First thanks to whomever I got the orginal piston from in the past. It’s great!
I copied one of my working pistons and the copied version is not working. The lights turn on, but never turn off.
If the door is opened, but there is no motion, the light will shutoff when the door is closed. If there is motion the light will turn off after two minutes of no motion.
The lights turn on, but never turnoff.
This piston does not work.
This piston does work.
3/5/2021, 8:48:42 PM +129ms
+4ms ╔Received event [Basement Door Contact].contact = closed with a delay of 42ms,canQueue: true, calledMyself: false
+26ms ║RunTime initialize > 25 LockT > 2ms > rtDT > 5ms > pistonT > 4ms (first state access 18 6 19)
+30ms ║Runtime (11474 bytes) successfully initialized in 5ms (v0.3.113.20210209_HE)
+32ms ║╔Execution stage started
+41ms ║║Comparison (enum) off is (string) off = true (1ms)
+43ms ║║Comparison (enum) off is (string) off = true (1ms)
+44ms ║║Condition #6 evaluated true (8ms)
+53ms ║║Condition #5 evaluated false (7ms)
+58ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+60ms ║║Condition #50 evaluated false (6ms)
+62ms ║║Condition group #49 evaluated false (state did not change) (16ms)
+63ms ║║Condition group #1 evaluated false (state did not change) (29ms)
+73ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+75ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+77ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+79ms ║║Adding a timed trigger schedule for condition 12
+81ms ║║Cancelling condition #12’s schedules…
+82ms ║║Condition #12 evaluated false (16ms)
+83ms ║║Condition group #53 evaluated false (state did not change) (18ms)
+89ms ║║Comparison (enum) closed stays (string) closed = true (1ms)
+91ms ║║Adding a timed trigger schedule for condition 52
+94ms ║║Condition #52 evaluated false (9ms)
+95ms ║║Condition group #55 evaluated false (state did not change) (10ms)
+96ms ║║Condition group #8 evaluated false (state did not change) (30ms)
+103ms ║║Condition #48 evaluated false (5ms)
+104ms ║║Condition group #46 evaluated false (state did not change) (7ms)
+109ms ║╚Execution stage complete. (77ms)
+125ms ║Setting up scheduled job for Fri, Mar 5 2021 @ 8:48:47 PM CST (in 5s),with 1 more job pending
+127ms ╚Event processed successfully (124ms)
3/5/2021, 8:48:42 PM +169ms
+3ms ╔Received event [Basement Door Contact].contact = open with a delay of 33ms,canQueue: true, calledMyself: false
+5ms ╚Event queued (4ms)
