I think I have this worked out, but the coding seems complex and messy and I was wondering if someone could just take a look at it and give some advice. Everything is working the way I want, but at times it is slow and throws semaphore errors.
I have an entry light in a landing coming up to my living room on a dimmer. The light can be turned on manually with a switch, and we use the light sometimes like when we watch TV or have a lot of people over. It also is at the front door, so if its night time, and now I got it to when it’s raining, it comes on when you unlock the door. Its also tied to a motion sensor, so if the doorbell senses motion, it turns on so if someone comes up to the house in the middle of the night it looks like they were spotted and the light comes on. So a little tricky, basically if its switched on I don’t want the lock or motion to impact the light. If its triggered by unlocking and off, I don’t want motion to impact it either. If motion impacts it, I want it to turn off after five minutes. If its locked manually, like we come inside and lock it, take off our shoes and coats, it shuts off after a few minutes. If its locked by the keypad or app, the light shuts off immediately, and stays off for five minutes so motion does not turn it back on as the car pulls away. Maybe I’m trying to do a little to much, but after motion or lock turns it on, the next “entry light on” event always causes a semaphore. I’m wondering if there are any tips for a better way to write it.
Its working but slow occasionally and has semaphore errors from time to time.
Logs:
7/29/2020, 9:05:37 PM +200ms
+1ms â•”Received event [Front Door].motion = inactive with a delay of 130ms
+92ms â•‘RunTime Analysis CS > 20ms > PS > 8ms > PE > 64ms > CE
+95ms â•‘Runtime (56969 bytes) successfully initialized in 8ms (v0.3.110.20191009) (93ms)
+96ms â•‘â•”Execution stage started
+107ms â•‘â•‘Condition #11 evaluated false (7ms)
+108ms â•‘â•‘Condition group #1 evaluated false (state did not change) (8ms)
+114ms â•‘â•‘Comparison (enum) inactive changes_to (string) active = false (1ms)
+115ms â•‘â•‘Condition #24 evaluated false (4ms)
+116ms â•‘â•‘Condition group #23 evaluated false (state did not change) (5ms)
+122ms â•‘â•‘Condition #33 evaluated false (4ms)
+123ms â•‘â•‘Condition group #32 evaluated false (state did not change) (5ms)
+132ms â•‘â•‘Condition #43 evaluated false (6ms)
+133ms â•‘â•‘Condition group #42 evaluated false (state did not change) (7ms)
+134ms â•‘â•‘Condition group #41 evaluated false (state did not change) (9ms)
+139ms â•‘â•‘Comparison (enum) inactive changes_to (string) inactive = true (1ms)
+140ms â•‘â•‘Cancelling condition #75's schedules...
+141ms â•‘â•‘Condition #75 evaluated true (5ms)
+145ms â•‘â•‘Comparison (string) motion is (string) motion = true (1ms)
+146ms â•‘â•‘Cancelling condition #52's schedules...
+147ms â•‘â•‘Condition #52 evaluated true (5ms)
+148ms â•‘â•‘Cancelling condition #51's schedules...
+149ms â•‘â•‘Condition group #51 evaluated true (state changed) (13ms)
+151ms â•‘â•‘Cancelling statement #98's schedules...
+156ms â•‘â•‘Executed virtual command setVariable (2ms)
+166ms â•‘â•‘Condition #15 evaluated false (7ms)
+167ms â•‘â•‘Condition group #14 evaluated false (state did not change) (8ms)
+174ms â•‘â•‘Condition #60 evaluated false (5ms)
+175ms â•‘â•‘Condition group #59 evaluated false (state did not change) (6ms)
+181ms â•‘â•‘Comparison (boolean) false stays (boolean) true = false (1ms)
+183ms â•‘â•‘Cancelling any timed trigger schedules for condition 83
+184ms â•‘â•‘Cancelling statement #83's schedules...
+185ms â•‘â•‘Condition #83 evaluated false (7ms)
+186ms â•‘â•‘Condition group #82 evaluated false (state did not change) (9ms)
+193ms â•‘â•‘Comparison (string) delayoff stays (string) delayoff = true (1ms)
+194ms â•‘â•‘Adding a timed trigger schedule for condition 101
+197ms â•‘â•‘Condition #101 evaluated false (7ms)
+197ms â•‘â•‘Condition group #100 evaluated false (state did not change) (9ms)
+200ms ║╚Execution stage complete. (103ms)
+201ms â•‘Setting up scheduled job for Wed, Jul 29 2020 @ 9:10:37 PM EDT (in 299.995s)
+209ms ╚Event processed successfully (209ms)
7/29/2020, 9:04:57 PM +925ms
+1ms â•”Received event [Entry light].switch = on with a delay of 119ms
+9863ms â•‘RunTime Analysis CS > 24ms > PS > 9770ms > PE > 70ms > CE
+9864ms â•‘Piston waited at a semaphore for 9764ms
+9867ms â•‘Runtime (57039 bytes) successfully initialized in 9770ms (v0.3.110.20191009) (9865ms)
+9868ms â•‘â•”Execution stage started
+9879ms â•‘â•‘Condition #11 evaluated false (7ms)
+9880ms â•‘â•‘Condition group #1 evaluated false (state did not change) (8ms)
+9888ms â•‘â•‘Cancelling condition #24's schedules...
+9889ms â•‘â•‘Condition #24 evaluated false (6ms)
+9890ms â•‘â•‘Cancelling condition #23's schedules...
+9891ms â•‘â•‘Condition group #23 evaluated false (state changed) (9ms)
+9898ms â•‘â•‘Condition #33 evaluated false (5ms)
+9899ms â•‘â•‘Condition group #32 evaluated false (state did not change) (6ms)
+9906ms â•‘â•‘Condition #43 evaluated false (4ms)
+9907ms â•‘â•‘Condition group #42 evaluated false (state did not change) (5ms)
+9908ms â•‘â•‘Condition group #41 evaluated false (state did not change) (7ms)
+9915ms â•‘â•‘Condition #75 evaluated false (3ms)
+9916ms â•‘â•‘Condition group #51 evaluated false (state did not change) (5ms)
+9921ms â•‘â•‘Comparison (enum) on changes_to (string) on = false (1ms)
+9922ms â•‘â•‘Condition #15 evaluated false (4ms)
+9923ms â•‘â•‘Condition group #14 evaluated false (state did not change) (5ms)
+9928ms â•‘â•‘Comparison (enum) on changes_to (string) off = false (1ms)
+9929ms â•‘â•‘Condition #60 evaluated false (4ms)
+9930ms â•‘â•‘Condition group #59 evaluated false (state did not change) (5ms)
+9936ms â•‘â•‘Comparison (boolean) false stays (boolean) true = false (1ms)
+9938ms â•‘â•‘Cancelling any timed trigger schedules for condition 83
+9939ms â•‘â•‘Cancelling statement #83's schedules...
+9940ms â•‘â•‘Condition #83 evaluated false (7ms)
+9941ms â•‘â•‘Condition group #82 evaluated false (state did not change) (9ms)
+9947ms â•‘â•‘Comparison (string) motion stays (string) delayoff = false (1ms)
+9949ms â•‘â•‘Cancelling any timed trigger schedules for condition 101
+9950ms â•‘â•‘Cancelling statement #101's schedules...
+9950ms â•‘â•‘Condition #101 evaluated false (7ms)
+9951ms â•‘â•‘Condition group #100 evaluated false (state did not change) (8ms)
+9953ms ║╚Execution stage complete. (85ms)
+9954ms ╚Event processed successfully (9954ms)
7/29/2020, 9:04:57 PM +476ms
+2ms â•”Received event [Front Door].motion = active with a delay of 125ms
+83ms â•‘RunTime Analysis CS > 19ms > PS > 7ms > PE > 56ms > CE
+86ms â•‘Runtime (56940 bytes) successfully initialized in 7ms (v0.3.110.20191009) (84ms)
+87ms â•‘â•”Execution stage started
+98ms â•‘â•‘Condition #11 evaluated false (8ms)
+99ms â•‘â•‘Condition group #1 evaluated false (state did not change) (9ms)
+104ms â•‘â•‘Comparison (enum) active changes_to (string) active = true (1ms)
+105ms â•‘â•‘Cancelling condition #24's schedules...
+106ms â•‘â•‘Condition #24 evaluated true (5ms)
+148ms â•‘â•‘Comparison (time) 75897583 is_between (time) 1596069540000 .. (time) 1596016980000 = true (8ms)
+149ms â•‘â•‘Time restriction check passed
+151ms â•‘â•‘Condition #25 evaluated true (44ms)
+154ms â•‘â•‘Comparison (string) off is (string) off = true (1ms)
+155ms â•‘â•‘Condition #26 evaluated true (4ms)
+159ms â•‘â•‘Comparison (boolean) false is_not (boolean) true = true (2ms)
+160ms â•‘â•‘Condition #80 evaluated true (4ms)
+167ms â•‘â•‘Comparison (enum) off is (string) off = true (1ms)
+168ms â•‘â•‘Cancelling condition #115's schedules...
+169ms â•‘â•‘Condition #115 evaluated true (7ms)
+170ms â•‘â•‘Cancelling condition #23's schedules...
+170ms â•‘â•‘Condition group #23 evaluated true (state changed) (69ms)
+172ms â•‘â•‘Cancelling statement #28's schedules...
+371ms â•‘â•‘Executed physical command [Entry light].setLevel([100]) (194ms)
+372ms â•‘â•‘Executed [Entry light].setLevel (196ms)
+374ms â•‘â•‘Cancelling statement #30's schedules...
+379ms â•‘â•‘Executed virtual command setVariable (3ms)
+386ms â•‘â•‘Calculating (string) On From Motion (at + (string) 9:04 P.M. >> (string) On From Motion (at 9:04 P.M.
+389ms â•‘â•‘Calculating (string) On From Motion (at 9:04 P.M. + (string) on >> (string) On From Motion (at 9:04 P.M. on
+391ms â•‘â•‘Calculating (string) On From Motion (at 9:04 P.M. on + (string) Wednesday >> (string) On From Motion (at 9:04 P.M. on Wednesday
+394ms â•‘â•‘Calculating (string) On From Motion (at 9:04 P.M. on Wednesday + (string) ) >> (string) On From Motion (at 9:04 P.M. on Wednesday)
+396ms â•‘â•‘Executed virtual command setState (1ms)
+402ms â•‘â•‘Condition #33 evaluated false (4ms)
+403ms â•‘â•‘Condition group #32 evaluated false (state did not change) (5ms)
+411ms â•‘â•‘Condition #43 evaluated false (4ms)
+411ms â•‘â•‘Condition group #42 evaluated false (state did not change) (6ms)
+412ms â•‘â•‘Condition group #41 evaluated false (state did not change) (7ms)
+417ms â•‘â•‘Comparison (enum) active changes_to (string) inactive = false (1ms)
+418ms â•‘â•‘Cancelling condition #75's schedules...
+419ms â•‘â•‘Condition #75 evaluated false (5ms)
+420ms â•‘â•‘Condition group #51 evaluated false (state did not change) (5ms)
+425ms â•‘â•‘Condition #15 evaluated false (3ms)
+426ms â•‘â•‘Condition group #14 evaluated false (state did not change) (5ms)
+432ms â•‘â•‘Condition #60 evaluated false (4ms)
+433ms â•‘â•‘Condition group #59 evaluated false (state did not change) (4ms)
+438ms â•‘â•‘Comparison (boolean) false stays (boolean) true = false (1ms)
+440ms â•‘â•‘Cancelling any timed trigger schedules for condition 83
+440ms â•‘â•‘Cancelling statement #83's schedules...
+441ms â•‘â•‘Condition #83 evaluated false (6ms)
+442ms â•‘â•‘Condition group #82 evaluated false (state did not change) (8ms)
+448ms â•‘â•‘Comparison (string) motion stays (string) delayoff = false (1ms)
+449ms â•‘â•‘Cancelling any timed trigger schedules for condition 101
+450ms â•‘â•‘Cancelling statement #101's schedules...
+451ms â•‘â•‘Condition #101 evaluated false (7ms)
+452ms â•‘â•‘Condition group #100 evaluated false (state did not change) (8ms)
+453ms ║╚Execution stage complete. (366ms)
+454ms ╚Event processed successfully (454ms)`Preformatted text`
