For some reason a month or so ago, the lights will sometimes turn off when you are in the kitchen
My motion sensor can only detect motion every 60 seconds (hence the timer) but every time it senses motion, the timer should reset, and it’s not always happening. This is how I do all my rooms, it’s designed after a big popular Occupancy Sensor piston by a member here, I forget his name
(PUT YOUR INFO HERE)
