Looking for options as previously this worked for me but causing issues ATM and not sure why.
I need multiple custom time slots where it waits a custom period of time before switching off.
This is what i currently use around the house.
I’m not sure why it used to work but doesn’t anymore.
Do you have any logs for when it fails to work?
I think I would break this up into 4 IF statements.
Not as elegant I know but it will work that way.
It would be easy to do as you can just duplicate an IF and then just change the time and the inactivity period for each newly duplicated IF.
The countdown timers that appear on the dashboard are odd, as when piston triggered countdown timer e.g. 2 minutes appears as is should, however when it reaches the end (should switch off light) but says pending then initiates another countdown timer, seems random also.
Have just made this with Else If, or would you break completely apart?
Just out of interest any particular reason?
I have quite a few pistons like this for various rooms
It’s just me I suppose.
If they are 4 completely separate IF’s then I know they will work independently of each other and the timers will not interfere with each other.
As I said that’s just me and how my tiny little mind works.
At the end of the day it’s what ever works for you. As people say, choice is good.
LOL ok fair enough
Think i will try this on failing that will make separate ones.
Interested to see if anyone else has had the same issues with timers.
