All attempts to make a web request or use IFTTT integration fail for me. A MissingMethodException is thrown for both Make a Web Request and IFTTT integration.
A web method is called on an IFTTT or other server with exposed web methods.
This exception is thrown:
An error occurred while executing the event: groovy.lang.MissingMethodException: No signature of method: physicalgraph.app.LocationWrapper.hasCommand() is applicable for argument types: (java.lang.String) values: [httpRequest]
5/19/2019, 8:39:13 PM +779ms +1ms ╔Starting piston... (v0.3.10b.20190514) +546ms ║╔Subscribing to devices... +593ms ║║Subscribing to Home.:de0ed8c9f29601e3ec8f1584cae0969c:.@StartClimateControl... +745ms ║╚Finished subscribing (217ms) +778ms ║Comparison (integer) 2 changes = false (1ms) +780ms ║Cancelling condition #2's schedules... +788ms ║Comparison (integer) 2 is_different_than (integer) 0 = true (4ms) +790ms ║Cancelling condition #1's schedules... +801ms ║Comparison (integer) 2 is_equal_to (integer) 1 = false (2ms) +817ms ║Comparison (integer) 2 is_equal_to (integer) 2 = true (3ms) +834ms ╚Piston successfully started (833ms) 5/19/2019, 8:39:04 PM +185ms +1ms ╔Received event [Home].:de0ed8c9f29601e3ec8f1584cae0969c: = @StartClimateControl with a delay of 97ms +115ms ║RunTime Analysis CS > 27ms > PS > 63ms > PE > 25ms > CE +118ms ║Runtime (42764 bytes) successfully initialized in 63ms (v0.3.10b.20190514) (115ms) +119ms ║╔Execution stage started +128ms ║║Comparison (integer) 2 changes = true (0ms) +129ms ║║Condition #2 evaluated true (4ms) +135ms ║║Comparison (integer) 2 is_different_than (integer) 0 = true (2ms) +137ms ║║Condition #3 evaluated true (6ms) +138ms ║║Condition group #1 evaluated true (state did not change) (13ms) +146ms ║║Comparison (integer) 2 is_equal_to (integer) 1 = false (2ms) +148ms ║║Cancelling condition #5's schedules... +149ms ║║Condition #5 evaluated false (8ms) +151ms ║║Cancelling condition #4's schedules... +152ms ║║Condition group #4 evaluated false (state changed) (12ms) +158ms ║║Comparison (integer) 2 is_equal_to (integer) 2 = true (2ms) +160ms ║║Condition #13 evaluated true (6ms) +162ms ║║Condition group #12 evaluated true (state did not change) (8ms) +165ms ║║Cancelling statement #14's schedules... +177ms ║║An error occurred while executing the event: groovy.lang.MissingMethodException: No signature of method: physicalgraph.app.LocationWrapper.hasCommand() is applicable for argument types: (java.lang.String) values: [httpRequest] +180ms ║╚Execution stage complete. (62ms) +182ms ╚Event processed successfully (182ms)
