Light turns on with door opening, but I want the timer to re-start (from 0) every time the door is opened. Instead, it always turns off when the initial timer expires (the timer never resets). If I change the execution policy away from “never cancel”, then the piston will turn on/off the light correctly if the door is only opened once, but if I open it again, the light never turns off, so I am not sure what to change.
Thank you in advance for any help!
If it is after sunset (dark), and the outside light is off, turn on patio light when door opens; if the door closes & is re-opened, re-start the timer.
Light comes on when door is opened, but always shuts off after the initial timer expires, even if the door is re-opened… I had to set the “never cancel” option because otherwise when re-opening the door after the light is turned on the first time, the piston will cancel based on the light now being on.
11/14/2020, 9:56:19 PM +13ms
+8ms ╔Received event [9011Hub].time = 1605416179179 with a delay of -166ms, canQueue: true, calledMyself: false
+36ms ║RunTime initialize > 35 LockT > 1ms > rtDT > 2ms > pistonT > 0ms (first state access 32 9 26)
+38ms ║Runtime (6294 bytes) successfully initialized in 2ms (v0.3.110.20201015_HE)
+40ms ║Synchronizing scheduled event, waiting for 126ms
+222ms ║║Executed physical command [Patio lights].off() (23ms)
+223ms ║║Executed [Patio lights].off (25ms)
+228ms ║╚Execution stage complete. (60ms)
+231ms ╚Event processed successfully (229ms)
11/14/2020, 9:56:17 PM +912ms
+2ms ╔Received event [Slider].contact = closed with a delay of 50ms, canQueue: true, calledMyself: false
+24ms ║RunTime initialize > 23 LockT > 1ms > rtDT > 1ms > pistonT > 1ms (first state access 21 4 19)
+25ms ║Runtime (6275 bytes) successfully initialized in 1ms (v0.3.110.20201015_HE)
+26ms ║╔Execution stage started
+31ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+33ms ║║Cancelling condition #2’s schedules…
+34ms ║║Condition #2 evaluated false (5ms)
+35ms ║║Cancelling condition #1’s schedules…
+36ms ║║Condition group #1 evaluated false (state changed) (8ms)
+40ms ║╚Execution stage complete. (14ms)
+81ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 9:56:19 PM MST (in 1s)
+82ms ╚Event processed successfully (81ms)
11/14/2020, 9:56:13 PM +357ms
+2ms ╔Received event [Slider].contact = open with a delay of 44ms, canQueue: true, calledMyself: false
+21ms ║RunTime initialize > 20 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 18 3 17)
+23ms ║Runtime (6274 bytes) successfully initialized in 1ms (v0.3.110.20201015_HE)
+24ms ║╔Execution stage started
+29ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+30ms ║║Cancelling condition #2’s schedules…
+31ms ║║Condition #2 evaluated true (5ms)
+43ms ║║Comparison (time) 78973000 is_between (time) 62640000 … (time) 25080000 = true (8ms)
+44ms ║║Time restriction check passed
+46ms ║║Condition #3 evaluated true (14ms)
+47ms ║║Cancelling condition #1’s schedules…
+48ms ║║Condition group #1 evaluated true (state changed) (22ms)
+53ms ║║Comparison (enum) on is (string) off = false (0ms)
+54ms ║║Cancelling condition #5’s schedules…
+55ms ║║Condition #5 evaluated false (6ms)
+56ms ║║Cancelling condition #4’s schedules…
+57ms ║║Condition group #4 evaluated false (state changed) (8ms)
+61ms ║╚Execution stage complete. (38ms)
+89ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 9:56:19 PM MST (in 6s)
+91ms ╚Event processed successfully (90ms)
11/14/2020, 9:56:00 PM +568ms
+3ms ╔Received event [Slider].contact = closed with a delay of 37ms, canQueue: true, calledMyself: false
+20ms ║RunTime initialize > 19 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 17 4 15)
+22ms ║Runtime (6265 bytes) successfully initialized in 1ms (v0.3.110.20201015_HE)
+23ms ║╔Execution stage started
+28ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+31ms ║║Condition #2 evaluated false (5ms)
+32ms ║║Cancelling condition #1’s schedules…
+33ms ║║Condition group #1 evaluated false (state changed) (8ms)
+37ms ║╚Execution stage complete. (15ms)
+68ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 9:56:19 PM MST (in 19s)
+70ms ╚Event processed successfully (69ms)
11/14/2020, 9:55:49 PM +26ms
+3ms ╔Received event [Slider].contact = open with a delay of 32ms, canQueue: true, calledMyself: false
+35ms ║RunTime initialize > 34 LockT > 1ms > rtDT > 21ms > pistonT > 20ms (first state access 12 4 30)
+38ms ║Runtime (6206 bytes) successfully initialized in 21ms (v0.3.110.20201015_HE)
+39ms ║╔Execution stage started
+46ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+48ms ║║Cancelling condition #2’s schedules…
+49ms ║║Condition #2 evaluated true (7ms)
+61ms ║║Comparison (time) 78949000 is_between (time) 62640000 … (time) 25080000 = true (7ms)
+62ms ║║Time restriction check passed
+64ms ║║Condition #3 evaluated true (13ms)
+65ms ║║Cancelling condition #1’s schedules…
+66ms ║║Condition group #1 evaluated true (state changed) (23ms)
+70ms ║║Comparison (enum) off is (string) off = true (1ms)
+72ms ║║Condition #5 evaluated true (4ms)
+73ms ║║Condition group #4 evaluated true (state did not change) (6ms)
+74ms ║║Cancelling statement #6’s schedules…
+147ms ║║Executed physical command [Patio lights].on() (69ms)
+148ms ║║Executed [Patio lights].on (70ms)
+151ms ║║Executed virtual command [Patio lights].wait (1ms)
+153ms ║║Requesting a wake up for Sat, Nov 14 2020 @ 9:56:19 PM MST (in 30s)
+163ms ║╚Execution stage complete. (124ms)
+186ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 9:56:19 PM MST (in 30s)
+187ms ╚Event processed successfully (186ms)
