I’ve got a simple action that turns off a light switch if another switch’s “LastEvent” string is not equal to Tap ▲▲. The logs seem to show that even though the string looks to match, it evaluates the comparison as true (as in, WebCoRE thinks that the two strings indeed do not match).
WebCoRE evaluates the two strings as matching.
WebCoRE is evaluating the two strings as not matching.
9/14/2021, 8:37:17 PM +74ms
+5ms ╔Received event [Hubitat].time = 1631669837016 with a delay of 58ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 10 6 6)
+15ms ║Runtime (5873 bytes) successfully initialized in 1ms (v0.3.113.20210825_HE)
+19ms ║╔Execution stage started
+30ms ║║Comparison (string) Tap ▲▲ is_not (string) Tap ▲▲ = true (1ms)
+31ms ║║Condition #4 evaluated true (5ms)
+34ms ║║Condition group #3 evaluated true (state did not change) (8ms)
+35ms ║║Cancelling statement #7's schedules...
+68ms ║║Executed physical command [Master Closet Lights].off() (19ms)
+69ms ║║Executed [Master Closet Lights].off (31ms)
+77ms ║╚Execution stage complete. (57ms)
+84ms ╚Event processed successfully (82ms)
9/14/2021, 8:37:11 PM +943ms
+4ms ╔Received event [Master Closet Lights].switch = on with a delay of 51ms, canQueue: true, calledMyself: false
+42ms ║RunTime initialize > 41 LockT > 4ms > rtDT > 27ms > pistonT > 26ms (first state access 10 9 32)
+45ms ║Runtime (5821 bytes) successfully initialized in 27ms (v0.3.113.20210825_HE)
+46ms ║╔Execution stage started
+54ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+56ms ║║Cancelling condition #2's schedules...
+57ms ║║Condition #2 evaluated true (8ms)
+59ms ║║Cancelling condition #1's schedules...
+61ms ║║Condition group #1 evaluated true (state changed) (11ms)
+63ms ║║Cancelling statement #5's schedules...
+70ms ║║Executed virtual command wait (1ms)
+73ms ║║Requesting a wake up for Tue, Sep 14 2021 @ 8:37:17 PM CDT (in 5000ms)
+89ms ║╚Execution stage complete. (44ms)
+110ms ║Setting up scheduled job for Tue, Sep 14 2021 @ 8:37:17 PM CDT (in 5009ms)
+112ms ╚Event processed successfully (110ms)
The issue here is this line:
Based on what I’m reading, it sure looks like this should evaluate to false, but is instead evaluating to true. Am I missing something here? Thanks!
