Piston has ‘Set Level to 10%’ and it appears to give the correct command (as per log entry), but lamp actually sets at 70%. This is a GE Link bulb which previously didn’t give problems thru SmartThings app, when on Wink hub had no issues, and using Stringify flows had no issues.
Lamp getting to correct setting as per piston’s command
These lines are from Log:
+508ms ║║Executed physical command [Living Room Lamp].setLevel([10]) (20ms)
+509ms ║║Executed [Living Room Lamp].setLevel (21ms)
