Lutron Caseta Switches not responding to commands from webCoRE consistently
Turn on/off when with command
Sporadically switches don’t change with command.
(UPLOAD YOUR IMAGE HERE)
Logging shows that command was skipped because it would not change the state of switch
My theory is that the API is receiving incorrect “switch state” from Lutron Switch which is causing the switch to not set as expected. Is this something I can alleviate by changing “command optimizations” to “no” or is there a different solution?
