I have a piston that changes the location mode, this seems to execute fine. I have another piston that turns the lights on or off depending upon time and/or location mode change.
Up until a week ago this was working absolutely fine, but now, it is turning the lights on, but failing to turn them off when the location changes to ‘home-asleep’
Lights should turn on at sunset or if location mode changes (if its after sunset, smart home monitor is disarmed and location mode is not ‘home - asleep’.
the lights should turn off if the location mode changes to ‘home - asleep’
The lights are turning on as expected at sunset. But they are not then turning off later qhen location mode changes to ‘home asleep’
**4) Post a Green Snapshot of
Logs
10/12/2020, 11:38:56 +566ms
+1ms ╔Received event [Home].test = 1607600336565 with a delay of 0ms
+106ms ║RunTime Analysis CS > 20ms > PS > 25ms > PE > 61ms > CE
+109ms ║Runtime (40319 bytes) successfully initialized in 25ms (v0.3.110.20191009) (106ms)
+110ms ║╔Execution stage started
+146ms ║║Comparison (time) 41936682 happens_daily_at (time) 1607615520000 = false (1ms)
+148ms ║║Condition #2 evaluated false (32ms)
+152ms ║║Cancelling statement #2’s schedules…
+157ms ║║Requesting time schedule wake up at Thu, Dec 10 2020 @ 3:52:00 PM GMT
+165ms ║║Comparison (string) :47b910cec7fb65a8cb1c73fcc2a47035: changes = false (0ms)
+166ms ║║Condition #3 evaluated false (4ms)
+168ms ║║Condition group #1 evaluated false (state did not change) (51ms)
+173ms ║║Comparison (string) :47b910cec7fb65a8cb1c73fcc2a47035: changes_to (string) :d992162b789465b09555a1194e12a166: = false (1ms)
+176ms ║║Condition #13 evaluated false (5ms)
+178ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+198ms ║╚Execution stage complete. (88ms)
+203ms ║Setting up scheduled job for Thu, Dec 10 2020 @ 3:52:00 PM GMT (in 15183.232s)
+217ms ╚Event processed successfully (216ms)
10/12/2020, 09:14:26 +969ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+302ms ║╔Subscribing to devices…
+338ms ║║Subscribing to Home.mode…
+418ms ║║Subscribing to Living Room Lamp…
+419ms ║║Subscribing to Office lamp…
+420ms ║║Subscribing to Conservatory left - white…
+421ms ║║Subscribing to Conservatory right - white…
