I would like to set up a piston that lowers the thermostat by 2 degrees if a sensor gets above a certain temperature. I know how to set a specific temperature but would like instead for it to look at current setting an lower it. I feel like this should be possible but don’t know how to do it.
If temperature is greater than or equal to 74 degrees then lower ecobee heating by 2 degrees.
Nothing is happening.
(UPLOAD YOUR IMAGE HERE)
