I’ve been using WebCoRE to control a few LIFX lights, but have recently run into some issues. Several months ago there was some change on ST’s, but the workaround to gain control over LIFX again was to use their “new” app (I use the original app because there’s some integrations I have that don’t work well with the “new” app). Anyways, the resolution was to re-link LIFX to ST with the new app, but then I could go back to the original app. I can still control the LIFX lights from the ST app, but WebCoRE isn’t getting the most updated list of “things” from ST. Not sure what the issue is. I also have the API connected between LIFX and webCoRE, but I don’t think that’s the issue, as I don’t use scenes with LIFX. Just in case, I made a new token on LIFX and inserted it within webCoRE - didn’t help.
I’m probably missing something simple here. I should say that WebCoRE is able to control 2 of the LIFX lights, but webCoRE still isn’t showing all of them (within devices) like it should.
