I found this piston here on the forums and I’m trying to change a little bit of the functionality. It’s doing very weird things.
I’m hoping that 30 minutes before sundown and after sunup it will be enabled. When motion is detected turn on a few lights but only if I’m not watching TV (switch 5 6 and 7 are my Logitech Harmony activities) and all lights are already off. If any of the Logitech activities are on, or any of the lights involved (Dimmer 1 and 3, and Switch 2 and 3) I do not want the motion detection event to turn on the lights and ruin my movie! Once motion is no longer detected, wait 2 minutes, then turn off the lights. I also do not want the lights to turn off automatically, unless they were turned on automatically. If the light was on manually, don’t ever do anything.
Motion will enable the lights, but for some reason the whole house turns into a disco. The lights will turn on and off randomly and the only way to get it to stop is to disable the piston. Does anyone need a disco mode piston cause this one works fantastically!
I can get logs upon request but this piston has been disabled for a long while. I can’t figure it out!
Hopefully someone here can help me out. My wife is visually impaired and having this would make her trips around the house in the middle of the night much easier.
Thanks!
