I have a working Piston that waits till the level of Light in Lux is reported by my locally located Weather Station to be Zero Lux. Then it proceeds to turn on lights and set other lights to specific light levels in percentage.
Turn some specific lights on and set other lights to a specific percentage.
Since there is still a good amount of ambient light outdoors when the Weather Station reads Zero Lux I would like to insert a wait command that allows the piston to wait a specific amount of time (ex. 30 minutes / 45 minutes) and then fires off all of the commands in the Piston. This will allow the outside light level to diminish even further to the point where outdoor light are actually needed and be more efficient. There will be a cost saving in power as the lights are not triggered to turn on when not needed.
I have not logged the events as the Piston works , but I am not sure if the Wait/ Delay is PROPER and will effect all the lights and not just the ones in which I added the Do Wait command.
