This is a two-part question.
Part 1: I am working on a piston that should change the profile of my security camera via an HTTP command. If I copy and paste the command from WC and paste it into a browser, things work properly and the camera’s profile changes as expected. But when I execute the piston, nothing happens and the camera’s profile stays the same.
I don’t understand why the command works when issued from a browser but doesn’t work when issued via WC. No errors are displayed in the log.
Part 2: I thought I would log the HTTP response to the console and look for clues in the response but nothing is written to the console. Am I doing something wrong? Is there just no response or is my syntax for logging the response incorrect?
The HTTP Get command should change the camera’s profile from 0 to 1 at sunset and 1 to 0 at sunrise.
If I copy the command from WebCoRE and paste it into a browser and execute it, the camera’s profile successfully changes. When I run the piston containing the same command, nothing happens.
Here’s the piston. I’ve changed the the User ID and password to gibberish so the entire formatted URL is visible. When I get it working, the piston will run at sunrise and sunset but right now it says everyday at a specific time so I can easily change the time and trigger it for testing purposes.
Here are the logs. I’ve redacted the User ID and Password.
| 298ms | ║╔Subscribing to devices… |
| +349ms | ║╚Finished subscribing (60ms) |
| +407ms | ║Setting up scheduled job for Tue, Jan 19 2021 @ 7:18:00 AM MST (in 40477.27s), with 1 more job pending |
| +420ms | ╚Piston successfully started (419ms) |
| 1/18/2021, 7:57:18 PM +42ms | |
| +1ms | ╔Received event [Home V3].time = 1611025039105 with a delay of -1063ms |
| +40ms | ║RunTime Analysis CS > 22ms > PS > 5ms > PE > 12ms > CE |
| +42ms | ║Runtime (40427 bytes) successfully initialized in 5ms (v0.3.110.20191009) (41ms) |
| +43ms | ║╔Execution stage started |
| +55ms | ║║[:] |
| +56ms | ║║Executed virtual command log (1ms) |
| +61ms | ║║Calculating (string) DW Starlight profile set to Night at + (string) Mon, Jan 18 2021 @ 7:57:18 PM MST >> (string) DW Starlight profile set to Night at Mon, Jan 18 2021 @ 7:57:18 PM MST |
| +64ms | ║║Calculating (string) DW Starlight profile set to Night at Mon, Jan 18 2021 @ 7:57:18 PM MST + (string) . >> (string) DW Starlight profile set to Night at Mon, Jan 18 2021 @ 7:57:18 PM MST. |
| +76ms | ║║Executed virtual command sendPushNotification (9ms) |
| +79ms | ║╚Execution stage complete. (36ms) |
| +81ms | ║Setting up scheduled job for Tue, Jan 19 2021 @ 7:18:00 AM MST (in 40841.878s), with 1 more job pending |
| +87ms | ╚Event processed successfully (87ms) |
| 1/18/2021, 7:56:59 PM +41ms | |
| +0ms | ╔Received event [Home V3].time = 1611025020000 with a delay of -960ms |
| +35ms | ║RunTime Analysis CS > 15ms > PS > 6ms > PE > 15ms > CE |
| +38ms | ║Runtime (40426 bytes) successfully initialized in 6ms (v0.3.110.20191009) (36ms) |
| +39ms | ║╔Execution stage started |
| +51ms | ║║Cancelling statement #2’s schedules… |
| +58ms | ║║Sending internal web request to: userRedacted:[email protected]/cgi-bin/configManager.cgi?action=setConfig&VideoInMode[0].Config[0]=1 |
| +62ms | ║║Executed virtual command httpRequest (4ms) |
| +63ms | ║║Requesting a wake up for Mon, Jan 18 2021 @ 7:57:19 PM MST (in 20.0s) |
| +70ms | ║╚Execution stage complete. (31ms) |
| +72ms | ║Setting up scheduled job for Mon, Jan 18 2021 @ 7:57:19 PM MST (in 19.993s), with 2 more jobs pending |
| +79ms | ╚Event processed successfully (79ms) |
