I’m not sure what happened, but suddenly, after MANY months working flawlessly our Kwickset lock has simply stopped automatically locking as per our webcore code. It essentially waits for the status to go to Unlocked, checks the time and sets a timer to lock the door based on what time it is. Nothing in our system changed and the door lock can be manually locked remotely with ST and works otherwise as well as having 70% battery life.
Here’s some recent logging:
/2018, 5:43:01 PM +496ms
+0ms ╔Received event [Front Door Lock].lock = locked with a delay of 804ms
+248ms ║RunTime Analysis CS > 15ms > PS > 26ms > PE > 207ms > CE
+250ms ║Runtime (37385 bytes) successfully initialized in 26ms (v0.2.101.20171227) (249ms)
+251ms ║╔Execution stage started
+258ms ║║Comparison (enum) locked changes_to (string) unlocked = false (0ms)
+259ms ║║Cancelling condition #10’s schedules…
+260ms ║║Condition #10 evaluated false (5ms)
+261ms ║║Cancelling condition #1’s schedules…
+262ms ║║Condition group #1 evaluated false (state changed) (6ms)
+264ms ║╚Execution stage complete. (12ms)
+265ms ╚Event processed successfully (266ms)
6/7/2018, 5:42:57 PM +67ms
+0ms ╔Received event [Home].time = 1528407778861 with a delay of -1794ms
+200ms ║RunTime Analysis CS > 29ms > PS > 64ms > PE > 107ms > CE
+202ms ║Runtime (37383 bytes) successfully initialized in 64ms (v0.2.101.20171227) (201ms)
+203ms ║╔Execution stage started
+241ms ║║Executed physical command [Front Door Lock].lock() (21ms)
+241ms ║║Executed [Front Door Lock].lock (23ms)
+244ms ║╚Execution stage complete. (41ms)
+245ms ╚Event processed successfully (245ms)
Thanks.
We have had it lock once or twice by itself, but mainly we’re finding the door completely unlocked after hours of sitting that way.
