How to loop the event so as to perform the check every hour between 11pm to 5am.
The event (auto arm check) only occurs once at 11:00PM.
Hello, can someone suggest how I would be able to loop this piston to check whether the house is armed or not every hour from 11:00PM to 5:00AM (based on if the doors are open or not and if the presence sensor is present or not).
Also, not to create another thread, but similarly, how to check the state of other things (e.g. doors, motion sensors, lights, temperature, humidity), and report the current state in a push messaging to my phone every 2 hours. Smartthings only reports if there is an intrusion, not when there isn’t, or if there’s a sudden rise in temperature. Thank you!! this community is great :)! I’ve learned so much from using webcore.
