I’ve created a “disco” piston to that slowly fades the hue of my Sylvania bulbs through the spectrum. I have this the fade working properly using a virutal switch to trigger it and the loop runs as expected - stopping when the virtual switch is “off”. I’ve added some additional code that should run after the final loop completes that should reset the color temperature back to normal, but it doesn’t ever seem to run.
Any idea what I might be doing wrong here? I’ve tried both a while and repeat and it never seems to run.
thanks!
