I have two lights in my kitchen, that ideally should turn on when the lux levels goes below a certain treshhold, and off when it goes above a different level. The latter is set to only trigger after five minutes with lux levels above the treshold.
But the issue is that the lights at points randomly turn off, and then back on. I suspect the “turn off” command triggers in a way I’m not quite understanding.
Expected behaviour should be:
Below 55 lux turn on lights
Lux moves above 85 for five minutes, turn off the lights
Lights seem to work normally with tthe expected results most of the time. Then at times with cloudy weather, it seems like the system doesn’t quite work as intended and the lights will turn off, and then quickly turn on.
|+1ms|╔Received event [Home].time = 1589657922799 with a delay of -691ms|
|+263ms|║RunTime Analysis CS > 65ms > PS > 162ms > PE > 36ms > CE|
|+266ms|║Runtime (39398 bytes) successfully initialized in 162ms (v0.3.110.20191009) (265ms)|
|+267ms|║╔Execution stage started|
|+282ms|║║Comparison (integer) 10 is_less_than_or_equal_to (integer) 55 = true (1ms)|
|+284ms|║║Condition #3 evaluated true (7ms)|
|+285ms|║║Condition group #2 evaluated true (state did not change) (9ms)|
|+288ms|║║Cancelling statement #4’s schedules…|
|+290ms|║║Skipping task 5 because of mode restrictions|
|+294ms|║╚Execution stage complete. (28ms)|
|+296ms|║Setting up scheduled job for Sat, May 16 2020 @ 9:39:12 PM CEST (in 30.396s)|
|+316ms|╚Event processed successfully (316ms)|
