This is a very basic piston, it should work and some of it does. Just not ALL of it. Its probably obvious and I’m looking right at the problem and not seeing it.
When the mailbox door opens the piston sees the changed and sends the SMS, It then should wait 5 minutes and set the boolean variable to set up for the next event.
It triggers, sends SMS, sets up for wake event 5 minutes later, wakes but NEVER sets the variable?
Here is a snapshot of the execution. I know not how it says to do it was just easier.
I’m sure it is something simple. Sometimes a new set of eyes see the obvious.
Thanks in advance because I know someone will see what I’m doing wrong and correct me.
