (166ms)
+4180ms ║║Executed physical command [Shower Light].setLevel([1]) (4005ms)
+4182ms ║╚Execution stage complete. (4013ms)
+4184ms ║Setting up scheduled job for Tue, Nov 19 2019 @ 7:31:24 PM EST (in 87.348s), with 2 more jobs pending
+4193ms ╚Event processed successfully (4193ms)
11/19/2019, 7:28:22 PM +170ms
+1ms ╔Received event [Suite].time = 1574209703702 with a delay of -1532ms
+111ms ║RunTime Analysis CS > 23ms > PS > 58ms > PE > 30ms > CE
+114ms ║Runtime (39198 bytes) successfully initialized in 58ms (v0.3.110.20191009) (111ms)
+115ms ║╔Execution stage started
+524ms ║║Executed physical command [Ceiling Exhaust Fan].off() (385ms)
+525ms ║║Executed [Ceiling Exhaust Fan].off (387ms)
+527ms ║║Cancelling statement #8’s schedules…
+2426ms ║║Executed physical command [Overhead Light].on() (1895ms)
+2427ms ║║Executed [Overhead Light].on (1897ms)
+2430ms ║║Cancelling statement #10’s schedules…
+2445ms ║║Skipped execution of physical command [Shower Light].setLevel([2]) because it would make no change to the device. (5ms)
+2466ms ║║Executed virtual command [Shower Light].fadeLevel (31ms)
+2467ms ║║Requesting a wake up for Tue, Nov 19 2019 @ 7:31:24 PM EST (in 180.1s)
+2472ms ║╚Execution stage complete. (2357ms)
+2474ms ║Setting up scheduled job for Tue, Nov 19 2019 @ 7:29:54 PM EST (in 89.991s), with 3 more jobs pending
+2482ms ╚Event processed successfully (2482ms)
11/19/2019, 7:25:23 PM +568ms
+2ms ╔Received event [Shower].valve = closed with a delay of 112ms
+104ms ║RunTime Analysis CS > 21ms > PS > 54ms > PE > 29ms > CE
+107ms ║Runtime (39184 bytes) successfully initialized in 54ms (v0.3.110.20191009) (104ms)
+108ms ║╔Execution stage started
+115ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+116ms ║║Cancelling condition #3’s schedules…
+117ms ║║Condition #3 evaluated false (5ms)
+118ms ║║Cancelling condition #1’s schedules…
+119ms ║║Condition group #1 evaluated false (state changed) (7ms)
+123ms ║║Comparison (enum) closed changes_to (string) closed = true (1ms)
+124ms ║║Condition #4 evaluated true (4ms)
+125ms ║║Condition group #2 evaluated true (state did not change) (5ms)
+127ms ║║Cancelling statement #5’s schedules…
+132ms ║║Executed virtual command [Ceiling Exhaust Fan].wait (1ms)
+133ms ║║Requesting a wake up for Tue, Nov 19 2019 @ 7:28:23 PM EST (in 180.0s)
+137ms ║╚Execution stage complete. (30ms)
+138ms ║Setting up scheduled job for Tue, Nov 19 2019 @ 7:28:23 PM EST (in 179.996s)
+149ms ╚Event processed successfully (149ms)
11/19/2019, 5:42:49 PM +921ms
+2ms ╔Received event [Shower].valve = open with a delay of 210ms
+120ms ║RunTime Analysis CS > 26ms > PS > 65ms > PE > 29ms > CE
+123ms ║Runtime (39189 bytes) successfully initialized in 65ms (v0.3.110.20191009) (120ms)
+124ms ║╔Execution stage started
+131ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+132ms ║║Cancelling condition #3’s schedules…
+133ms ║║Condition #3 evaluated true (5ms)
+134ms ║║Cancelling condition #1’s schedules…
+135ms ║║Condition group #1 evaluated true (state changed) (7ms)
+137ms ║║Cancelling statement #12’s schedules…
+1736ms ║║Executed physical command [Shower Light].on() (1595ms)
+1737ms ║║Executed [Shower Light].on (1597ms)
+1740ms ║║Cancelling statement #14’s schedules…
+1853ms ║║Executed physical command [Ceiling Exhaust Fan].on() (109ms)
+1854ms ║║Executed [Ceiling Exhaust Fan].on (111ms)
+1866ms ║║Comparison (decimal) 60.0 is_less_than_or_equal_to (integer) 67 = true (1ms)
+1867ms ║║Condition #22 evaluated true (10ms)
+1868ms ║║Condition group #20 evaluated true (state did not change) (12ms)
+1870ms ║║Cancelling statement #20’s schedules…
+1902ms ║║Executed physical command [Ceiling Heater].on() (26ms)
+1903ms ║║Executed [Ceiling Heater].on (28ms)
+1905ms ║╚Execution stage complete. (1782ms)
+1906ms ╚Event processed successfully (1906ms)
. Alternately it could be set so it does activate every time it goes on, either way works so long as it always cuts it off if those conditions are met.
