Glad we got it working! I will update my first post with our findings…
Commas and periods add a bit of delay between phrases…
(but unfortunately, “dot dot dot” does not triple that delay)
Perhaps a better answer would be: You can edit the “Task” on line 3 (the Say command).
Here, you can play with Pitch & Speed… as well as choose other voices, if you like.
Once you change something, back up multiple times to the desktop (to save Tasker)… Then you can press the Test button in my sample piston above to hear the latest tweaks.
It is also possible to download new voices to your Android, but oftentimes, there are some decent ones already pre-installed on the device. (my favs are: eng-aus, eng-gbr & eng-usa, but feel free to experiment)
Edit:
Before I update my original post, can you share a new Profile pic showing the working trigger?
(the latest “AutoNotification Intercept”)
Also, is “My home” your choice of words, or is that the default Title that everyone will see on their devices? (I guess anyone with the new app can answer this last question)
