Location mode and SHM not changing properly (either using the Routines on mobile app or Webcore pistons)
Does anyone know why I’m not able to change the Location Mode or SHM properly? I’ve used the actions “set Location Mode” and “set SHM security mode” in several of my Webcore Pistons and it just does not work properly anymore.
For example, a simple arrival piston (using my phone as a presence sensor) will result in SHM going from Armed/Away => Disarmed, but does NOT change my Location Mode from Away=>Home as anticipated.
Also, at night, another webcore piston to automatically set SHM from Disarmed=>Armed/Stay, instead changes from Disarmed=>Armed/AWAY, and instead of changing Location Mode from Home=>Night, it changes it from Home=>Away!?
I’ve also tried to change these modes and SHM using the Routines on the native mobile smartthings app, and it still fails to change correctly. It always changes from Disarmed=>Armed/Away (never Armed/Home). Basically, the pistons are firing as triggered, but part of the resulting SHM and location mode changes are not correct (even though there is a change). Any help is much appreciated!
