Piston has worked for a long time, but just stopped working in the last couple of days.
Once my LUX sensor hits 11 or below, it should set off a sequence of turning lights on.
The piston detects the LUX, but doesn’t continue with the rest of the sequence (turning on the lights). It’s set up to only run once a day, that way if I turn those lights off after they turn on, the piston doesn’t try to turn them back on again.
