(Piston below is not behaving like it should)
(Bathroom lighting should be bright during the day and dim at night)
(Piston is not firing)
4) Post a Green Snapshot of the piston![image|45x37])
11/30/2020, 11:02:32 AM +162ms
+0ms â•”Received event [2060 Brughs Mill Rd].time = 1606752153361 with a delay of -1199ms
+127ms â•‘RunTime Analysis CS > 64ms > PS > 4ms > PE > 59ms > CE
+130ms â•‘Runtime (41052 bytes) successfully initialized in 4ms (v0.3.110.20191009) (129ms)
+131ms â•‘â•”Execution stage started
+162ms â•‘â•‘Cancelling condition #30's schedules...
+163ms â•‘â•‘Condition #30 evaluated true (2ms)
+164ms â•‘â•‘Cancelling condition #29's schedules...
+165ms â•‘â•‘Condition group #29 evaluated true (state changed) (4ms)
+167ms â•‘â•‘Cancelling statement #31's schedules...
+184ms â•‘â•‘Skipped execution of physical command [Bathroom Sink 1].off([]) because it would make no change to the device. (12ms)
+185ms â•‘â•‘Executed [Bathroom Sink 1].off (14ms)
+202ms â•‘â•‘Skipped execution of physical command [Bathroom Sink 2].off([]) because it would make no change to the device. (14ms)
+203ms â•‘â•‘Executed [Bathroom Sink 2].off (16ms)
+239ms â•‘â•‘Skipped execution of physical command [Bathroom Sink 3].off([]) because it would make no change to the device. (32ms)
+240ms â•‘â•‘Executed [Bathroom Sink 3].off (34ms)
+253ms â•‘â•‘Skipped execution of physical command [Shower Light].off([]) because it would make no change to the device. (9ms)
+253ms â•‘â•‘Executed [Shower Light].off (11ms)
+256ms ║╚Execution stage complete. (125ms)
+257ms ╚Event processed successfully (257ms)
