Lights are turning off when they shouldn’t
Lights should stay on with motion detected
Lights are shutting off when there is motion in the room.
11/1/2021, 5:30:17 PM +791ms
+0ms ╔Received event [Home].time = 1635805811014 with a delay of 6777ms
+126ms ║RunTime Analysis CS > 46ms > PS > 7ms > PE > 72ms > CE
+129ms ║Runtime (40482 bytes) successfully initialized in 7ms (v0.3.113.20210203) (127ms)
+151ms ║║Cancelling condition #6’s schedules…
+153ms ║║Condition #6 evaluated true (1ms)
+154ms ║║Cancelling condition #5’s schedules…
+155ms ║║Condition group #5 evaluated true (state changed) (5ms)
+157ms ║║Cancelling statement #7’s schedules…
+188ms ║║Executed physical command [Bathroom left].off() (23ms)
+190ms ║║Executed virtual command [Bathroom left].setSwitch (25ms)
+223ms ║║Executed physical command [Bathroom mid].off() (26ms)
+225ms ║║Executed virtual command [Bathroom mid].setSwitch (29ms)
+258ms ║║Executed physical command [Bathroom right].off() (26ms)
+259ms ║║Executed virtual command [Bathroom right].setSwitch (30ms)
+264ms ║╚Execution stage complete. (135ms)
+269ms ╚Event processed successfully (269ms)
11/1/2021, 5:27:28 PM +710ms
+2ms ╔Received event [#5].motion = inactive with a delay of 84ms
+77ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 50ms > CE
+79ms ║Runtime (40470 bytes) successfully initialized in 6ms (v0.3.113.20210203) (76ms)
+86ms ║║Comparison (enum) inactive changes = true (1ms)
+87ms ║║Condition #18 evaluated true (3ms)
+88ms ║║Condition group #1 evaluated true (state did not change) (4ms)
+94ms ║║Comparison (enum) inactive is (string) active = false (1ms)
+95ms ║║Cancelling condition #4’s schedules…
+96ms ║║Condition #4 evaluated false (6ms)
+97ms ║║Cancelling condition #3’s schedules…
+98ms ║║Condition group #3 evaluated false (state changed) (8ms)
+105ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+107ms ║║Condition #6 evaluated false (7ms)
+108ms ║║Condition group #5 evaluated false (state did not change) (8ms)
+111ms ║╚Execution stage complete. (30ms)
+112ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:30:11 PM CDT (in 162s)
+120ms ╚Event processed successfully (120ms)
11/1/2021, 5:25:13 PM +527ms
+1ms ╔Received event [#5].motion = active with a delay of 61ms
+75ms ║RunTime Analysis CS > 18ms > PS > 3ms > PE > 54ms > CE
+78ms ║Runtime (40472 bytes) successfully initialized in 3ms (v0.3.113.20210203) (75ms)
+86ms ║║Comparison (enum) active changes = true (1ms)
+87ms ║║Condition #18 evaluated true (4ms)
+88ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+95ms ║║Comparison (enum) active is (string) active = true (2ms)
+97ms ║║Cancelling condition #4’s schedules…
+98ms ║║Condition #4 evaluated true (6ms)
+99ms ║║Cancelling condition #3’s schedules…
+100ms ║║Condition group #3 evaluated true (state changed) (9ms)
+113ms ║║Comparison (time) 62713629 is_between (time) 14400000 … (time) 72000000 = true (9ms)
+115ms ║║Time restriction check passed
+116ms ║║Condition #10 evaluated true (14ms)
+118ms ║║Condition group #9 evaluated true (state did not change) (15ms)
+120ms ║║Cancelling statement #16’s schedules…
+129ms ║║Executed physical command [Bathroom left].setColorTemperature([5000]) (3ms)
+130ms ║║Executed [Bathroom left].setColorTemperature (5ms)
+138ms ║║Executed physical command [Bathroom mid].setColorTemperature([5000]) (4ms)
+139ms ║║Executed [Bathroom mid].setColorTemperature (6ms)
+144ms ║║Executed physical command [Bathroom right].setColorTemperature([5000]) (3ms)
+145ms ║║Executed [Bathroom right].setColorTemperature (5ms)
+162ms ║║Executed physical command [Bathroom left].setLevel([100]) (13ms)
+163ms ║║Executed [Bathroom left].setLevel (14ms)
+177ms ║║Executed physical command [Bathroom mid].setLevel([100]) (12ms)
+178ms ║║Executed [Bathroom mid].setLevel (13ms)
+192ms ║║Executed physical command [Bathroom right].setLevel([100]) (11ms)
+193ms ║║Executed [Bathroom right].setLevel (13ms)
+197ms ║╚Execution stage complete. (119ms)
+199ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:30:11 PM CDT (in 297s)
+210ms ╚Event processed successfully (209ms)
11/1/2021, 5:25:10 PM +903ms
+80ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 53ms > CE
+82ms ║Runtime (40468 bytes) successfully initialized in 5ms (v0.3.113.20210203) (80ms)
+90ms ║║Comparison (enum) inactive changes = true (0ms)
+91ms ║║Condition #18 evaluated true (4ms)
+92ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+98ms ║║Comparison (enum) inactive is (string) active = false (1ms)
+99ms ║║Cancelling condition #4’s schedules…
+100ms ║║Condition #4 evaluated false (6ms)
+101ms ║║Cancelling condition #3’s schedules…
+102ms ║║Condition group #3 evaluated false (state changed) (8ms)
+109ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+111ms ║║Adding a timed trigger schedule for condition 6
+113ms ║║Cancelling condition #6’s schedules…
+114ms ║║Condition #6 evaluated false (10ms)
+115ms ║║Cancelling condition #5’s schedules…
+116ms ║║Condition group #5 evaluated false (state changed) (12ms)
+119ms ║╚Execution stage complete. (36ms)
+121ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:30:11 PM CDT (in 299s)
+129ms ╚Event processed successfully (129ms)
11/1/2021, 5:23:22 PM +133ms
+0ms ╔Received event [Home].time = 1635805403213 with a delay of -1081ms
+84ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 58ms > CE
+86ms ║Runtime (40478 bytes) successfully initialized in 5ms (v0.3.113.20210203) (85ms)
+87ms ║╔Execution stage started
+107ms ║║Cancelling condition #6’s schedules…
+108ms ║║Condition #6 evaluated true (1ms)
+109ms ║║Cancelling condition #5’s schedules…
+110ms ║║Condition group #5 evaluated true (state changed) (4ms)
+112ms ║║Cancelling statement #7’s schedules…
+130ms ║║Executed physical command [Bathroom left].off() (13ms)
+131ms ║║Executed virtual command [Bathroom left].setSwitch (14ms)
+147ms ║║Executed physical command [Bathroom mid].off() (12ms)
+148ms ║║Executed virtual command [Bathroom mid].setSwitch (14ms)
+163ms ║║Executed physical command [Bathroom right].off() (13ms)
+164ms ║║Executed virtual command [Bathroom right].setSwitch (13ms)
+167ms ║╚Execution stage complete. (80ms)
+173ms ╚Event processed successfully (174ms)
11/1/2021, 5:22:15 PM +24ms
+0ms ╔Received event [#5].motion = active with a delay of 63ms
+68ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 49ms > CE
+71ms ║Runtime (40472 bytes) successfully initialized in 4ms (v0.3.113.20210203) (70ms)
+72ms ║╔Execution stage started
+79ms ║║Comparison (enum) active changes = true (0ms)
+80ms ║║Condition #18 evaluated true (4ms)
+81ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+87ms ║║Comparison (enum) active is (string) active = true (1ms)
+89ms ║║Cancelling condition #4’s schedules…
+90ms ║║Condition #4 evaluated true (7ms)
+91ms ║║Cancelling condition #3’s schedules…
+92ms ║║Condition group #3 evaluated true (state changed) (9ms)
+105ms ║║Comparison (time) 62535119 is_between (time) 14400000 … (time) 72000000 = true (8ms)
+106ms ║║Time restriction check passed
+108ms ║║Condition #10 evaluated true (14ms)
+109ms ║║Condition group #9 evaluated true (state did not change) (15ms)
+111ms ║║Cancelling statement #16’s schedules…
+120ms ║║Executed physical command [Bathroom left].setColorTemperature([5000]) (3ms)
+121ms ║║Executed [Bathroom left].setColorTemperature (5ms)
+127ms ║║Executed physical command [Bathroom mid].setColorTemperature([5000]) (3ms)
+128ms ║║Executed [Bathroom mid].setColorTemperature (5ms)
+136ms ║║Executed physical command [Bathroom right].setColorTemperature([5000]) (5ms)
+137ms ║║Executed [Bathroom right].setColorTemperature (6ms)
+153ms ║║Executed physical command [Bathroom left].setLevel([100]) (12ms)
+154ms ║║Executed [Bathroom left].setLevel (14ms)
+169ms ║║Executed physical command [Bathroom mid].setLevel([100]) (12ms)
+171ms ║║Executed [Bathroom mid].setLevel (14ms)
+186ms ║║Executed physical command [Bathroom right].setLevel([100]) (13ms)
+187ms ║║Executed [Bathroom right].setLevel (15ms)
+191ms ║╚Execution stage complete. (120ms)
+192ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:23:23 PM CDT (in 67s)
+206ms ╚Event processed successfully (206ms)
11/1/2021, 5:21:30 PM +498ms
+1ms ╔Received event [#5].motion = inactive with a delay of 75ms
+71ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 50ms > CE
+73ms ║Runtime (40470 bytes) successfully initialized in 4ms (v0.3.113.20210203) (72ms)
+81ms ║║Comparison (enum) inactive changes = true (1ms)
+82ms ║║Condition #18 evaluated true (3ms)
+83ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+90ms ║║Comparison (enum) inactive is (string) active = false (1ms)
+91ms ║║Cancelling condition #4’s schedules…
+92ms ║║Condition #4 evaluated false (6ms)
+93ms ║║Cancelling condition #3’s schedules…
+94ms ║║Condition group #3 evaluated false (state changed) (9ms)
+101ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+103ms ║║Condition #6 evaluated false (7ms)
+105ms ║║Condition group #5 evaluated false (state did not change) (8ms)
+108ms ║╚Execution stage complete. (33ms)
+109ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:23:23 PM CDT (in 112s)
11/1/2021, 5:18:25 PM +411ms
+2ms ╔Received event [#5].motion = active with a delay of 80ms
+83ms ║RunTime Analysis CS > 24ms > PS > 6ms > PE > 52ms > CE
+85ms ║Runtime (40472 bytes) successfully initialized in 6ms (v0.3.113.20210203) (83ms)
+86ms ║╔Execution stage started
+92ms ║║Comparison (enum) active changes = true (0ms)
+94ms ║║Condition #18 evaluated true (3ms)
+95ms ║║Condition group #1 evaluated true (state did not change) (4ms)
+101ms ║║Comparison (enum) active is (string) active = true (1ms)
+102ms ║║Cancelling condition #4’s schedules…
+103ms ║║Condition #4 evaluated true (6ms)
+104ms ║║Cancelling condition #3’s schedules…
+105ms ║║Condition group #3 evaluated true (state changed) (9ms)
+118ms ║║Comparison (time) 62305519 is_between (time) 14400000 … (time) 72000000 = true (8ms)
+119ms ║║Time restriction check passed
+121ms ║║Condition #10 evaluated true (13ms)
+122ms ║║Condition group #9 evaluated true (state did not change) (14ms)
+124ms ║║Cancelling statement #16’s schedules…
+141ms ║║Executed physical command [Bathroom left].setColorTemperature([5000]) (9ms)
+142ms ║║Executed [Bathroom left].setColorTemperature (10ms)
+153ms ║║Executed physical command [Bathroom mid].setColorTemperature([5000]) (6ms)
+154ms ║║Executed [Bathroom mid].setColorTemperature (8ms)
+164ms ║║Executed physical command [Bathroom right].setColorTemperature([5000]) (6ms)
+165ms ║║Executed [Bathroom right].setColorTemperature (8ms)
+191ms ║║Executed physical command [Bathroom left].setLevel([100]) (19ms)
+192ms ║║Executed [Bathroom left].setLevel (20ms)
+230ms ║║Executed physical command [Bathroom mid].setLevel([100]) (34ms)
+231ms ║║Executed [Bathroom mid].setLevel (36ms)
+257ms ║║Executed physical command [Bathroom right].setLevel([100]) (22ms)
+258ms ║║Executed [Bathroom right].setLevel (23ms)
+262ms ║╚Execution stage complete. (176ms)
+263ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:23:23 PM CDT (in 297s)
+273ms ╚Event processed successfully (272ms)
11/1/2021, 5:18:23 PM +88ms
+0ms ╔Received event [#5].motion = inactive with a delay of 89ms
+91ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 70ms > CE
+94ms ║Runtime (40468 bytes) successfully initialized in 5ms (v0.3.113.20210203) (92ms)
+101ms ║║Comparison (enum) inactive changes = true (1ms)
+103ms ║║Condition #18 evaluated true (3ms)
+104ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+110ms ║║Comparison (enum) inactive is (string) active = false (2ms)
+111ms ║║Cancelling condition #4’s schedules…
+112ms ║║Condition #4 evaluated false (6ms)
+113ms ║║Cancelling condition #3’s schedules…
+114ms ║║Condition group #3 evaluated false (state changed) (8ms)
+122ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+124ms ║║Adding a timed trigger schedule for condition 6
+127ms ║║Cancelling condition #6’s schedules…
+128ms ║║Condition #6 evaluated false (10ms)
+129ms ║║Cancelling condition #5’s schedules…
+130ms ║║Condition group #5 evaluated false (state changed) (14ms)
+133ms ║╚Execution stage complete. (39ms)
+134ms ║Setting up scheduled job for Mon, Nov 1 2021 @ 5:23:23 PM CDT (in 299s)
+143ms ╚Event processed successfully (143ms)
11/1/2021, 5:10:14 PM +998ms
+2ms ╔Received event [#5].motion = active with a delay of 82ms
+88ms ║RunTime Analysis CS > 26ms > PS > 5ms > PE > 57ms > CE
+91ms ║Runtime (40470 bytes) successfully initialized in 5ms (v0.3.113.20210203) (88ms)
+99ms ║║Comparison (enum) active changes = true (1ms)
+101ms ║║Condition #18 evaluated true (3ms)
+102ms ║║Condition group #1 evaluated true (state did not change) (6ms)
+109ms ║║Comparison (enum) active is (string) active = true (2ms)
+112ms ║║Condition #4 evaluated true (8ms)
+114ms ║║Cancelling condition #3’s schedules…
+115ms ║║Condition group #3 evaluated true (state changed) (11ms)
+132ms ║║Comparison (time) 61815116 is_between (time) 14400000 … (time) 72000000 = true (11ms)
+133ms ║║Time restriction check passed
+135ms ║║Condition #10 evaluated true (17ms)
+136ms ║║Condition group #9 evaluated true (state did not change) (18ms)
+139ms ║║Cancelling statement #16’s schedules…
+156ms ║║Executed physical command [Bathroom left].setColorTemperature([5000]) (10ms)
+157ms ║║Executed [Bathroom left].setColorTemperature (12ms)
+171ms ║║Executed physical command [Bathroom mid].setColorTemperature([5000]) (9ms)
+172ms ║║Executed [Bathroom mid].setColorTemperature (11ms)
+183ms ║║Executed physical command [Bathroom right].setColorTemperature([5000]) (7ms)
+184ms ║║Executed [Bathroom right].setColorTemperature (9ms)
+210ms ║║Executed physical command [Bathroom left].setLevel([100]) (19ms)
+211ms ║║Executed [Bathroom left].setLevel (22ms)
+234ms ║║Executed physical command [Bathroom mid].setLevel([100]) (19ms)
+235ms ║║Executed [Bathroom mid].setLevel (21ms)
+259ms ║║Executed physical command [Bathroom right].setLevel([100]) (20ms)
+260ms ║║Executed [Bathroom right].setLevel (21ms)
+263ms ║╚Execution stage complete. (171ms)
+265ms ╚Event processed successfully (264ms)Preformatted text
