Give a description of the problem**
The lights are not turning off after the motion sensor goes inactive for 10 seconds. -
What is the expected behaviour?**
After the office motion sensor goes inactive all of the office lights should turn off. -
What is happening/not happening?**
Post a Green Snapshot of the piston![image|45x37]
Attach logs after turning logging level to Full**
1/3/2022, 4:46:52 PM +842ms
+2ms ╔Received event [Motion - Office].motion = inactive with a delay of 35ms, canQueue: true, calledMyself: false
+30ms ║RunTime initialize > 29 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 27 3 26)
+32ms ║Runtime (9061 bytes) successfully initialized in 1ms (v0.3.113.20211120_HE)
+33ms ║╔Execution stage started
+97ms ║║Device missing from piston. Loading all from parent (60ms)
+101ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+103ms ║║Cancelling condition #2’s schedules…
+104ms ║║Condition #2 evaluated false (68ms)
+106ms ║║Cancelling condition #1’s schedules…
+107ms ║║Condition group #1 evaluated false (state changed) (71ms)
+112ms ║║Condition #6 evaluated false (3ms)
+114ms ║║Condition group #5 evaluated false (state did not change) (4ms)
+120ms ║║Comparison (enum) present is (string) present = true (2ms)
+122ms ║║Condition #8 evaluated true (5ms)
+127ms ║║Comparison (enum) inactive is (string) active = false (1ms)
+128ms ║║Cancelling condition #10’s schedules…
+130ms ║║Condition #10 evaluated false (7ms)
+134ms ║║Comparison (enum) present is (string) present = true (2ms)
+136ms ║║Condition #11 evaluated true (5ms)
+137ms ║║Condition group #9 evaluated true (state did not change) (14ms)
+138ms ║║Condition group #7 evaluated true (state did not change) (22ms)
+149ms ║║Comparison (time) 60412000 is_between (time) 24720000 … (time) 82800000 = true (8ms)
+150ms ║║Time restriction check passed
+152ms ║║Condition #13 evaluated true (12ms)
+153ms ║║Condition group #12 evaluated true (state did not change) (13ms)
+154ms ║║Cancelling statement #14’s schedules…
+159ms ║║Skipped execution of physical command [Light - Office Recessed].on([]) because it would make no change to the device. (1ms)
+159ms ║║Executed [Light - Office Recessed].on (3ms)
+165ms ║║Skipped execution of physical command [Light - Office Recessed].setLevel([30]) because it would make no change to the device. (1ms)
+166ms ║║Executed [Light - Office Recessed].setLevel (2ms)
+167ms ║║Cancelling statement #17’s schedules…
+175ms ║║Skipped execution of physical command [Light - BenQ Desk Light].on([]) because it would make no change to the device. (4ms)
+176ms ║║Executed [Light - BenQ Desk Light].on (6ms)
+178ms ║║Cancelling statement #19’s schedules…
+184ms ║║Skipped execution of physical command [Light - Office Floor Lamp].setLevel([70]) because it would make no change to the device. (1ms)
+185ms ║║Executed [Light - Office Floor Lamp].setLevel (2ms)
+208ms ║║Executed physical command [Light - Office Floor Lamp].setColorTemperature(2800) (18ms)
+209ms ║║Executed [Light - Office Floor Lamp].setColorTemperature (19ms)
+218ms ║║Comparison (string) false is (boolean) true = false (1ms)
+219ms ║║Cancelling condition #23’s schedules…
+220ms ║║Condition #23 evaluated false (8ms)
+221ms ║║Condition group #22 evaluated false (state did not change) (9ms)
+225ms ║╚Execution stage complete. (192ms)
+227ms ╚Event processed successfully (226ms)
1/3/2022, 4:46:22 PM +936ms
+2ms ╔Received event [Motion - Office].motion = active with a delay of 37ms, canQueue: true, calledMyself: false
+121ms ║Device missing from piston. Loading all from parent (49ms)
+127ms ║RunTime initialize > 126 LockT > 1ms > rtDT > 102ms > pistonT > 101ms (first state access 23 3 123)
+130ms ║Runtime (12854 bytes) successfully initialized in 102ms (v0.3.113.20211120_HE)
+136ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+138ms ║║Cancelling condition #2’s schedules…
+139ms ║║Condition #2 evaluated true (5ms)
+140ms ║║Cancelling condition #1’s schedules…
+141ms ║║Condition group #1 evaluated true (state changed) (8ms)
+143ms ║║Cancelling statement #3’s schedules…
+147ms ║║Executed virtual command setVariable (1ms)
+151ms ║║Condition #6 evaluated false (2ms)
+152ms ║║Condition group #5 evaluated false (state did not change) (3ms)
+157ms ║║Comparison (enum) present is (string) present = true (1ms)
+159ms ║║Condition #8 evaluated true (4ms)
+163ms ║║Comparison (enum) active is (string) active = true (0ms)
+164ms ║║Cancelling condition #10’s schedules…
+165ms ║║Condition #10 evaluated true (6ms)
+167ms ║║Condition group #9 evaluated true (state did not change) (7ms)
+168ms ║║Condition group #7 evaluated true (state did not change) (14ms)
+179ms ║║Comparison (time) 60383000 is_between (time) 24720000 … (time) 82800000 = true (8ms)
+180ms ║║Time restriction check passed
+182ms ║║Condition #13 evaluated true (12ms)
+183ms ║║Condition group #12 evaluated true (state did not change) (14ms)
+184ms ║║Cancelling statement #14’s schedules…
+201ms ║║Executed physical command [Light - Office Recessed].on() (13ms)
+202ms ║║Executed [Light - Office Recessed].on (15ms)
+217ms ║║Executed physical command [Light - Office Recessed].setLevel(30) (10ms)
+218ms ║║Executed [Light - Office Recessed].setLevel (12ms)
+220ms ║║Cancelling statement #17’s schedules…
+235ms ║║Executed physical command [Light - BenQ Desk Light].on() (11ms)
+236ms ║║Executed [Light - BenQ Desk Light].on (13ms)
+238ms ║║Cancelling statement #19’s schedules…
+262ms ║║Executed physical command [Light - Office Floor Lamp].setLevel(70) (20ms)
+263ms ║║Executed [Light - Office Floor Lamp].setLevel (21ms)
+288ms ║║Executed physical command [Light - Office Floor Lamp].setColorTemperature(2800) (18ms)
+289ms ║║Executed [Light - Office Floor Lamp].setColorTemperature (20ms)
+298ms ║║Comparison (string) true is (boolean) true = true (2ms)
+299ms ║║Cancelling condition #23’s schedules…
+300ms ║║Condition #23 evaluated true (7ms)
+305ms ║║Comparison (enum) active is (string) inactive = false (2ms)
+307ms ║║Cancelling condition #24’s schedules…
+309ms ║║Condition #24 evaluated false (7ms)
+310ms ║║Condition group #22 evaluated false (state did not change) (17ms)
+316ms ║╚Execution stage complete. (185ms)
+319ms ╚Event processed successfully (318ms)Clear
Full
Lights not turning off after motion sensor inactivity period
Automate85
Automate85
Thanks, I tried something similar (without a variable) and here’s the problem I had (and have with your example): The lights do go on with motion, and turn off with inactivity. However, if I immediately re-trigger motion then it’s very hit and miss if the first async lights (ceiling lights) turn back on. The second and third set of lights always come on when re-triggered. If I wait about 5 seconds to re-trigger after they turn off, all lights DO come on. Ideas?
Automate85
