Lights are changing status when they should be staying the same when already on.
When my door unlocks i would like a few lights to turn on. If they are already on I would like them to keep the same status and not change or turn off.
Lights are turning on and turning off but the lights that are aready on are also turning off.
I did see this post to cancel the timer but then i run in to the issue of the lights not turning off.
12/30/2020, 6:10:14 PM +752ms
+1ms â•”Received event [Living Room Switch].switch = off with a delay of 53ms
+61ms â•‘RunTime Analysis CS > 14ms > PS > 3ms > PE > 44ms > CE
+63ms â•‘Runtime (40342 bytes) successfully initialized in 3ms (v0.3.110.20191009) (61ms)
+64ms â•‘â•”Execution stage started
+76ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (1ms)
+77ms â•‘â•‘Condition #7 evaluated false (9ms)
+78ms â•‘â•‘Condition group #6 evaluated false (state did not change) (10ms)
+87ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (1ms)
+88ms â•‘â•‘Condition #16 evaluated false (8ms)
+89ms â•‘â•‘Condition group #15 evaluated false (state did not change) (9ms)
+98ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (1ms)
+99ms â•‘â•‘Condition #24 evaluated false (8ms)
+100ms â•‘â•‘Condition group #23 evaluated false (state did not change) (8ms)
+101ms ║╚Execution stage complete. (37ms)
+102ms ╚Event processed successfully (102ms)
12/30/2020, 6:02:14 PM +485ms
+2ms â•”Received event [Living Room Switch].switch = on with a delay of 69ms
+76ms â•‘RunTime Analysis CS > 17ms > PS > 5ms > PE > 54ms > CE
+79ms â•‘Runtime (40341 bytes) successfully initialized in 5ms (v0.3.110.20191009) (77ms)
+80ms â•‘â•”Execution stage started
+94ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (1ms)
+95ms â•‘â•‘Condition #7 evaluated false (12ms)
+96ms â•‘â•‘Condition group #6 evaluated false (state did not change) (13ms)
+105ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (1ms)
+107ms â•‘â•‘Condition #16 evaluated false (8ms)
+107ms â•‘â•‘Condition group #15 evaluated false (state did not change) (9ms)
+117ms â•‘â•‘Comparison (enum) locked is (string) unlocked = false (2ms)
+118ms â•‘â•‘Condition #24 evaluated false (8ms)
+119ms â•‘â•‘Condition group #23 evaluated false (state did not change) (10ms)
+121ms ║╚Execution stage complete. (42ms)
+122ms ╚Event processed successfully (122ms)
