I’m assuming that time starts over at midnight, If I had a piston to lock at 11:59pm and unlock after 12:01am that since its passed midnight(another day) the piston works basically as described.
Also How much time does a piston need for “if time is between” I understand it checks every 30 sec. so technically I could set it between 7:30 and 7:31 and it would work. Is there a minimum of time needed for it to work? or to run it’s best.
I did do a search on this but couldn’t find the answers in wiki or other post.
