Lights are dimming as expected when the lux level register. I have them setup to wait 30 minutes after the initial lux register to dim down over a period of time. That too happened. but after that 30 minutes, the creeped back up to the initial dim level.
I want the lights to dim hwen the sensor register the lux level i set. I want the piston to wait 30 minutes then slowly dim the light down and stay at that level.
The lights come on, then dim down to the level I set after the waiting period. They don’t stay there, the creep back up.
Apologies, the long is terribly long…
|5/10/2020, 8:05:54 PM +255ms|
|+1ms|╔Received event [My home].time = 1589155554977 with a delay of -722ms|
|+111ms|║RunTime Analysis CS > 70ms > PS > 7ms > PE > 34ms > CE|
|+114ms|║Runtime (38847 bytes) successfully initialized in 7ms (v0.3.110.20191009) (113ms)|
|+115ms|║╔Execution stage started|
|+121ms|║║Cancelling condition #14's schedules...|
|+122ms|║║Condition #14 evaluated true (1ms)|
|+182ms|║║Comparison (time) 72354379 is_between (time) 1589156700000 .. (time) 1589156700000 = true (11ms)|
|+183ms|║║Time restriction check passed|
|+185ms|║║Condition #15 evaluated true (62ms)|
|+186ms|║║Cancelling condition #1's schedules...|
|+187ms|║║Condition group #1 evaluated true (state changed) (67ms)|
|+189ms|║║Cancelling statement #7's schedules...|
|+210ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (11ms)|
|+211ms|║║Executed virtual command [Living Room Pot Lights 1].fadeLevel (16ms)|
|+228ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (11ms)|
|+229ms|║║Executed virtual command [Living Room Pot Lights 2].fadeLevel (16ms)|
|+234ms|║║Executed virtual command [Living Room Pot Lights 1, Living Room Pot Lights 2].wait (1ms)|
|+236ms|║║Requesting a wake up for Sun, May 10 2020 @ 8:35:54 PM EDT (in 1800.0s)|
|+242ms|║╚Execution stage complete. (128ms)|
|+244ms|║Setting up scheduled job for Sun, May 10 2020 @ 8:35:54 PM EDT (in 1799.994s)|
|+252ms|╚Event processed successfully (251ms)|
|5/10/2020, 8:03:32 PM +194ms|
|+1ms|╔Received event [My home].time = 1589155412453 with a delay of -259ms|
|+48ms|║RunTime Analysis CS > 15ms > PS > 4ms > PE > 29ms > CE|
|+50ms|║Runtime (38846 bytes) successfully initialized in 4ms (v0.3.110.20191009) (49ms)|
|+51ms|║╔Execution stage started|
|+61ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (6ms)|
|+63ms|║║Fast executing schedules, waiting for 213ms to sync up|
|+284ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (5ms)|
|+285ms|║║Fast executing schedules, waiting for 73ms to sync up|
|+365ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (4ms)|
|+367ms|║║Fast executing schedules, waiting for 8ms to sync up|
|+381ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (3ms)|
|+393ms|║║Executed virtual command [Living Room Pot Lights 1, Living Room Pot Lights 2].wait (0ms)|
|+394ms|║║Requesting a wake up for Sun, May 10 2020 @ 8:33:32 PM EDT (in 1800.0s)|
|+398ms|║╚Execution stage complete. (346ms)|
|+399ms|║Setting up scheduled job for Sun, May 10 2020 @ 8:05:54 PM EDT (in 142.385s), with 1 more job pending|
|+408ms|╚Event processed successfully (407ms)|
|5/10/2020, 8:00:15 PM +957ms|
|+0ms|╔Received event [My home].time = 1589155212452 with a delay of 3504ms|
|+196ms|║RunTime Analysis CS > 120ms > PS > 8ms > PE > 69ms > CE|
|+200ms|║Runtime (38848 bytes) successfully initialized in 8ms (v0.3.110.20191009) (198ms)|
|+201ms|║╔Execution stage started|
|+223ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([9]) (15ms)|
|+240ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([9]) (12ms)|
|+242ms|║╚Execution stage complete. (42ms)|
|+245ms|║Setting up scheduled job for Sun, May 10 2020 @ 8:03:32 PM EDT (in 196.252s), with 5 more jobs pending|
|+252ms|╚Event processed successfully (252ms)|
|5/10/2020, 7:59:54 PM +900ms|
|+1ms|╔Received event [Living Room Sensor].illuminance = 1 with a delay of 375ms|
|+55ms|║RunTime Analysis CS > 17ms > PS > 5ms > PE > 32ms > CE|
|+57ms|║Runtime (38849 bytes) successfully initialized in 5ms (v0.3.110.20191009) (56ms)|
|+58ms|║╔Execution stage started|
|+68ms|║║Comparison (enum) present is (string) present = true (1ms)|
|+70ms|║║Condition #13 evaluated true (8ms)|
|+75ms|║║Comparison (integer) 1 stays_less_than (integer) 25 = true (1ms)|
|+77ms|║║Adding a timed trigger schedule for condition 14|
|+79ms|║║Cancelling condition #14's schedules...|
|+80ms|║║Condition #14 evaluated false (9ms)|
|+81ms|║║Cancelling condition #1's schedules...|
|+82ms|║║Condition group #1 evaluated false (state changed) (19ms)|
|+86ms|║╚Execution stage complete. (28ms)|
|+89ms|║Setting up scheduled job for Sun, May 10 2020 @ 8:00:12 PM EDT (in 17.464s), with 7 more jobs pending|
|+101ms|╚Event processed successfully (101ms)|
|5/10/2020, 7:56:51 PM +189ms|
|+1ms|╔Received event [My home].time = 1589155012452 with a delay of -1263ms|
|+94ms|║RunTime Analysis CS > 55ms > PS > 6ms > PE > 33ms > CE|
|+97ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (94ms)|
|+98ms|║╔Execution stage started|
|+115ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([8]) (13ms)|
|+118ms|║║Fast executing schedules, waiting for 1163ms to sync up|
|+1296ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([8]) (12ms)|
|+1298ms|║╚Execution stage complete. (1201ms)|
|+1301ms|║Setting up scheduled job for Sun, May 10 2020 @ 8:00:12 PM EDT (in 199.963s), with 6 more jobs pending|
|+1309ms|╚Event processed successfully (1309ms)|
|5/10/2020, 7:53:32 PM +229ms|
|+1ms|╔Received event [My home].time = 1589154812677 with a delay of -448ms|
|+88ms|║RunTime Analysis CS > 48ms > PS > 6ms > PE > 33ms > CE|
|+90ms|║Runtime (38846 bytes) successfully initialized in 6ms (v0.3.110.20191009) (88ms)|
|+91ms|║╔Execution stage started|
|+99ms|║║Cancelling condition #14's schedules...|
|+100ms|║║Condition #14 evaluated true (1ms)|
|+195ms|║║Comparison (time) 71612330 is_between (time) 1589156700000 .. (time) 1589156700000 = true (9ms)|
|+196ms|║║Time restriction check passed|
|+198ms|║║Condition #15 evaluated true (97ms)|
|+199ms|║║Cancelling condition #1's schedules...|
|+200ms|║║Condition group #1 evaluated true (state changed) (103ms)|
|+202ms|║║Cancelling statement #7's schedules...|
|+222ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([7]) (11ms)|
|+224ms|║║Executed virtual command [Living Room Pot Lights 1].fadeLevel (16ms)|
|+239ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([7]) (10ms)|
|+241ms|║║Executed virtual command [Living Room Pot Lights 2].fadeLevel (15ms)|
|+242ms|║║Requesting a wake up for Sun, May 10 2020 @ 8:03:32 PM EDT (in 600.1s)|
|+250ms|║╚Execution stage complete. (159ms)|
|+253ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:56:52 PM EDT (in 199.97s), with 8 more jobs pending|
|+266ms|╚Event processed successfully (265ms)|
|5/10/2020, 7:52:47 PM +103ms|
|+0ms|╔Received event [My home].time = 1589154767103 with a delay of -1ms|
|+77ms|║RunTime Analysis CS > 37ms > PS > 5ms > PE > 35ms > CE|
|+81ms|║Runtime (38844 bytes) successfully initialized in 5ms (v0.3.110.20191009) (79ms)|
|+82ms|║╔Execution stage started|
|+97ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([7]) (7ms)|
|+110ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([7]) (6ms)|
|+114ms|║╚Execution stage complete. (31ms)|
|+118ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:53:32 PM EDT (in 45.457s), with 9 more jobs pending|
|+142ms|╚Event processed successfully (142ms)|
|5/10/2020, 7:51:23 PM +921ms|
|+0ms|╔Received event [My home].time = 1589154681389 with a delay of 2532ms|
|+48ms|║RunTime Analysis CS > 15ms > PS > 5ms > PE > 27ms > CE|
|+50ms|║Runtime (38846 bytes) successfully initialized in 5ms (v0.3.110.20191009) (49ms)|
|+63ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([6]) (6ms)|
|+74ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([6]) (6ms)|
|+77ms|║╚Execution stage complete. (26ms)|
|+81ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:52:47 PM EDT (in 83.101s), with 11 more jobs pending|
|+126ms|╚Event processed successfully (126ms)|
|5/10/2020, 7:49:55 PM +131ms|
|+0ms|╔Received event [My home].time = 1589154595675 with a delay of -545ms|
|+80ms|║RunTime Analysis CS > 51ms > PS > 3ms > PE > 26ms > CE|
|+82ms|║Runtime (38846 bytes) successfully initialized in 3ms (v0.3.110.20191009) (81ms)|
|+83ms|║╔Execution stage started|
|+95ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([5]) (7ms)|
|+99ms|║║Fast executing schedules, waiting for 465ms to sync up|
|+573ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([5]) (6ms)|
|+577ms|║╚Execution stage complete. (494ms)|
|+581ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:51:21 PM EDT (in 85.678s), with 13 more jobs pending|
|+589ms|╚Event processed successfully (588ms)|
|5/10/2020, 7:48:29 PM +101ms|
|+1ms|╔Received event [My home].time = 1589154509960 with a delay of -859ms|
|+88ms|║RunTime Analysis CS > 40ms > PS > 9ms > PE > 38ms > CE|
|+91ms|║Runtime (38846 bytes) successfully initialized in 9ms (v0.3.110.20191009) (89ms)|
|+93ms|║╔Execution stage started|
|+116ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([4]) (12ms)|
|+120ms|║║Fast executing schedules, waiting for 758ms to sync up|
|+895ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([4]) (13ms)|
|+899ms|║╚Execution stage complete. (807ms)|
|+904ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:49:55 PM EDT (in 85.671s), with 15 more jobs pending|
|+971ms|╚Event processed successfully (970ms)|
|5/10/2020, 7:47:32 PM +591ms|
|+2ms|╔Received event [Living Room Sensor].illuminance = 0 with a delay of 145ms|
|+63ms|║RunTime Analysis CS > 22ms > PS > 5ms > PE > 35ms > CE|
|+65ms|║Runtime (38849 bytes) successfully initialized in 5ms (v0.3.110.20191009) (62ms)|
|+66ms|║╔Execution stage started|
|+77ms|║║Comparison (enum) present is (string) present = true (1ms)|
|+78ms|║║Condition #13 evaluated true (8ms)|
|+82ms|║║Comparison (integer) 0 stays_less_than (integer) 25 = true (1ms)|
|+85ms|║║Adding a timed trigger schedule for condition 14|
|+88ms|║║Cancelling condition #14's schedules...|
|+88ms|║║Condition #14 evaluated false (9ms)|
|+89ms|║║Cancelling condition #1's schedules...|
|+90ms|║║Condition group #1 evaluated false (state changed) (20ms)|
|+99ms|║╚Execution stage complete. (33ms)|
|+103ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:48:29 PM EDT (in 57.266s), with 17 more jobs pending|
|+114ms|╚Event processed successfully (114ms)|
|5/10/2020, 7:47:04 PM +103ms|
|+0ms|╔Received event [My home].time = 1589154425242 with a delay of -1139ms|
|+63ms|║RunTime Analysis CS > 21ms > PS > 7ms > PE > 35ms > CE|
|+66ms|║Runtime (38847 bytes) successfully initialized in 7ms (v0.3.110.20191009) (64ms)|
|+73ms|║║Cancelling condition #14's schedules...|
|+74ms|║║Condition #14 evaluated true (1ms)|
|+112ms|║║Comparison (time) 71224178 is_between (time) 1589156700000 .. (time) 1589156700000 = true (9ms)|
|+114ms|║║Time restriction check passed|
|+115ms|║║Condition #15 evaluated true (40ms)|
|+116ms|║║Cancelling condition #1's schedules...|
|+117ms|║║Condition group #1 evaluated true (state changed) (46ms)|
|+120ms|║║Cancelling statement #7's schedules...|
|+140ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([3]) (11ms)|
|+146ms|║║Executed virtual command [Living Room Pot Lights 1].fadeLevel (20ms)|
|+162ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([3]) (10ms)|
|+165ms|║║Executed virtual command [Living Room Pot Lights 2].fadeLevel (17ms)|
|+166ms|║║Requesting a wake up for Sun, May 10 2020 @ 7:57:04 PM EDT (in 600.1s)|
|+176ms|║╚Execution stage complete. (110ms)|
|+181ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:48:29 PM EDT (in 85.677s), with 16 more jobs pending|
|+189ms|╚Event processed successfully (189ms)|
|5/10/2020, 7:41:05 PM +140ms|
|+1ms|╔Received event [Living Room Sensor].illuminance = 0 with a delay of 123ms|
|+51ms|║RunTime Analysis CS > 21ms > PS > 4ms > PE > 26ms > CE|
|+53ms|║Runtime (38849 bytes) successfully initialized in 4ms (v0.3.110.20191009) (52ms)|
|+54ms|║╔Execution stage started|
|+94ms|║║Comparison (enum) present is (string) present = true (2ms)|
|+95ms|║║Condition #13 evaluated true (37ms)|
|+99ms|║║Comparison (integer) 0 stays_less_than (integer) 25 = true (1ms)|
|+101ms|║║Adding a timed trigger schedule for condition 14|
|+103ms|║║Cancelling condition #14's schedules...|
|+104ms|║║Condition #14 evaluated false (8ms)|
|+105ms|║║Cancelling condition #1's schedules...|
|+105ms|║║Condition group #1 evaluated false (state changed) (48ms)|
|+107ms|║╚Execution stage complete. (53ms)|
|+108ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:47:05 PM EDT (in 359.994s)|
|+116ms|╚Event processed successfully (115ms)|
|5/10/2020, 7:37:00 PM +145ms|
|+1ms|╔Received event [My home].time = 1589153821146 with a delay of -1001ms|
|+62ms|║RunTime Analysis CS > 23ms > PS > 6ms > PE > 33ms > CE|
|+64ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (63ms)|
|+65ms|║╔Execution stage started|
|+81ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([3]) (11ms)|
|+82ms|║║Fast executing schedules, waiting for 935ms to sync up|
|+1032ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([3]) (12ms)|
|+1034ms|║║Fast executing schedules, waiting for 68ms to sync up|
|+1113ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([3]) (8ms)|
|+1115ms|║║Fast executing schedules, waiting for 4ms to sync up|
|+1129ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([3]) (7ms)|
|+1140ms|║╚Execution stage complete. (1075ms)|
|+1141ms|╚Event processed successfully (1141ms)|
|5/10/2020, 7:35:37 PM +465ms|
|+1ms|╔Received event [My home].time = 1589153735432 with a delay of 2032ms|
|+98ms|║RunTime Analysis CS > 55ms > PS > 8ms > PE > 36ms > CE|
|+101ms|║Runtime (38844 bytes) successfully initialized in 8ms (v0.3.110.20191009) (99ms)|
|+103ms|║╔Execution stage started|
|+124ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([4]) (12ms)|
|+142ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([4]) (11ms)|
|+146ms|║╚Execution stage complete. (44ms)|
|+150ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:37:01 PM EDT (in 83.532s), with 4 more jobs pending|
|+159ms|╚Event processed successfully (159ms)|
|5/10/2020, 7:34:09 PM +939ms|
|+1ms|╔Received event [My home].time = 1589153649718 with a delay of 221ms|
|+66ms|║RunTime Analysis CS > 28ms > PS > 7ms > PE > 31ms > CE|
|+68ms|║Runtime (38843 bytes) successfully initialized in 7ms (v0.3.110.20191009) (67ms)|
|+69ms|║╔Execution stage started|
|+90ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([5]) (16ms)|
|+105ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([5]) (11ms)|
|+108ms|║╚Execution stage complete. (39ms)|
|+111ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:35:35 PM EDT (in 85.383s), with 6 more jobs pending|
|+127ms|╚Event processed successfully (127ms)|
|5/10/2020, 7:32:43 PM +141ms|
|+1ms|╔Received event [My home].time = 1589153564004 with a delay of -863ms|
|+87ms|║RunTime Analysis CS > 53ms > PS > 6ms > PE > 28ms > CE|
|+89ms|║Runtime (38844 bytes) successfully initialized in 6ms (v0.3.110.20191009) (88ms)|
|+90ms|║╔Execution stage started|
|+109ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([6]) (12ms)|
|+111ms|║║Fast executing schedules, waiting for 767ms to sync up|
|+893ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([6]) (11ms)|
|+897ms|║╚Execution stage complete. (806ms)|
|+901ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:34:09 PM EDT (in 85.677s), with 8 more jobs pending|
|+915ms|╚Event processed successfully (915ms)|
|5/10/2020, 7:31:17 PM +259ms|
|+0ms|╔Received event [My home].time = 1589153478289 with a delay of -1030ms|
|+58ms|║RunTime Analysis CS > 31ms > PS > 4ms > PE > 23ms > CE|
|+60ms|║Runtime (38845 bytes) successfully initialized in 4ms (v0.3.110.20191009) (59ms)|
|+61ms|║╔Execution stage started|
|+72ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([7]) (6ms)|
|+75ms|║║Fast executing schedules, waiting for 972ms to sync up|
|+1056ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([7]) (6ms)|
|+1060ms|║╚Execution stage complete. (999ms)|
|+1063ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:32:44 PM EDT (in 85.682s), with 10 more jobs pending|
|+1076ms|╚Event processed successfully (1076ms)|
|5/10/2020, 7:29:51 PM +111ms|
|+0ms|╔Received event [My home].time = 1589153392575 with a delay of -1465ms|
|+65ms|║RunTime Analysis CS > 34ms > PS > 6ms > PE > 25ms > CE|
|+67ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (65ms)|
|+85ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([8]) (9ms)|
|+90ms|║║Fast executing schedules, waiting for 1391ms to sync up|
|+1492ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([8]) (6ms)|
|+1495ms|║╚Execution stage complete. (1427ms)|
|+1499ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:31:18 PM EDT (in 85.68s), with 12 more jobs pending|
|+1510ms|╚Event processed successfully (1510ms)|
|5/10/2020, 7:28:26 PM +197ms|
|+1ms|╔Received event [My home].time = 1589153306861 with a delay of -664ms|
|+72ms|║RunTime Analysis CS > 32ms > PS > 7ms > PE > 32ms > CE|
|+74ms|║Runtime (38844 bytes) successfully initialized in 7ms (v0.3.110.20191009) (72ms)|
|+75ms|║╔Execution stage started|
|+93ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([9]) (12ms)|
|+96ms|║║Fast executing schedules, waiting for 583ms to sync up|
|+694ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([9]) (11ms)|
|+699ms|║╚Execution stage complete. (624ms)|
|+704ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:29:52 PM EDT (in 85.675s), with 14 more jobs pending|
|+713ms|╚Event processed successfully (713ms)|
|5/10/2020, 7:27:01 PM +64ms|
|+0ms|╔Received event [My home].time = 1589153222345 with a delay of -1281ms|
|+48ms|║RunTime Analysis CS > 18ms > PS > 6ms > PE > 24ms > CE|
|+51ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (49ms)|
|+79ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (10ms)|
|+85ms|║║Executed virtual command [Living Room Pot Lights 1].fadeLevel (20ms)|
|+98ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (8ms)|
|+100ms|║║Executed virtual command [Living Room Pot Lights 2].fadeLevel (14ms)|
|+101ms|║║Requesting a wake up for Sun, May 10 2020 @ 7:37:01 PM EDT (in 600.1s)|
|+112ms|║╚Execution stage complete. (61ms)|
|+116ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:28:26 PM EDT (in 85.681s), with 16 more jobs pending|
|5/10/2020, 6:57:01 PM +58ms|
|+1ms|╔Received event [My home].time = 1589151422202 with a delay of -1144ms|
|+48ms|║RunTime Analysis CS > 18ms > PS > 5ms > PE > 24ms > CE|
|+50ms|║Runtime (38846 bytes) successfully initialized in 5ms (v0.3.110.20191009) (48ms)|
|+66ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (10ms)|
|+67ms|║║Fast executing schedules, waiting for 1096ms to sync up|
|+1176ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (10ms)|
|+1178ms|║║Fast executing schedules, waiting for 66ms to sync up|
|+1253ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([10]) (6ms)|
|+1254ms|║║Fast executing schedules, waiting for 10ms to sync up|
|+1273ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([10]) (6ms)|
|+1285ms|║║Executed virtual command [Living Room Pot Lights 1, Living Room Pot Lights 2].wait (1ms)|
|+1286ms|║║Requesting a wake up for Sun, May 10 2020 @ 7:27:02 PM EDT (in 1800.0s)|
|+1290ms|║╚Execution stage complete. (1239ms)|
|+1291ms|║Setting up scheduled job for Sun, May 10 2020 @ 7:27:02 PM EDT (in 1799.996s)|
|+1299ms|╚Event processed successfully (1299ms)|
|5/10/2020, 6:56:26 PM +162ms|
|+1ms|╔Received event [My home].time = 1589151386927 with a delay of -765ms|
|+75ms|║RunTime Analysis CS > 41ms > PS > 5ms > PE > 29ms > CE|
|+78ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (74ms)|
|+79ms|║╔Execution stage started|
|+95ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([11]) (12ms)|
|+97ms|║╚Execution stage complete. (19ms)|
|+99ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:57:02 PM EDT (in 35.942s), with 4 more jobs pending|
|+108ms|╚Event processed successfully (108ms)|
|5/10/2020, 6:55:51 PM +155ms|
|+0ms|╔Received event [My home].time = 1589151351632 with a delay of -478ms|
|+64ms|║RunTime Analysis CS > 37ms > PS > 5ms > PE > 23ms > CE|
|+67ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (65ms)|
|+67ms|║╔Execution stage started|
|+83ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([12]) (12ms)|
|+85ms|║╚Execution stage complete. (18ms)|
|+88ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:56:26 PM EDT (in 35.685s), with 5 more jobs pending|
|+95ms|╚Event processed successfully (96ms)|
|5/10/2020, 6:55:46 PM +223ms|
|+0ms|╔Received event [My home].time = 1589151347202 with a delay of -980ms|
|+51ms|║RunTime Analysis CS > 22ms > PS > 7ms > PE > 23ms > CE|
|+54ms|║Runtime (38845 bytes) successfully initialized in 7ms (v0.3.110.20191009) (51ms)|
|+55ms|║╔Execution stage started|
|+69ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([9]) (10ms)|
|+71ms|║╚Execution stage complete. (17ms)|
|+74ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:55:51 PM EDT (in 5.336s), with 6 more jobs pending|
|+84ms|╚Event processed successfully (84ms)|
|5/10/2020, 6:55:16 PM +212ms|
|+0ms|╔Received event [My home].time = 1589151316338 with a delay of -127ms|
|+63ms|║RunTime Analysis CS > 32ms > PS > 7ms > PE > 24ms > CE|
|+65ms|║Runtime (38845 bytes) successfully initialized in 7ms (v0.3.110.20191009) (64ms)|
|+86ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([13]) (12ms)|
|+89ms|║╚Execution stage complete. (23ms)|
|+92ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:55:47 PM EDT (in 30.899s), with 7 more jobs pending|
|+100ms|╚Event processed successfully (100ms)|
|5/10/2020, 6:54:40 PM +107ms|
|+0ms|╔Received event [My home].time = 1589151281044 with a delay of -938ms|
|+72ms|║RunTime Analysis CS > 42ms > PS > 6ms > PE > 24ms > CE|
|+74ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (73ms)|
|+93ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([14]) (13ms)|
|+96ms|║╚Execution stage complete. (21ms)|
|+100ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:55:16 PM EDT (in 36.132s), with 8 more jobs pending|
|+112ms|╚Event processed successfully (112ms)|
|5/10/2020, 6:54:31 PM +101ms|
|+0ms|╔Received event [My home].time = 1589151272202 with a delay of -1101ms|
|+45ms|║RunTime Analysis CS > 19ms > PS > 5ms > PE > 21ms > CE|
|+47ms|║Runtime (38846 bytes) successfully initialized in 5ms (v0.3.110.20191009) (46ms)|
|+48ms|║╔Execution stage started|
|+58ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([8]) (6ms)|
|+60ms|║╚Execution stage complete. (12ms)|
|+63ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:54:41 PM EDT (in 9.88s), with 9 more jobs pending|
|+71ms|╚Event processed successfully (71ms)|
|5/10/2020, 6:54:05 PM +170ms|
|+1ms|╔Received event [My home].time = 1589151245750 with a delay of -580ms|
|+43ms|║RunTime Analysis CS > 17ms > PS > 5ms > PE > 21ms > CE|
|+45ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (43ms)|
|+46ms|║╔Execution stage started|
|+59ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([15]) (8ms)|
|+62ms|║╚Execution stage complete. (16ms)|
|+66ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:54:32 PM EDT (in 26.967s), with 10 more jobs pending|
|+75ms|╚Event processed successfully (75ms)|
|5/10/2020, 6:53:31 PM +273ms|
|+1ms|╔Received event [My home].time = 1589151210455 with a delay of 818ms|
|+54ms|║RunTime Analysis CS > 21ms > PS > 6ms > PE > 27ms > CE|
|+57ms|║Runtime (38844 bytes) successfully initialized in 6ms (v0.3.110.20191009) (55ms)|
|+59ms|║╔Execution stage started|
|+81ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([16]) (14ms)|
|+87ms|║╚Execution stage complete. (29ms)|
|+94ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:54:05 PM EDT (in 34.385s), with 11 more jobs pending|
|+102ms|╚Event processed successfully (102ms)|
|5/10/2020, 6:53:16 PM +191ms|
|+1ms|╔Received event [My home].time = 1589151197201 with a delay of -1010ms|
|+178ms|║RunTime Analysis CS > 25ms > PS > 128ms > PE > 25ms > CE|
|+180ms|║Runtime (38851 bytes) successfully initialized in 128ms (v0.3.110.20191009) (179ms)|
|+181ms|║╔Execution stage started|
|+201ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([7]) (14ms)|
|+205ms|║╚Execution stage complete. (24ms)|
|+210ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:53:30 PM EDT (in 14.055s), with 12 more jobs pending|
|+217ms|╚Event processed successfully (217ms)|
|5/10/2020, 6:52:56 PM +853ms|
|+0ms|╔Received event [My home].time = 1589151175161 with a delay of 1692ms|
|+38ms|║RunTime Analysis CS > 15ms > PS > 5ms > PE > 17ms > CE|
|+40ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (39ms)|
|+41ms|║╔Execution stage started|
|+53ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([17]) (7ms)|
|+56ms|║╚Execution stage complete. (16ms)|
|+60ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:53:17 PM EDT (in 20.289s), with 13 more jobs pending|
|+68ms|╚Event processed successfully (68ms)|
|5/10/2020, 6:52:19 PM +116ms|
|+1ms|╔Received event [My home].time = 1589151139867 with a delay of -752ms|
|+84ms|║RunTime Analysis CS > 52ms > PS > 8ms > PE > 25ms > CE|
|+87ms|║Runtime (38845 bytes) successfully initialized in 8ms (v0.3.110.20191009) (83ms)|
|+88ms|║╔Execution stage started|
|+112ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([18]) (16ms)|
|+118ms|║╚Execution stage complete. (31ms)|
|+123ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:52:55 PM EDT (in 35.923s), with 14 more jobs pending|
|+132ms|╚Event processed successfully (131ms)|
|5/10/2020, 6:52:01 PM +63ms|
|+1ms|╔Received event [My home].time = 1589151122201 with a delay of -1138ms|
|+54ms|║RunTime Analysis CS > 25ms > PS > 7ms > PE > 22ms > CE|
|+57ms|║Runtime (38846 bytes) successfully initialized in 7ms (v0.3.110.20191009) (55ms)|
|+75ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([6]) (12ms)|
|+79ms|║╚Execution stage complete. (22ms)|
|+84ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:52:19 PM EDT (in 18.721s), with 15 more jobs pending|
|+94ms|╚Event processed successfully (94ms)|
|5/10/2020, 6:51:44 PM +122ms|
|+0ms|╔Received event [My home].time = 1589151104573 with a delay of -452ms|
|+63ms|║RunTime Analysis CS > 41ms > PS > 5ms > PE > 18ms > CE|
|+65ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (64ms)|
|+81ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([19]) (9ms)|
|+85ms|║╚Execution stage complete. (19ms)|
|+90ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:52:02 PM EDT (in 17.99s), with 16 more jobs pending|
|+98ms|╚Event processed successfully (98ms)|
|5/10/2020, 6:51:08 PM +78ms|
|+0ms|╔Received event [My home].time = 1589151069278 with a delay of -1200ms|
|+62ms|║RunTime Analysis CS > 30ms > PS > 6ms > PE > 26ms > CE|
|+65ms|║Runtime (38846 bytes) successfully initialized in 6ms (v0.3.110.20191009) (64ms)|
|+83ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([20]) (10ms)|
|+88ms|║╚Execution stage complete. (23ms)|
|+93ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:51:44 PM EDT (in 36.402s), with 17 more jobs pending|
|+100ms|╚Event processed successfully (99ms)|
|5/10/2020, 6:50:47 PM +221ms|
|+1ms|╔Received event [My home].time = 1589151047201 with a delay of 19ms|
|+62ms|║RunTime Analysis CS > 29ms > PS > 8ms > PE > 26ms > CE|
|+65ms|║Runtime (38843 bytes) successfully initialized in 8ms (v0.3.110.20191009) (63ms)|
|+88ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([5]) (12ms)|
|+94ms|║╚Execution stage complete. (28ms)|
|+100ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:51:09 PM EDT (in 21.958s), with 18 more jobs pending|
|+107ms|╚Event processed successfully (107ms)|
|5/10/2020, 6:50:33 PM +94ms|
|+0ms|╔Received event [My home].time = 1589151033984 with a delay of -891ms|
|+40ms|║RunTime Analysis CS > 19ms > PS > 4ms > PE > 18ms > CE|
|+42ms|║Runtime (38845 bytes) successfully initialized in 4ms (v0.3.110.20191009) (41ms)|
|+43ms|║╔Execution stage started|
|+55ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([21]) (6ms)|
|+60ms|║╚Execution stage complete. (17ms)|
|+65ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:50:47 PM EDT (in 14.042s), with 19 more jobs pending|
|+140ms|╚Event processed successfully (140ms)|
|5/10/2020, 6:49:58 PM +40ms|
|+1ms|╔Received event [My home].time = 1589150998690 with a delay of -650ms|
|+46ms|║RunTime Analysis CS > 21ms > PS > 5ms > PE > 20ms > CE|
|+48ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (47ms)|
|+49ms|║╔Execution stage started|
|+64ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([22]) (6ms)|
|+69ms|║╚Execution stage complete. (19ms)|
|+74ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:50:33 PM EDT (in 35.871s), with 20 more jobs pending|
|+85ms|╚Event processed successfully (85ms)|
|5/10/2020, 6:49:31 PM +163ms|
|+0ms|╔Received event [My home].time = 1589150972201 with a delay of -1038ms|
|+73ms|║RunTime Analysis CS > 31ms > PS > 9ms > PE > 33ms > CE|
|+77ms|║Runtime (38846 bytes) successfully initialized in 9ms (v0.3.110.20191009) (76ms)|
|+109ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([4]) (16ms)|
|+117ms|║╚Execution stage complete. (39ms)|
|+125ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:49:58 PM EDT (in 27.403s), with 21 more jobs pending|
|+132ms|╚Event processed successfully (132ms)|
|5/10/2020, 6:49:23 PM +180ms|
|+1ms|╔Received event [My home].time = 1589150963396 with a delay of -216ms|
|+58ms|║RunTime Analysis CS > 31ms > PS > 6ms > PE > 20ms > CE|
|+60ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (59ms)|
|+74ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([23]) (6ms)|
|+79ms|║╚Execution stage complete. (18ms)|
|+85ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:49:32 PM EDT (in 8.936s), with 22 more jobs pending|
|+94ms|╚Event processed successfully (93ms)|
|5/10/2020, 6:48:47 PM +146ms|
|+0ms|╔Received event [My home].time = 1589150928102 with a delay of -956ms|
|+52ms|║RunTime Analysis CS > 27ms > PS > 5ms > PE > 19ms > CE|
|+54ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (53ms)|
|+73ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([24]) (11ms)|
|+80ms|║╚Execution stage complete. (25ms)|
|+90ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:49:23 PM EDT (in 36.161s), with 23 more jobs pending|
|+104ms|╚Event processed successfully (104ms)|
|5/10/2020, 6:48:16 PM +490ms|
|+0ms|╔Received event [My home].time = 1589150897200 with a delay of -710ms|
|+59ms|║RunTime Analysis CS > 28ms > PS > 6ms > PE > 24ms > CE|
|+61ms|║Runtime (38845 bytes) successfully initialized in 6ms (v0.3.110.20191009) (60ms)|
|+62ms|║╔Execution stage started|
|+84ms|║║Executed physical command [Living Room Pot Lights 1].setLevel([3]) (15ms)|
|+89ms|║╚Execution stage complete. (27ms)|
|+96ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:48:48 PM EDT (in 31.517s), with 24 more jobs pending|
|+104ms|╚Event processed successfully (103ms)|
|5/10/2020, 6:48:12 PM +526ms|
|+0ms|╔Received event [My home].time = 1589150892807 with a delay of -281ms|
|+40ms|║RunTime Analysis CS > 19ms > PS > 5ms > PE > 16ms > CE|
|+42ms|║Runtime (38845 bytes) successfully initialized in 5ms (v0.3.110.20191009) (41ms)|
|+57ms|║║Executed physical command [Living Room Pot Lights 2].setLevel([25]) (7ms)|
|+62ms|║╚Execution stage complete. (19ms)|
|+69ms|║Setting up scheduled job for Sun, May 10 2020 @ 6:48:17 PM EDT (in 4.606s), with 25 more jobs pending|
|+77ms|╚Event processed successfully (77ms)|
|5/10/2020, 6:47:37 PM +116ms|
|+0ms|╔Received event [My home].time = 1589150857513 with a delay of -398ms|
|+84ms|║RunTime Analysis CS > 49ms > PS > 6ms > PE > 29ms > CE|
