I have a piston for my door that is supposed to lock it after an hour if the contact is in a closed state and they are no longer working correctly. It’s been working for probably over a year until about the last month or so.
The locks should only engage if the contact is in a closed state and it has been one hour. If the contact is opened or the lock is locked then the piston tasks should be cancelled.
Instead the lock is engaging sometimes when the contact is open.
9/12/2021, 4:42:46 PM +416ms
+1ms ╔Received event [Front Door].lock = unlocked with a delay of 123ms
+87ms ║RunTime Analysis CS > 29ms > PS > 7ms > PE > 52ms > CE
+90ms ║Runtime (40143 bytes) successfully initialized in 7ms (v0.3.111.20210130) (87ms)
+98ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+100ms ║║Cancelling condition #6’s schedules…
+101ms ║║Condition #6 evaluated true (6ms)
+112ms ║║Comparison (enum) open stays (string) closed = false (1ms)
+113ms ║║Cancelling any timed trigger schedules for condition 3
+114ms ║║Cancelling statement #3’s schedules…
+115ms ║║Cancelling condition #3’s schedules…
+116ms ║║Condition #3 evaluated false (15ms)
+117ms ║║Condition group #1 evaluated false (state did not change) (23ms)
+126ms ║║Condition #15 evaluated false (6ms)
+127ms ║║Condition group #14 evaluated false (state did not change) (8ms)
+132ms ║║Comparison (enum) unlocked changes_to (string) locked = false (1ms)
+133ms ║║Condition #10 evaluated false (4ms)
+134ms ║║Condition group #17 evaluated false (state did not change) (6ms)
+135ms ║║Condition group #9 evaluated false (state did not change) (16ms)
+138ms ║╚Execution stage complete. (47ms)
+139ms ╚Event processed successfully (139ms)
9/12/2021, 3:51:15 PM +776ms
+2ms ╔Received event [Front Door].lock = locked with a delay of 149ms
+10128ms ║RunTime Analysis CS > 27ms > PS > 10036ms > PE > 64ms > CE
+10129ms ║Piston waited at a semaphore for 10031ms
+10131ms ║Runtime (40223 bytes) successfully initialized in 10036ms (v0.3.111.20210130) (10128ms)
+10132ms ║╔Execution stage started
+10141ms ║║Comparison (enum) locked is_not (string) locked = false (1ms)
+10142ms ║║Condition #6 evaluated false (5ms)
+10143ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+10154ms ║║Condition #15 evaluated false (8ms)
+10155ms ║║Condition group #14 evaluated false (state did not change) (9ms)
+10160ms ║║Comparison (enum) locked changes_to (string) locked = false (1ms)
+10162ms ║║Cancelling condition #10’s schedules…
+10163ms ║║Condition #10 evaluated false (5ms)
+10164ms ║║Condition group #17 evaluated false (state did not change) (7ms)
+10165ms ║║Condition group #9 evaluated false (state did not change) (20ms)
+10167ms ║╚Execution stage complete. (35ms)
+10168ms ╚Event processed successfully (10168ms)
9/12/2021, 3:51:15 PM +751ms
+1ms ╔Received event [Front Door].lock = locked with a delay of 124ms
+77ms ║RunTime Analysis CS > 23ms > PS > 5ms > PE > 49ms > CE
+79ms ║Runtime (40132 bytes) successfully initialized in 5ms (v0.3.111.20210130) (77ms)
+88ms ║║Comparison (enum) locked is_not (string) locked = false (1ms)
+90ms ║║Cancelling condition #6’s schedules…
+91ms ║║Condition #6 evaluated false (7ms)
+92ms ║║Cancelling condition #1’s schedules…
+93ms ║║Condition group #1 evaluated false (state changed) (8ms)
+103ms ║║Cancelling condition #15’s schedules…
+104ms ║║Condition #15 evaluated false (9ms)
+105ms ║║Cancelling condition #14’s schedules…
+106ms ║║Condition group #14 evaluated false (state changed) (11ms)
+111ms ║║Comparison (enum) locked changes_to (string) locked = true (0ms)
+112ms ║║Condition #10 evaluated true (5ms)
+121ms ║║Comparison (enum) open is (string) closed = false (1ms)
+122ms ║║Cancelling condition #13’s schedules…
+123ms ║║Condition #13 evaluated false (10ms)
+124ms ║║Cancelling condition #17’s schedules…
+125ms ║║Condition group #17 evaluated false (state changed) (18ms)
+126ms ║║Cancelling condition #9’s schedules…
+127ms ║║Condition group #9 evaluated false (state changed) (33ms)
+129ms ║╚Execution stage complete. (49ms)
+130ms ╚Event processed successfully (130ms)
9/12/2021, 3:51:08 PM +417ms
+1ms ╔Received event [Home].time = 1631476268383 with a delay of 34ms
+109ms ║RunTime Analysis CS > 41ms > PS > 7ms > PE > 61ms > CE
+111ms ║Runtime (40138 bytes) successfully initialized in 7ms (v0.3.111.20210130) (109ms)
+118ms ║║Cancelling condition #3’s schedules…
+119ms ║║Condition #3 evaluated true (1ms)
+121ms ║║Cancelling condition #1’s schedules…
+121ms ║║Condition group #1 evaluated true (state changed) (4ms)
+124ms ║║Cancelling statement #4’s schedules…
+262ms ║║Executed physical command [Front Door].lock() (132ms)
+263ms ║║Executed [Front Door].lock (134ms)
+322ms ║║Executed virtual command [Front Door].sendSMSNotification (55ms)
+331ms ║╚Execution stage complete. (218ms)
+332ms ╚Event processed successfully (332ms)
9/12/2021, 2:51:08 PM +498ms
+2ms ╔Received event [Front Door].contact = open with a delay of 117ms
+79ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 50ms > CE
+81ms ║Runtime (40141 bytes) successfully initialized in 6ms (v0.3.111.20210130) (79ms)
+94ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+96ms ║║Cancelling condition #6’s schedules…
+96ms ║║Condition #6 evaluated true (10ms)
+101ms ║║Comparison (enum) open stays (string) closed = false (1ms)
+103ms ║║Cancelling any timed trigger schedules for condition 3
+104ms ║║Cancelling statement #3’s schedules…
+105ms ║║Condition #3 evaluated false (8ms)
+106ms ║║Condition group #1 evaluated false (state did not change) (19ms)
+112ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+113ms ║║Cancelling condition #15’s schedules…
+114ms ║║Condition #15 evaluated true (6ms)
+122ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+123ms ║║Condition #16 evaluated true (8ms)
+124ms ║║Cancelling condition #14’s schedules…
+125ms ║║Condition group #14 evaluated true (state changed) (17ms)
+126ms ║║Condition group #9 evaluated true (state did not change) (19ms)
+128ms ║║Cancelling statement #11’s schedules…
+131ms ║║Executed virtual command cancelTasks (0ms)
+135ms ║╚Execution stage complete. (53ms)
9/12/2021, 2:51:08 PM +270ms
+2ms ╔Received event [Front Door].lock = unlocked with a delay of 138ms
+86ms ║RunTime Analysis CS > 29ms > PS > 6ms > PE > 51ms > CE
+89ms ║Runtime (40142 bytes) successfully initialized in 6ms (v0.3.111.20210130) (86ms)
+90ms ║╔Execution stage started
+98ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+99ms ║║Cancelling condition #6’s schedules…
+100ms ║║Condition #6 evaluated true (6ms)
+111ms ║║Comparison (enum) closed stays (string) closed = true (2ms)
+113ms ║║Adding a timed trigger schedule for condition 3
+115ms ║║Condition #3 evaluated false (14ms)
+116ms ║║Condition group #1 evaluated false (state did not change) (22ms)
+130ms ║║Condition #15 evaluated false (11ms)
+132ms ║║Condition group #14 evaluated false (state did not change) (13ms)
+136ms ║║Comparison (enum) unlocked changes_to (string) locked = false (1ms)
+138ms ║║Cancelling condition #10’s schedules…
+139ms ║║Condition #10 evaluated false (6ms)
+140ms ║║Cancelling condition #17’s schedules…
+141ms ║║Condition group #17 evaluated false (state changed) (8ms)
+142ms ║║Cancelling condition #9’s schedules…
+143ms ║║Condition group #9 evaluated false (state changed) (25ms)
+146ms ║╚Execution stage complete. (56ms)
+147ms ║Setting up scheduled job for Sun, Sep 12 2021 @ 3:51:08 PM EDT (in 3599s)
+160ms ╚Event processed successfully (159ms)
9/12/2021, 12:26:02 PM +229ms
+1ms ╔Received event [Front Door].lock = locked with a delay of 98ms
+80ms ║RunTime Analysis CS > 24ms > PS > 6ms > PE > 51ms > CE
+82ms ║Runtime (40143 bytes) successfully initialized in 6ms (v0.3.111.20210130) (80ms)
+91ms ║║Comparison (enum) locked is_not (string) locked = false (2ms)
+92ms ║║Cancelling condition #6’s schedules…
+93ms ║║Condition #6 evaluated false (6ms)
+94ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+104ms ║║Condition #15 evaluated false (7ms)
+105ms ║║Condition group #14 evaluated false (state did not change) (8ms)
+110ms ║║Comparison (enum) locked changes_to (string) locked = true (0ms)
+111ms ║║Cancelling condition #10’s schedules…
+112ms ║║Condition #10 evaluated true (6ms)
+121ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+123ms ║║Condition #13 evaluated true (9ms)
+125ms ║║Condition group #17 evaluated true (state changed) (18ms)
+127ms ║║Condition group #9 evaluated true (state changed) (30ms)
+129ms ║║Cancelling statement #11’s schedules…
+139ms ║╚Execution stage complete. (56ms)
+145ms ╚Event processed successfully (146ms)
9/12/2021, 12:26:00 PM +885ms
+1ms ╔Received event [Front Door].contact = closed with a delay of 129ms
+150ms ║RunTime Analysis CS > 17ms > PS > 6ms > PE > 127ms > CE
+152ms ║Runtime (40144 bytes) successfully initialized in 6ms (v0.3.111.20210130) (150ms)
+153ms ║╔Execution stage started
+166ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+167ms ║║Condition #6 evaluated true (10ms)
+173ms ║║Comparison (enum) closed stays (string) closed = true (1ms)
+177ms ║║Adding a timed trigger schedule for condition 3
+179ms ║║Condition #3 evaluated false (11ms)
+180ms ║║Condition group #1 evaluated false (state did not change) (23ms)
+186ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+188ms ║║Cancelling condition #15’s schedules…
+189ms ║║Condition #15 evaluated false (5ms)
+190ms ║║Cancelling condition #14’s schedules…
+191ms ║║Condition group #14 evaluated false (state changed) (7ms)
+199ms ║║Condition #10 evaluated false (7ms)
+200ms ║║Condition group #17 evaluated false (state did not change) (9ms)
+201ms ║║Cancelling condition #9’s schedules…
+202ms ║║Condition group #9 evaluated false (state changed) (20ms)
+205ms ║╚Execution stage complete. (51ms)
+206ms ║Setting up scheduled job for Sun, Sep 12 2021 @ 1:26:01 PM EDT (in 3599s)
+243ms ╚Event processed successfully (243ms)
9/12/2021, 11:45:09 AM +908ms
+1ms ╔Received event [Front Door].contact = open with a delay of 135ms
+83ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 56ms > CE
+85ms ║Runtime (40145 bytes) successfully initialized in 6ms (v0.3.111.20210130) (83ms)
+86ms ║╔Execution stage started
+100ms ║║Condition #6 evaluated true (9ms)
+105ms ║║Comparison (enum) open stays (string) closed = false (2ms)
+107ms ║║Cancelling any timed trigger schedules for condition 3
+108ms ║║Cancelling statement #3’s schedules…
+109ms ║║Condition #3 evaluated false (8ms)
+110ms ║║Condition group #1 evaluated false (state did not change) (19ms)
+116ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+117ms ║║Cancelling condition #15’s schedules…
+118ms ║║Condition #15 evaluated true (6ms)
+127ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+128ms ║║Condition #16 evaluated true (9ms)
+129ms ║║Cancelling condition #14’s schedules…
+130ms ║║Condition group #14 evaluated true (state changed) (18ms)
+131ms ║║Cancelling condition #9’s schedules…
+132ms ║║Condition group #9 evaluated true (state changed) (21ms)
+134ms ║║Cancelling statement #11’s schedules…
+136ms ║║Executed virtual command cancelTasks (0ms)
+144ms ║╚Execution stage complete. (58ms)
9/12/2021, 11:27:40 AM +916ms
+2ms ╔Received event [Front Door].contact = closed with a delay of 146ms
+96ms ║RunTime Analysis CS > 35ms > PS > 6ms > PE > 55ms > CE
+99ms ║Runtime (40140 bytes) successfully initialized in 6ms (v0.3.111.20210130) (95ms)
+100ms ║╔Execution stage started
+114ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+116ms ║║Condition #6 evaluated true (10ms)
+121ms ║║Comparison (enum) closed stays (string) closed = true (2ms)
+123ms ║║Adding a timed trigger schedule for condition 3
+125ms ║║Condition #3 evaluated false (9ms)
+126ms ║║Condition group #1 evaluated false (state did not change) (22ms)
+132ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+134ms ║║Cancelling condition #15’s schedules…
+135ms ║║Condition #15 evaluated false (6ms)
+136ms ║║Cancelling condition #14’s schedules…
+137ms ║║Condition group #14 evaluated false (state changed) (8ms)
+146ms ║║Cancelling condition #10’s schedules…
+147ms ║║Condition #10 evaluated false (9ms)
+148ms ║║Cancelling condition #17’s schedules…
+149ms ║║Condition group #17 evaluated false (state changed) (11ms)
+150ms ║║Cancelling condition #9’s schedules…
+151ms ║║Condition group #9 evaluated false (state changed) (23ms)
+154ms ║╚Execution stage complete. (55ms)
+155ms ║Setting up scheduled job for Sun, Sep 12 2021 @ 12:27:41 PM EDT (in 3599s)
+162ms ╚Event processed successfully (162ms)
9/12/2021, 11:20:48 AM +86ms
+1ms ╔Received event [Front Door].contact = open with a delay of 93ms
+78ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 52ms > CE
+80ms ║Runtime (40140 bytes) successfully initialized in 5ms (v0.3.111.20210130) (78ms)
+95ms ║║Cancelling condition #6’s schedules…
+96ms ║║Condition #6 evaluated true (11ms)
+101ms ║║Comparison (enum) open stays (string) closed = false (2ms)
+103ms ║║Cancelling statement #3’s schedules…
+104ms ║║Condition #3 evaluated false (7ms)
+105ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+111ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+122ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+124ms ║║Condition #16 evaluated true (9ms)
+125ms ║║Cancelling condition #14’s schedules…
+126ms ║║Condition group #14 evaluated true (state changed) (18ms)
+127ms ║║Condition group #9 evaluated true (state did not change) (20ms)
+136ms ║╚Execution stage complete. (55ms)
+137ms ╚Event processed successfully (137ms)
9/12/2021, 11:20:47 AM +900ms
+1ms ╔Received event [Front Door].lock = unlocked with a delay of 111ms
+85ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 57ms > CE
+88ms ║Runtime (40142 bytes) successfully initialized in 6ms (v0.3.111.20210130) (86ms)
+97ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+100ms ║║Condition #6 evaluated true (7ms)
+115ms ║║Comparison (enum) open stays (string) closed = false (2ms)
+117ms ║║Cancelling any timed trigger schedules for condition 3
+118ms ║║Cancelling statement #3’s schedules…
+119ms ║║Condition #3 evaluated false (18ms)
+120ms ║║Condition group #1 evaluated false (state did not change) (27ms)
+130ms ║║Condition #15 evaluated false (6ms)
+131ms ║║Condition group #14 evaluated false (state did not change) (7ms)
+136ms ║║Comparison (enum) unlocked changes_to (string) locked = false (0ms)
+137ms ║║Cancelling condition #10’s schedules…
+138ms ║║Condition #10 evaluated false (6ms)
+139ms ║║Cancelling condition #17’s schedules…
+140ms ║║Condition group #17 evaluated false (state changed) (8ms)
+141ms ║║Cancelling condition #9’s schedules…
+142ms ║║Condition group #9 evaluated false (state changed) (20ms)
+144ms ║╚Execution stage complete. (56ms)
+146ms ╚Event processed successfully (145ms)
9/11/2021, 6:28:38 PM +60ms
+1ms ╔Received event [Front Door].lock = locked with a delay of 187ms
+81ms ║Runtime (40144 bytes) successfully initialized in 6ms (v0.3.111.20210130) (79ms)
+89ms ║║Comparison (enum) locked is_not (string) locked = false (1ms)
+91ms ║║Cancelling condition #6’s schedules…
+91ms ║║Condition #6 evaluated false (5ms)
+108ms ║║Condition #15 evaluated false (11ms)
+110ms ║║Condition group #14 evaluated false (state did not change) (13ms)
+114ms ║║Comparison (enum) locked changes_to (string) locked = true (1ms)
+115ms ║║Cancelling condition #10’s schedules…
+116ms ║║Condition #10 evaluated true (5ms)
+125ms ║║Comparison (enum) closed is (string) closed = true (2ms)
+126ms ║║Condition #13 evaluated true (9ms)
+127ms ║║Cancelling condition #17’s schedules…
+128ms ║║Condition group #17 evaluated true (state changed) (17ms)
+129ms ║║Cancelling condition #9’s schedules…
+130ms ║║Condition group #9 evaluated true (state changed) (34ms)
+132ms ║║Cancelling statement #11’s schedules…
+135ms ║║Executed virtual command cancelTasks (0ms)
+146ms ║╚Execution stage complete. (64ms)
+154ms ╚Event processed successfully (153ms)
9/11/2021, 6:28:36 PM +230ms
+1ms ╔Received event [Front Door].contact = closed with a delay of 144ms
+104ms ║RunTime Analysis CS > 28ms > PS > 12ms > PE > 65ms > CE
+107ms ║Runtime (40145 bytes) successfully initialized in 12ms (v0.3.111.20210130) (104ms)
+124ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+125ms ║║Condition #6 evaluated true (13ms)
+131ms ║║Comparison (enum) closed stays (string) closed = true (2ms)
+133ms ║║Adding a timed trigger schedule for condition 3
+136ms ║║Condition #3 evaluated false (10ms)
+137ms ║║Condition group #1 evaluated false (state did not change) (25ms)
+143ms ║║Comparison (enum) closed changes_to (string) open = false (1ms)
+145ms ║║Cancelling condition #15’s schedules…
+146ms ║║Condition #15 evaluated false (6ms)
+147ms ║║Cancelling condition #14’s schedules…
+148ms ║║Condition group #14 evaluated false (state changed) (8ms)
+157ms ║║Condition #10 evaluated false (7ms)
+158ms ║║Condition group #17 evaluated false (state did not change) (9ms)
+159ms ║║Cancelling condition #9’s schedules…
+160ms ║║Condition group #9 evaluated false (state changed) (21ms)
+163ms ║╚Execution stage complete. (56ms)
+165ms ║Setting up scheduled job for Sat, Sep 11 2021 @ 7:28:36 PM EDT (in 3599s)
+173ms ╚Event processed successfully (173ms)
9/11/2021, 6:28:26 PM +314ms
+1ms ╔Received event [Front Door].contact = open with a delay of 80ms
+82ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 57ms > CE
+85ms ║Runtime (40144 bytes) successfully initialized in 5ms (v0.3.111.20210130) (83ms)
+100ms ║║Condition #6 evaluated true (10ms)
+105ms ║║Comparison (enum) open stays (string) closed = false (1ms)
+110ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+117ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+118ms ║║Cancelling condition #15’s schedules…
+119ms ║║Condition #15 evaluated true (6ms)
+128ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+129ms ║║Condition #16 evaluated true (9ms)
+130ms ║║Cancelling condition #14’s schedules…
+131ms ║║Condition group #14 evaluated true (state changed) (18ms)
+132ms ║║Cancelling condition #9’s schedules…
+133ms ║║Condition group #9 evaluated true (state changed) (21ms)
+136ms ║║Cancelling statement #11’s schedules…
+138ms ║║Executed virtual command cancelTasks (0ms)
+147ms ║╚Execution stage complete. (62ms)
+154ms ╚Event processed successfully (154ms)
9/11/2021, 6:28:25 PM +848ms
+1ms ╔Received event [Front Door].lock = unlocked with a delay of 69ms
+81ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 55ms > CE
+84ms ║Runtime (40141 bytes) successfully initialized in 5ms (v0.3.111.20210130) (83ms)
+93ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+96ms ║║Condition #6 evaluated true (7ms)
+105ms ║║Comparison (enum) closed stays (string) closed = true (2ms)
+107ms ║║Adding a timed trigger schedule for condition 3
+109ms ║║Condition #3 evaluated false (12ms)
+110ms ║║Condition group #1 evaluated false (state did not change) (21ms)
+119ms ║║Condition #15 evaluated false (6ms)
+121ms ║║Condition group #14 evaluated false (state did not change) (7ms)
+125ms ║║Comparison (enum) unlocked changes_to (string) locked = false (0ms)
+127ms ║║Cancelling condition #10’s schedules…
+128ms ║║Condition #10 evaluated false (6ms)
+129ms ║║Cancelling condition #17’s schedules…
+130ms ║║Condition group #17 evaluated false (state changed) (8ms)
+132ms ║║Condition group #9 evaluated false (state changed) (20ms)
+135ms ║╚Execution stage complete. (51ms)
+137ms ║Setting up scheduled job for Sat, Sep 11 2021 @ 7:28:25 PM EDT (in 3599s)
+144ms ╚Event processed successfully (143ms)
9/11/2021, 5:16:39 PM +328ms
+1ms ╔Received event [Front Door].lock = locked with a delay of 56ms
+76ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 50ms > CE
+78ms ║Runtime (40143 bytes) successfully initialized in 5ms (v0.3.111.20210130) (76ms)
+87ms ║║Comparison (enum) locked is_not (string) locked = false (2ms)
+88ms ║║Cancelling condition #6’s schedules…
+89ms ║║Condition #6 evaluated false (6ms)
+90ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+100ms ║║Condition #15 evaluated false (7ms)
+101ms ║║Condition group #14 evaluated false (state did not change) (8ms)
+105ms ║║Comparison (enum) locked changes_to (string) locked = true (0ms)
+107ms ║║Cancelling condition #10’s schedules…
+108ms ║║Condition #10 evaluated true (6ms)
+116ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+117ms ║║Condition #13 evaluated true (8ms)
+118ms ║║Cancelling condition #17’s schedules…
+119ms ║║Condition group #17 evaluated true (state changed) (17ms)
+120ms ║║Cancelling condition #9’s schedules…
+121ms ║║Condition group #9 evaluated true (state changed) (29ms)
+123ms ║║Cancelling statement #11’s schedules…
+125ms ║║Executed virtual command cancelTasks (0ms)
+134ms ║╚Execution stage complete. (55ms)
+141ms ╚Event processed successfully (140ms)
9/11/2021, 5:16:36 PM +991ms
+2ms ╔Received event [Front Door].contact = closed with a delay of 120ms
+77ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 48ms > CE
+79ms ║Runtime (40142 bytes) successfully initialized in 6ms (v0.3.111.20210130) (77ms)
+91ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+92ms ║║Condition #6 evaluated true (8ms)
+97ms ║║Comparison (enum) closed stays (string) closed = true (1ms)
+99ms ║║Adding a timed trigger schedule for condition 3
+101ms ║║Condition #3 evaluated false (8ms)
+102ms ║║Condition group #1 evaluated false (state did not change) (19ms)
+108ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+109ms ║║Cancelling condition #15’s schedules…
+110ms ║║Condition #15 evaluated false (5ms)
+111ms ║║Cancelling condition #14’s schedules…
+112ms ║║Condition group #14 evaluated false (state changed) (8ms)
+120ms ║║Condition #10 evaluated false (7ms)
+121ms ║║Condition group #17 evaluated false (state did not change) (8ms)
+122ms ║║Cancelling condition #9’s schedules…
+123ms ║║Condition group #9 evaluated false (state changed) (18ms)
+125ms ║╚Execution stage complete. (46ms)
+126ms ║Setting up scheduled job for Sat, Sep 11 2021 @ 6:16:37 PM EDT (in 3599s)
+147ms ╚Event processed successfully (147ms)
9/11/2021, 5:16:29 PM +360ms
+2ms ╔Received event [Front Door].contact = open with a delay of 128ms
+86ms ║RunTime Analysis CS > 18ms > PS > 11ms > PE > 57ms > CE
+89ms ║Runtime (40147 bytes) successfully initialized in 11ms (v0.3.111.20210130) (86ms)
+103ms ║║Comparison (enum) unlocked is_not (string) locked = true (1ms)
+104ms ║║Condition #6 evaluated true (10ms)
+110ms ║║Comparison (enum) open stays (string) closed = false (2ms)
+112ms ║║Cancelling any timed trigger schedules for condition 3
+113ms ║║Cancelling statement #3’s schedules…
+114ms ║║Condition #3 evaluated false (8ms)
+115ms ║║Condition group #1 evaluated false (state did not change) (20ms)
+121ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+123ms ║║Cancelling condition #15’s schedules…
+124ms ║║Condition #15 evaluated true (5ms)
+133ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+134ms ║║Condition #16 evaluated true (10ms)
+137ms ║║Condition group #14 evaluated true (state changed) (19ms)
+138ms ║║Cancelling condition #9’s schedules…
+139ms ║║Condition group #9 evaluated true (state changed) (22ms)
+141ms ║║Cancelling statement #11’s schedules…
+144ms ║║Executed virtual command cancelTasks (0ms)
+152ms ║╚Execution stage complete. (63ms)
+159ms ╚Event processed successfully (159ms)
9/11/2021, 5:16:24 PM +544ms
+2ms ╔Received event [Front Door].contact = closed with a delay of 143ms
+88ms ║RunTime Analysis CS > 27ms > PS > 6ms > PE > 55ms > CE
+91ms ║Runtime (40142 bytes) successfully initialized in 6ms (v0.3.111.20210130) (88ms)
+106ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+107ms ║║Condition #6 evaluated true (11ms)
+113ms ║║Comparison (enum) closed stays (string) closed = true (1ms)
+115ms ║║Adding a timed trigger schedule for condition 3
+117ms ║║Condition #3 evaluated false (9ms)
+118ms ║║Condition group #1 evaluated false (state did not change) (22ms)
+124ms ║║Comparison (enum) closed changes_to (string) open = false (0ms)
+126ms ║║Cancelling condition #15’s schedules…
+127ms ║║Condition #15 evaluated false (6ms)
+128ms ║║Cancelling condition #14’s schedules…
+129ms ║║Condition group #14 evaluated false (state changed) (8ms)
+138ms ║║Condition #10 evaluated false (7ms)
+139ms ║║Condition group #17 evaluated false (state did not change) (8ms)
+140ms ║║Cancelling condition #9’s schedules…
+141ms ║║Condition group #9 evaluated false (state changed) (21ms)
+144ms ║╚Execution stage complete. (52ms)
+145ms ║Setting up scheduled job for Sat, Sep 11 2021 @ 6:16:24 PM EDT (in 3599s)
+153ms ╚Event processed successfully (153ms)
9/11/2021, 5:16:20 PM +696ms
+1ms ╔Received event [Front Door].contact = open with a delay of 85ms
+76ms ║RunTime Analysis CS > 19ms > PS > 5ms > PE > 52ms > CE
+79ms ║Runtime (40144 bytes) successfully initialized in 5ms (v0.3.111.20210130) (77ms)
+92ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+94ms ║║Condition #6 evaluated true (9ms)
+99ms ║║Comparison (enum) open stays (string) closed = false (2ms)
+101ms ║║Cancelling any timed trigger schedules for condition 3
+102ms ║║Cancelling statement #3’s schedules…
+103ms ║║Condition #3 evaluated false (9ms)
+104ms ║║Condition group #1 evaluated false (state did not change) (21ms)
+110ms ║║Comparison (enum) open changes_to (string) open = true (1ms)
+112ms ║║Cancelling condition #15’s schedules…
+113ms ║║Condition #15 evaluated true (6ms)
+121ms ║║Comparison (enum) unlocked is_not (string) locked = true (2ms)
+125ms ║║Condition group #14 evaluated true (state changed) (19ms)
+127ms ║║Condition group #9 evaluated true (state changed) (21ms)
+132ms ║║Executed virtual command cancelTasks (0ms)
+140ms ║╚Execution stage complete. (61ms)
