I have 6 SmartThings leak detectors that return an incorrect battery level and stop responding even though the battery level shows it’s fine. What I’d like to do is monitor the temperature they’re reporting and have a piston react if the temperature doesn’t change over a 12-hour period, as that will tell me that one or more sensor is likely dead.
Can someone help me design a piston that will do this? I could cobble something together that monitors each sensor but I’d like something that’s more efficient and more concise than the pistons I usually cobble together.
I need something like this:
If Sensor1 or Sensor2 or Sensor3’s temperature stays the same for 12 hours then
"alert Message = “{sensorThatsNotResponding} temperature has not changed in 12 hours”
Push “alertMessage”
End if
**3) What is happening/not happen
Nothing is happening as I haven’t written the piston yet. I’m hoping someone with strong Webcore chops can assist me in creating a much more concise and efficient piston than what I usually come up with. Teach a man to fish and all that…
(UPLOAD YOUR IMAGE HERE)
