**1) Created a simple piston that executes every minute (for testing). Normally it runs every 60 minutes.
This piston switches on two devices
Waits 15 seconds
switches the two devices off
It has been working properly for a few weeks.
I added two simple get requests to log the data to a google sheets file. I’ve done this many other times without an issue.
The problem is once the first get is encountered, the piston continues to run the the first with statement that turns on both devices and logs the data to google.
If I comment out the get request, the piston starts acting normally again. Why would the get request cause this behavior?
**4)
- This is a copy of the output on google. It shows that the first get is executing every 15 seconds:
Here is a log file
5/31/2020, 10:39:51 PM +448ms
+50ms ╔Stopping piston…
+102ms ╚Piston successfully stopped (52ms)
5/31/2020, 10:39:42 PM +137ms
+0ms ╔Received event [Heber GH].time = 1590986383298 with a delay of -1161ms
+54ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 31ms > CE
+56ms ║Runtime (40533 bytes) successfully initialized in 5ms (v0.3.110.20191009) (55ms)
+57ms ║╔Execution stage started
+66ms ║║Cancelling statement #2’s schedules…
+80ms ║║Skipped execution of physical command [Return pump].on([]) because it would make no change to the device. (8ms)
+81ms ║║Executed [Return pump].on (11ms)
+93ms ║║Skipped execution of physical command [Return UV light].on([]) because it would make no change to the device. (9ms)
+94ms ║║Executed [Return UV light].on (11ms)
+103ms ║║Pump On
+104ms ║║Executed virtual command [Return pump, Return UV light].log (2ms)
+108ms ║║Cancelling statement #18’s schedules…
+116ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status= + (string) ONLINE >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE
+120ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE + (string) &UV Light Status= >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status=
+124ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status= + (string) ONLINE >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status=ONLINE
+130ms ║║Sending external web request to: script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump%20Status=ONLINE&UV%20Light%20Status=ONLINE
+1659ms ║║Executed virtual command httpRequest (1529ms)
+1662ms ║║Cancelling statement #4’s schedules…
+1665ms ║║Executed virtual command wait (1ms)
+1666ms ║║Requesting a wake up for Sun, May 31 2020 @ 10:39:58 PM MDT (in 15.0s)
+1670ms ║╚Execution stage complete. (1613ms)
+1672ms ║Setting up scheduled job for Sun, May 31 2020 @ 10:39:58 PM MDT (in 14.996s), with 1 more job pending
+1706ms ╚Event processed successfully (1705ms)
5/31/2020, 10:39:26 PM +129ms
+1ms ╔Received event [Heber GH].time = 1590986366766 with a delay of -637ms
+49ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 27ms > CE
+51ms ║Runtime (40532 bytes) successfully initialized in 4ms (v0.3.110.20191009) (50ms)
+52ms ║╔Execution stage started
+61ms ║║Cancelling statement #2’s schedules…
+139ms ║║Executed physical command [Return pump].on() (58ms)
+143ms ║║Executed [Return pump].on (75ms)
+160ms ║║Executed physical command [Return UV light].on() (14ms)
+161ms ║║Executed [Return UV light].on (16ms)
+175ms ║║Pump On
+176ms ║║Executed virtual command [Return pump, Return UV light].log (1ms)
+179ms ║║Cancelling statement #18’s schedules…
+192ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status= + (string) ONLINE >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE
+197ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE + (string) &UV Light Status= >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status=
+201ms ║║Calculating (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status= + (string) ONLINE >> (string) https://script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump Status=ONLINE&UV Light Status=ONLINE
+214ms ║║Sending external web request to: script.google.com/macros/s/{ID removed}/exec?Return=on&Wait=4.75&Pump%20Status=ONLINE&UV%20Light%20Status=ONLINE
+2137ms ║║Executed virtual command httpRequest (1923ms)
+2140ms ║║Cancelling statement #4’s schedules…
+2145ms ║║Executed virtual command wait (1ms)
+2163ms ║║Requesting a wake up for Sun, May 31 2020 @ 10:39:43 PM MDT (in 15.0s)
+2172ms ║╚Execution stage complete. (2120ms)
+2174ms ║Setting up scheduled job for Sun, May 31 2020 @ 10:39:43 PM MDT (in 14.996s), with 1 more job pending
+2200ms ╚Event processed successfully (2200ms)
5/31/2020, 10:38:29 PM +3ms
+0ms ╔Received event [Heber GH].test = 1590986308999 with a delay of 3ms
+60ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 35ms > CE
+63ms ║Runtime (40529 bytes) successfully initialized in 6ms (v0.3.110.20191009) (62ms)
+64ms ║╔Execution stage started
+110ms ║╚Execution stage complete. (45ms)
+112ms ║Setting up scheduled job for Sun, May 31 2020 @ 10:39:26 PM MDT (in 57.652s)
+132ms ╚Event processed successfully (132ms)
5/31/2020, 10:38:26 PM +465ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+204ms ║╔Subscribing to devices…
+267ms ║║Subscribing to Return pump…
+268ms ║║Subscribing to Return UV light…
+269ms ║╚Finished subscribing (69ms)
+332ms ║Setting up scheduled job for Sun, May 31 2020 @ 10:39:26 PM MDT (in 59.97s)
+344ms ╚Piston successfully started (344ms)
looks good to me…
