Mimo lite Control Piston
I’ve got a MimoLite that controls my garage door and I can get it to open just fine via a piston, however I cannot get it to close with one. Working fine with local ST Routines.
Garage to close when I leave base on L360 location.
It will open but not close.
Which one is the Mimolight in the picture? Also, have you tried just creating one simple piston with just the Mimolight and triggering it to close?
It’s the Garage device. I thought about creating a virtual switch and playing with the different actions on there. I’ve tried Device - Turn on, Device - Turn off, Emulated - Toggle, and Set Switch ones within the piston.
Also just noticed the screenshot is showing Switch 4, but in the piston on the site(just checked) It’s showing correctly as Garage.
What other commands you see under the device? (After DO part)
Sometimes turn off means something else for that device (or meaningless)
Shut down?
Close?
Off?
Do you use a device handler?
I do use a device handler too… Posting the code for it as well.
  • MIMOlite as a Garage Door Control with Potentiometer Multi Sensor
  • Copyright 2016 Simon Capper
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Inspired by a similar handler written by https://community.smartthings.com/users/johnconstantelo
    metadata {
    definition (name: “MIMOlite - Garage Door Control”, namespace: “skyjunky”, author: “Simon Capper”) {
    capability “Polling”
    capability “Refresh”
    capability “Momentary”
    capability “Configuration”
    capability “Switch”
    capability “Actuator”
    attribute “powerSupply”, “string”
    attribute “doorPosition”, “number”
    attribute “doorPositionClosed”, “number”
    attribute “doorPositionOpen”, “number”
    command “setOpenPosition”
    command “setClosedPosition”
    fingerprint deviceId:“0x1000”, inClusters:“0x72, 0x86, 0x71, 0x30, 0x31, 0x35, 0x70, 0x85, 0x25”
    // UI tile definitions
    tiles(scale:2) {
    multiAttributeTile(name:“door”, type: “generic”, width: 6, height: 4){
    tileAttribute (“device.door”, key: “PRIMARY_CONTROL”) {
    attributeState “open”, label: “Open”, action: “push”, icon: “st.doors.garage.garage-open”, backgroundColor: “#ffa81e”, nextState:“closing”
    attributeState “opening”, label: “Opening”, action: “push”, icon: “st.doors.garage.garage-opening”, backgroundColor: “#ffffff”, nextState:“closing”
    attributeState “closed”, label: “Closed”, action: “push”, icon: “st.doors.garage.garage-closed”, backgroundColor: “#79b821”, nextState:“opening”
    attributeState “closing”, label: “Closing”, action: “push”, icon: “st.doors.garage.garage-closing”, backgroundColor: “#ffffff”, nextState:“opening”
    attributeState “unknown”, label: “Power Out”, icon: “st.alarm.alarm.alarm”, backgroundColor: “#bc2323”
    tileAttribute (“powerSupply”, key: “SECONDARY_CONTROL”) {
    attributeState “good”, label: “Power Good”
    attributeState “powerOutOpen”, label: “Power Out - Door Open”
    attributeState “powerOutClosed”, label: “Power Out - Door Closed”
    valueTile (“doorPositionOpen”, “device.doorPositionOpen”, width: 5, height: 1) {
    state “doorPositionOpen”, label: ‘Configured Open Position ${currentValue}’
    standardTile (“setOpenPos”, “setOpenPos”, decoration: “flat” ) {
    state “setOpenPos”, label: ‘’, action: ‘setOpenPosition’, icon: “st.secondary.configure”
    valueTile (“doorPositionClosed”, “device.doorPositionClosed”, width: 5, height: 1) {
    state “doorPositionClosed”, label: ‘Configured Close Position ${currentValue}’
    standardTile (“setClosedPos”, “setClosedPos”, decoration: “flat”) {
    state “setClosedPos”, label: ‘’, action: ‘setClosedPosition’, icon: “st.secondary.configure”
    valueTile (“doorPosition”, “device.doorPosition”, width: 5, height: 1) {
    state “doorPosition”, label: ‘Current Door Position ${currentValue}’
     main "door"
     details(["door", "doorPositionOpen", "setOpenPos",
              "doorPositionClosed", "setClosedPos", "doorPosition"])
def parse(String description) {
def result = null
// supported classes
// 0x20 - BasicSet used to report when the sensor trigger level changes
// 0x25 - switch binary V1
// 0x30 - sensor binary V1
// 0x31 - sensor multilevel V1
// 0x35 - meter pulse (not tested)
// 0x70 - configuration V1
// 0x71 - alarm V1 (for supply voltage monitor, does not seem to respond to AlarmGet)
// 0x72 - manufacturer specific V1
// 0x85 - association V1
// 0x86 - version V1
def cmd = zwave.parse(description, [0x20: 1, 0x25: 1, 0x86: 1, 0x30: 1, 0x31: 1, 0x72: 1, 0x71: 1])
if (cmd) {
    result = createEvent(zwaveEvent(cmd))
    if (result) {
        log.debug "Parsed command: ${result?.descriptionText} raw: ${description}"
    } else {
        log.debug "Unhandled command: ${description}"
} else {
    log.debug "Unparsed command: ${description}"
return result
def getSensitivity() {
return 0x1
def getPotOpen() {
def rc = device.currentValue(“doorPositionOpen”)
if (rc == null) {
sendEvent(name: “doorPositionOpen”, value: 158)
return 158
return rc
def getPotClosed() {
def rc = device.currentValue(“doorPositionClosed”)
if (rc == null) {
sendEvent(name: “doorPositionClosed”, value: 0)
return 0
return rc
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
// trigger fires, request the door position so we can see what state it is in
poll().collect { sendHubCommand(new physicalgraph.device.HubAction(it)) }
return null
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd) {
if (cmd.alarmLevel) {
if (device.currentValue(“door”) == “closed”) {
sendEvent(name: “powerSupply”, value: “powerOutClosed”)
} else {
sendEvent(name: “powerSupply”, value: “powerOutOpen”)
return [name: “door”, value: “unknown”]
return null
def convertSensorValueToDoorState( BigDecimal sensorValue ) {
def upper = (potOpen < potClosed) ? potClosed : potOpen
def lower = (potOpen > potClosed) ? potClosed : potOpen
def upperState = (potOpen > potClosed) ? “open” : “closed”
def lowerState = (potOpen < potClosed) ? “open” : “closed”
if (sensorValue >= (upper - sensitivity)) {
    return upperState
} else if (sensorValue <= (lower + sensitivity)) {
    return lowerState
} else if (device.currentValue('door') == "open") {
    return 'closing'
} else if (device.currentValue('door') == "closed") {
    return 'opening'
return device.currentValue('door')
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
// if we are in a power fail state this is the first message we’ll get after the power comes back
// so update the powerState
if (device.currentValue(‘powerSupply’) != “good”) {
sendEvent(name: “powerSupply”, value: “good”)
def adjustedValue = cmd.scaledSensorValue.intValue() >> 4
if (adjustedValue != device.currentValue('doorPosition')) {
    def doorState = convertSensorValueToDoorState( adjustedValue )
    sendEvent(name: "doorPosition", value: adjustedValue)
    if (device.currentValue('door') != doorState) {
        return [name: "door", value: doorState]
return null
def zwaveEvent(physicalgraph.zwave.Command cmd) {
// Handles all Z-Wave commands we aren’t interested in
return null
def setOpenPosition() {
sendEvent(name: “doorPositionOpen”, value: device.currentValue(‘doorPosition’))
setTriggerLevels().collect { sendHubCommand(new physicalgraph.device.HubAction(it)) }
def setClosedPosition() {
sendEvent(name: “doorPositionClosed”, value: device.currentValue(‘doorPosition’))
def on() {
open()
def off() {
close()
def open() {
push()
def close() {
if (device.currentValue(“door”) == “open”) {
push()
def push() {
def cmds = delayBetween([
zwave.switchBinaryV1.switchBinarySet(switchValue: 0xff).format(),
],500)
return cmds
def poll() {
delayBetween([
zwave.sensorMultilevelV1.sensorMultilevelGet().format(),
],500)
def refresh() {
delayBetween([
],500)
def updated() {
// called when the device is updated
configure()
def installed() {
// called when the device is installed
configure()
def setTriggerLevels() {
def openVal = getPotOpen()
def closedVal = getPotClosed()
def slop = getSensitivity()
// if the potentiometer is installed backwards reverse the parameters
if (openVal < closedVal) {
    def temp = closedVal
    closedVal = openVal
    openVal = temp
def lowerValHigh = closedVal + (2 * slop)
def lowerValLow = closedVal + slop
def upperValHigh = openVal - slop
def upperValLow = openVal - (2 * slop)
delayBetween([
    // Lower Threshold, High (Default=0xBB)
    zwave.configurationV1.configurationSet(scaledConfigurationValue: lowerValHigh, parameterNumber: 4, size: 2).format(),
    // Lower Threshold, Low (Default=0xAB)
    zwave.configurationV1.configurationSet(scaledConfigurationValue: lowerValLow, parameterNumber: 5, size: 2).format(),
    // Upper Threshold, High (Default=0xFF)
    zwave.configurationV1.configurationSet(scaledConfigurationValue: upperValHigh, parameterNumber: 6, size: 2).format(),
    // Upper Threshold, Low (Default = 0xFE)
    zwave.configurationV1.configurationSet(scaledConfigurationValue: upperValLow, parameterNumber: 7, size: 2).format(),
],500)
def configure() {
log.debug “configure”
// enable analog alert thresholds
zwave.configurationV1.configurationSet(scaledConfigurationValue: 0, parameterNumber: 8, size: 2).format(),
// turn on momentary button press, this presses it for 1 second
zwave.configurationV1.configurationSet(scaledConfigurationValue: 10, parameterNumber: 11, size: 2).format(),
// tell device to send multivalue sensor updates every 10 seconds
zwave.configurationV1.configurationSet(scaledConfigurationValue: 1, parameterNumber: 9, size: 2).format(),
// enable alarms to be sent to smartthings hub
zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
// enable multivalue sensor updates to be sent to smartthings hub
zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(),
],500)
cmds += setTriggerLevels()
return cmds
Looks like it should work (I am not advanced enough to be able to comment on the DH code)
i can only make a couple of test reccomendatitions.
1 - as @eibyer said, it’s always the best going back to basics when in trouble.
I would also create something as simple as
IF simulated switch X changes to ON
Garage door OPEN
IF simulated switch X changes to OFF
Grage door closed
2 - I would try all other available options for turning OFF (Door down)no matter how silly it looks.
I had a similar problem with blinds. I was using a device handler and it had CLOSE
but it was not working. Finally - weird enough - PRESET started turning them OFF (DOWN)
Preset supposed to bring them Up or down to decided preset position but it didn’t. It just shut them OFF.
Right now all my blinds pistons are
IF trigger happens
Blinds ON (Up)
If trigger happens
Blinds PRESET (Down - off)
3 - While turning it OFF with ST app, try to check ST IDE live logging to see whats going on, (Have not tested this suggestion, I am not sure if you can see that in ST IDE) it works for other stuff but I am not sure about your situation.
Sorry my knowledge is not on the expert level:) Just trying to help.
Let us know how it goes.
Thanks @ike2018. I’ll take any and all the help I can get. I didn’t think about checking the IDE logs. I’ll do that tonight and see if I can find something(even if its an argument instead of a preset). Weird that “Preset” works lol, but hey it works.
I’ll post back what I figure out.
So I’ve tried several different things without success. I keep getting this in the WC Live logs.
|+2ms |╔Received event [**TEST**].switch = off with a delay of 58ms|
|+101ms |║RunTime Analysis CS > 15ms > PS > 69ms > PE > 17ms > CE|
|+104ms |║Runtime (36805 bytes) successfully initialized in 69ms (v0.3.109.20181207) (102ms)|
|+105ms |║╔Execution stage started|
|+116ms |║║Comparison (enum) off changes_to (string) off = true (0ms)|
|+118ms |║║Cancelling condition #2's schedules...|
|+119ms |║║Condition #2 evaluated true (8ms)|
|+120ms |║║Cancelling condition #1's schedules...|
|+122ms |║║Condition group #1 evaluated true (state changed) (10ms)|
|+125ms |║║Cancelling statement #3's schedules...|
|+137ms |║║Skipped execution of physical command [Garage].off([]) because it would make no change to the device. (4ms)|
|+138ms |║║Executed virtual command [Garage].setSwitch (6ms)|
|+141ms |║╚Execution stage complete. (36ms)|
|+143ms |╚Event processed successfully (143ms)|
and this is what is in the logs when I close it from within the app.
[5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d](https://graph-na02-useast1.api.smartthings.com/ide/logs#5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d) 8:55:49 PM: debug Parsed command: Garage door is closed raw: zw device: 07, command: 3105, payload: 02 0A 00 00
[5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d](https://graph-na02-useast1.api.smartthings.com/ide/logs#5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d) 8:55:49 PM: debug Unhandled command: zw device: 07, command: 2001, payload: 00
[5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d](https://graph-na02-useast1.api.smartthings.com/ide/logs#5620eebb-8d6c-4e85-bb6e-4b202c6f3d4d) 8:55:34 PM: debug Unhandled command: zw device: 07, command: 2503, payload: 00
Can you share the latest piston you are using???
I am running out of ideas…
a) I would uninstall and install the device handler
b) I would email the coder
c) I would check to see if anybody else is having the same problem in ST community or here.
d) I would swear ST, WebCore, Code writer, and this guy called @ike2018 and once all that out of the way, have a nice martini, call it a night and start all over again tomorrow morning LOL
